BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Office SMS Issue - Help
      10-09-2012, 08:58 AM   #1
legaleye3000
Drives: 2014 328i; 2015 X3
I've enabled Office (at least the SMS part of Office) on my non-enhanced BT car. It reads sms, however, it will never read the latest one. When I get a new sms it will know and show the little envelope on the screen. But when I open office, it will only show old sms's.
Anyone have this problem? Thanks.
      10-10-2012, 01:20 PM   #2
demge01
demge01's Avatar
Drives: F30 320ed
I enabled office too but only get Contacts. How to you get SMS?
I have an iPhone 4 btw.
      10-12-2012, 12:55 PM   #3
legaleye3000
You have to enable it via coding. However, I'm running into the above problem running it basically useless...
      10-12-2012, 04:40 PM   #4
demge01
demge01's Avatar
Drives: F30 320ed
Yes I enabled it via coding but only get CONTACTS...
What settings did you change to get SMS with office?
      10-13-2012, 12:10 AM   #5
Nitz99
Nitz99's Avatar
Drives: 2013 AW F30 335i Sport
I'm having an issue with my SMS where the message comes through correctly and immediately but when I try to use the call back option in the left column it does not work. It will ring twice and then say "the number you have dialed is not in service, etc.". Is anyone else successfully able to call a number back directly from the SMS screen on idrive?
      10-13-2012, 01:11 AM   #6
LousyShot
LousyShot's Avatar
Drives: M340i xDrive
Hmmm, haven't tried that yet. I'll give it a shot tomorrow and let you know if it works.
      10-13-2012, 04:18 PM   #7
lematt
Drives: 2013 328i X-Drive, Sport
How do you activate SMS "by coding"?
Thanks!
      10-13-2012, 05:45 PM   #8
LousyShot
LousyShot's Avatar
Are you talking about replying to an SMS through iDrive? I haven't had anything coded on my car and I can recieve/read SMS and email through iDrive with my Galaxy SII. I still have to pull out the phone to send a reply (hope BMW incorporates a voice to text update one day).
      10-13-2012, 08:30 PM   #9
Nitz99
Nitz99's Avatar
Any luck on this LousyShot?
      10-14-2012, 12:50 PM   #10
LousyShot
LousyShot's Avatar
I was able to call back to the SMS sender by clicking the call back icon on the left side of the message display. The message was from someone already in my contacts list so I don't know if that made a difference or not, but everything worked as advertised.
Hope that helps.
      10-14-2012, 08:52 PM   #11
Nitz99
Nitz99's Avatar
I was able to call back to the SMS sender by clicking the call back icon on the left side of the message display. The message was from someone already in my contacts in my contacts list so I don't know if that made a difference or not, but everything worked as advertised.
Hope that helps.
Thanks for testing this. The call back feature is exactly what I was questioning. It doesn't work for me. It dials some 5 it 6 digit code even though the person is in my contacts. Maybe I need to update my software?
      10-15-2012, 01:56 PM   #12
Quelque
Netherlands
Drives: F30 330e
Hi legaleye3000, I am also interested to know how to enable it. I assume you used E-sys etc? It would be great if you could share with us which settings you changed in which module!
      10-15-2012, 10:40 PM   #13
LousyShot
LousyShot's Avatar
I didn't try it before I installed the latest bluetooth update, so it may help get yours working. Only other suggestion after installing the update is to delete and re-pair your phone (I had some issues when I first got the car and re-paring helped). When I deleted the phone from the cars memory, I went into the phone and deleted the car so that I had a fresh start on both.
Hope you get it figured out.
