BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > show off your winter wheels
Studio RSR
      01-07-2017, 07:13 PM   #199
cobranick03
Drives: 2013 Bmw 328i M-Sport
VMR 703's w/ Nokian Hakkapeliitta R2's
VMRWheels2038.00
      01-08-2017, 07:06 AM   #200
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Nice shot cobranick03!
And great winter tires, I use R2's on both our cars.
      01-08-2017, 07:42 AM   #201
mtechnik3
mtechnik3's Avatar
Drives: 2020 M2C
18x8 Sport Edition KM11 with 225/45-18 Falken Eurowinter HS449. Lowered on H&R Sport springs. I like the setup with the BMW Performance LSD.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i
      01-08-2017, 07:08 PM   #202
xi330
Drives: 2006 330xi w/ 6mt, sport, nav
Originally Posted by TheObviousChild View Post
Just placed my order on TireRack.
18x8 Enkei Tuning Raijin Black Painted
225/45R18 Michelin Pilot Alpin PA3
The Michelin's had better scores than the Blizzaks for dry driving conditions while still performing very well in light and deep snow. Here in Denver, it often snows hard, but by the time you're heading home from work, the roads are clear and dry.
With TPMS sensors and valve stems, it came to around $2,000.
Now does anyone have a good recommendation for BMW Center Caps that will fit these wheels?
What color is your car?
      01-08-2017, 07:14 PM   #203
xi330
Originally Posted by 2blu View Post
Originally Posted by AweSam8 View Post
So since my 335i has the normal gray brakes, I should be able to fit 17's??
335i X-drive, M-sport, gray brakes, 17" winter wheels.
Is it a "rule" that the gray brakes equal smaller brakes that can accommodate 17" wheels?
      01-09-2017, 07:45 AM   #204
Araemo
Drives: 2017 340iX 6MT
Nope. See:
https://www.turnermotorsport.com/t-b...ke-Differences
There are grey/unpainted brembos of the same size as the blue/red/white brembos, but they're rare.
xi3309.50
      01-11-2017, 04:07 PM   #205
STR8-6IX
Drives: RWD 528i N52
try to avoid anything low profile for winter tires. 50+ sidewall is best.
      01-11-2017, 04:54 PM   #206
hollandog
hollandog's Avatar
Drives: F30
2016 BMW 340i  [9.00]
Not really possible with M sport brakes.
      01-11-2017, 05:22 PM   #207
Araemo
Yep, can't go below 18" wheels over those brakes, and the 'correct' size on F30 if you get 18x8 is 225/45R18.
      01-11-2017, 05:26 PM   #208
STR8-6IX
right.. forgot about that.
would 17's fit? or is 18 basically the smallest size that will fit with M brakes?
would 18/50 tires look silly on an f30?
      01-11-2017, 05:33 PM   #209
Araemo
It's not about looking silly, but if you have a taller sidewall than 225/45 on 18s, you're going to #1: have an incorrect speedometer reading, and #2: possibly have clearance issues with the fender. (Unsure an extra 11mm would do that, but I wouldn't want to deal with #1), and #3: you'd be raising the car an extra 11mm (for 225/50, compared to 225/45)
      01-12-2017, 12:37 PM   #210
VMRWheels
VMRWheels's Avatar
2038
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
I'm really diggin this picture! She looks beautiful in the snow!
      01-13-2017, 11:25 AM   #211
three40_6ix
three40_6ix's Avatar
Drives: BMW F30 340i
Currently running my OEM 18's for my 340 with Bridgestone WS80's (225/45/18)
Present: '16 BMW 340i xDrive ///MSport | Alpine White/Coral Red | M-Performance | Bootmod3 Stg 2 | xHP Stage 3 | VRSF catless dp | VMR V703 x Michelin PS4S
Previous:
'10 Audi Q5 - Sold
      01-13-2017, 05:38 PM   #212
thisismikeyb
thisismikeyb's Avatar
115
Drives: 2014 328i xDrive M-Sport EBII
Apex EC-7 18x8.5et35 w/ Michelin Pilot Alpin PA4 245/45. Pictures are from the 17th of December, driving from Maryland to Connecticut.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
hollandog448.00
      01-31-2021, 03:45 PM   #213
Theoldfm
Drives: BMW X5
Here’s mine - snow tyres on and running 18” rather than my usual 19” summer wheels.
      02-01-2021, 09:07 AM   #214
Desertnate
Drives: BMW 435i
2016 BMW 435i  [0.00]
Not the best picture of the wheels, but 18x8 ET30 Rial X10's. Tires are Pirelli Sottozero 3's in 225/45/18.
      03-04-2021, 10:54 PM   #215
Cabra
Drives: TBD
I have a 2016 F31 with track handling package (m performance brakes) and want to run 17” winter wheels
What specific wheel specs (offset, etc) do I need ?
I’ve been shopping around but worried the wrong size won’t fit over the brakes
      03-05-2021, 03:33 AM   #216
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
      03-05-2021, 08:18 AM   #217
Cabra
Drives: TBD
Originally Posted by alohasurftoad View Post
18" is the minimum diameter required for barrels to clear m-sport/performance brakes.
OEM or aftermarket square setup, 8"-8.5", ET35ish with 225/45/18 or 235/45/18 works all day(and night).
Thanks !
What about 245/45-18 square setup from a 535i
      03-05-2021, 08:45 AM   #218
Desertnate
Drives: BMW 435i
As an FYI. My F32, a couple posts up is also equipped with the track handling package and after market 18" wheels.
Snow performance is better with more narrow tires. What size wheels are coming from the 535? Bolt patterns on the wheels and offsets of the wheels would also need to be considered.
      03-05-2021, 10:10 PM   #219
Cabra
Drives: TBD
18x8 30mm offset
BMW Style 281 from a 2014 535i
      03-05-2021, 11:52 PM   #220
Cabra
Drives: TBD
at +44, the upper inner tire shoulder of a 245/45/18(26.7") diameter front tire will mostly likely touch the spring perch. i am not 100% certainty, so try it out and let us know...
Actually they are 18x8 30mm offset
