03-13-2014, 03:38 PM | #6007 |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
Yes.
You need: - buy new buttons (left and right) appropriate to your steering wheel. - disconnect negative pole of battery - open wheel - remove airbag - change the buttons with new ones - install airbag - close wheel - connect battery back - add 544 то FA - VO Code Kombi, ICM Last edited by avgor123; 03-13-2014 at 03:51 PM.. |
03-13-2014, 10:41 PM | #6008 |
Rep 286
avgor123, I'm assuming once Internet is activated with the fake VIN, you do the same process to write the original/donor VIN number which you had before for all your FSC to work? Do I have to manually activate all the FSC that are rejected or will writing the proper will fix this issue?
Any chance it will cancel the FSC? Thanks |
03-13-2014, 11:18 PM | #6009 |
Rep 286
03-14-2014, 01:18 AM | #6010 | |
Rep 122
No. FCS status changes automatically from "rejected" to "accepted". I don't know about chance of loss of FSCs. I guess you can extract all the FSCs from NBT and save them as archive copy before you play with VIN. |
03-14-2014, 01:23 AM | #6011 |
Rep 40,903
That would be a waste of time. If they ever go to Cancelled status, the cannot be recovered. New ones must be used, with a newer creation date, which is why reimporting the same ones wouldn't work. If one is using an emulator, it's no big deal to find another set, but if one has OEM ones cancelled, its a huge problem and expense getting replacements issued from BMW AG.
03-14-2014, 08:11 AM | #6012 | |
Rep 55
Just tried that one, no difference.
Also can't find RemoteControl folder under CAS module. Is it shure named like this? |
03-14-2014, 11:46 AM | #6013 |
Rep 40,903
Ok. I give up then.
03-14-2014, 02:25 PM | #6014 |
Rep 122
03-14-2014, 02:40 PM | #6015 |
Rep 40,903
CAFD_000007C8_006_004_000
03-15-2014, 09:14 AM | #6016 |
Rep 30
Hey shawnsheridan, would you mind to share the info/link for the coding?
Do you need specific details of my car or the software works well with all F30 3 Series? Thanks in advance! |
03-15-2014, 09:24 AM | #6017 |
Rep 40,903
PM sent.
03-16-2014, 06:52 AM | #6019 |
Rep 40,903
It looks like he just needs to inject CAFD into DME and VO Code DME.
03-16-2014, 09:44 AM | #6020 | |
Rep 46
I just know he want to coding M performance brake ,but I don't know what he did.He is the clerk of the shop,he want face-saving, so he didn't reveal anything. |
03-16-2014, 09:50 AM | #6021 |
Rep 40,903
He doesn't have 2 DME's. It's one DME with its Actual state in Blue, and its Target state in RED.
As I wrote above, he just needs to inject CAFD into DME and VO Code DME. That's it. And for M-Performace Brake, all that is needed is to add HO-Wort SPBR to FA and VO Code DSC module.
03-16-2014, 10:40 AM | #6022 | |
Rep 122
I think, FA they use to calculate target SVT doesn't match to real car's hardware. Last edited by avgor123; 03-16-2014 at 11:09 AM.. |
03-16-2014, 10:55 AM | #6023 |
Rep 40,903
His DME Actual state in Blue is missing it's CAFD. The Target State in Red properly shows it needs a CAFD, and based on the PSdZData's newer I-Level, it is showing the firmware can also be updated. Or as you wrote, the firmware is targeted based on improper FA.
Still, all that is needed is to inject CAFD in Coding Module into DME and VO Code it. It does not need to be flashed too.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 03-16-2014 at 09:25 PM.. |
03-17-2014, 12:18 AM | #6024 |
Rep 46
This picture is my car,my I-level is F020-13-11-504.
My friend's car I-level is also F020-13-11-504,The Actual state in blue is older version and I could't inject cafd into that(get error message). The guy have no experience in coding. Take my friend car as a guinea pig. Even attached picture and asked him why it becomes like that, but he reply that it wasn't like that before. And now ask my friend to go to the dealer for flash..... |
03-17-2014, 09:36 AM | #6025 |
Rep 941
Hi guys so after reading about people succesfully enabling traffic updates I made the following FDL code modifications below but when I try to check traffic on weekday mornings in Montreal it checks for traffic information and then ultimately always comes back with No Traffic Messages currently available. Any idea?
Thanks HU-CIC 3000 > NAVI_TRAFFIC_INFO_MAP > aktiv 3002 > TI_CA_TMC > aktiv 3002 > TI_TMC_REGIONAL > aktiv 3002 > TI_VINFO > aktiv 3002 > TI_FALLBACK_DISABLED > aktiv
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
03-17-2014, 11:50 PM | #6026 |
Rep 718
Drives: N/A
Shawnsheridan,
If you could also PM me the links to all the required software and tokens me and my F10 would appreciate it very much!
2021 F87 HS M2C
2018 F80 SO M3 (SOLD) 2016 F80 AY M3 (SOLD) 2014 F10 M5 LCI (SOLD) 2011 VO 1M (SOLD) |
03-18-2014, 12:24 AM | #6027 |
Rep 40,903
PM sent.
03-18-2014, 06:04 PM | #6028 |
Rep 234
Token question...
I have a new installation which I think is running correctly... but wanted to know if I need to buy a token to read the integration level? I'm getting an error when I try to find what the dealer upgraded my car to.
Connect>VCM Module>VCM Master Tab>Read I-Step>I-Step Current. This is the error: ParameterizationException: Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name VCM_ETHERNET doesn't map to an item' If not, then perhaps my installation is messed up. ZGW gives me a private IP and it says it connects via VIN. TIA. |
