07-03-2014, 08:35 PM | #6821 |
Rep 40,785
PM sent.
07-03-2014, 08:58 PM | #6822 |
Rep 6
Sorry, when I said code it I mean to make it appear on the front glass. "Make it exist" lol. I have no idea if this can be done.
How do I know if it has 610 Head-up display as you said? |
07-03-2014, 09:00 PM | #6823 |
Rep 40,785
The easiest way is you would see a projector in the dashboard above the instrument cluster.
07-03-2014, 09:18 PM | #6824 |
Rep 6
07-04-2014, 08:59 AM | #6825 |
BMW CCA #505303
43
Rep 185
You should see something like the this when you are driving. There is also a button to the left of the steering column to toggle the HUD on/off, but you would see an opening in the dash in front of the steering wheel as well.
2015 BMW X5M F85 ///M
07-04-2014, 09:15 AM | #6826 | |
BMW CCA #505303
43
Rep 185
Hi Shawn,
I have the following coded for USB video: HU_NBT => API_USB_VIDEO = both (Werte=03) HU_NBT => ENT_MC_VIDEO_SUPPORT = aktiv (Werte=01) HU_NBT => ENT_CODEC_OGG = aktiv (nicht_aktiv) HU_NBT => ENT_CODEC_VCD = aktiv (Werte=01) HU_NBT => ENT_CODEC_XVID = aktiv (Werte=01) From the looks of your recommendation, I'm missing the ECC_CODEC_OGG setting, which is probably my issue. I'll modify this and hopfully it will work then. Thanks again! Sean Quote:
07-04-2014, 09:23 AM | #6827 |
Rep 40,785
Well, OGG is simply one Codec. Unless you try and play OGG file, it would not make a difference.
If you are using your phone though, try instead using a USB Flash Drive with .mp4 on it, and see if you can play it.
07-04-2014, 09:33 AM | #6828 |
Rep 1,976
Drives: 2020 G20 320i M Sport
Does anyone have the settings to disable the DRL bulb check if the halogen bulbs were replaced with LEDs on an F30?
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
07-04-2014, 09:46 AM | #6829 |
BMW CCA #505303
43
Rep 185
Ok, good point.
What I was trying to do was get the iPhone display to show on the iDrive screen so that I could play anything from a video to the local news if stuck in traffic etc... I've only tried it twice now, but when I plug it in via the standard Apple USB cable plugged into my iPhone 4S, then go to 'External Devices' and select my phone, it's giving me a message on the screen that the device that's being connected is not compatible (or something to that effect). I'm doing this through the center console. Oddly, on my 2011 335i with NO mods whatsoever, I could play iPhone music videos while stopped in traffic, but of course then when I started to move they stopped and gave me the default 'warning' message. I can't even seem to get it to play anything from the iPhone, even while parked in the garage, and what's odd is that the iPhone screen states that the video is being played on a 'TV Screen', so it's thinking it's doing something. All this is making me think I'm missing another setting somewhere else. Additionally, with this said I can't get the iPhone 4S to display texts, messages, emails, anything, etc... on the iDrive, even the dealer was stumped by this when I picked up the car. As I write this, I recall on my 2014 F12 that under Bluetooth settings it would allow you to select a second phone (wifes) via a check box to allow for a second phone to be connected to the car and I've noticed that this is not present on the 2015 F12 any longer.
07-04-2014, 11:10 AM | #6830 |
Now in the dark side !
65
Rep 1,136
Aren't you supposed to use a special cable to hook up a pre-iPhone5 to your car for more functionality (ex: BMW Apps) ?
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
07-04-2014, 11:58 AM | #6831 | |
Rep 40,785
What is the Bluetooth Option Code you have?
07-04-2014, 02:17 PM | #6832 | |
Rep 80
Can I code them for NTB 07/2013 ? |
07-04-2014, 03:10 PM | #6834 |
Rep 38
Speed Limit Info Display
I have a 2014 F30, it does not have the Driver Assist Plus package with the camera in the rear view mirror. I do have GPS and just about every other option..I would like to activate the portion of SLI which is provided with the GPS
to display in my HUD - is there a coding option to do that?? |
07-04-2014, 03:44 PM | #6835 |
Rep 40,785
Ok. It's a False Positive. So disable Norton and download it.
07-04-2014, 03:48 PM | #6836 | |
Rep 40,785
But, you cannot enable it without a 7E FSC FSC Enabling Code issued by BMW AG for your VIN, which is so far impossible to get.
07-04-2014, 06:42 PM | #6837 |
BMW CCA #505303
43
Rep 185
Here is the build sheet from my car and I'd actually be happy to send you my CAFD files if you wanted to look at all the new stuff they've put in the 2015's if you don't already have it.
Type Value VIN xxxxxxxxxxxxxxxxx Type code YP13 Type 650I XDRIVE (USA) E series F12 () Series 6 Type CABRIO Steering LL Doors 2 Engine N63T Displacement 4.40 Power 330 Drive ALLR Transmission AUT Colour CARBONSCHWARZ METALLIC (416) Upholstery EXCL.LEDER NAPPA ERW./ZIMTBRAUN (NAEZ) Prod.date 2014-04-03 Code Description (interface) Description (EPC) S1CAA SELEKTION COP RELEVANTER FAHRZEUGE Selection of COP relevant vehicles S223A ELEKTRONISCHE DAEMPFER CONTROL(EDC) Electronic Damper Control (EDC) S248A LENKRADHEIZUNG Steering wheel heater S2NMA 20" M LM RAEDER DOPPELSP. 373 M/MB BMW LA wheel, M Double Spoke 373 S2VBA REIFENDRUCKANZEIGE Tire pressure display S319A INTEGRIERTE UNIVERSAL-FERNBEDIENUNG Integrated universal remote control S322A KOMFORTZUGANG Comfort access S323A SOFT-CLOSE-AUTOMATIK FUER TUEREN Soft-Close-Automatic doors P337A M SPORTPAKET M Sports package S388A VERDECK SCHWARZ Softtop, black S3AGA RUECKFAHRKAMERA Reversing camera S3DZA ENTFALL ZUSATZ-SCHRIFTZUG AUSSEN Delete extra external lettering S423A FUSSMATTEN IN VELOURS Floor mats, velours S430A INNEN-/AUSSENSPIEGEL AUT.ABBLENDEND Interior/outside mirror with auto dip S453A AKTIVE SITZBELUEFTUNG VORN Climatised fornt seats Code Description (interface) Description (EPC) S456A KOMFORTSITZE ELEKTRISCH VERSTELLBAR Comfort seat with memory S464A SKISACK Ski bag S488A LORDOSENSTUETZE FAHRER/BEIFAHRER Lumbar support, driver and passenger S494A SITZHEIZUNG FUER FAHRER/BEIFAHRER Seat heating driver/passenger S4KSA KONTRASTSTEPPUNG Contrast stitching S4NDA INSTRUMENTENTAFEL LEDERBEZOGEN Instrument panel, leather-covered S4U1A KERAMIKAPPLIKATION F.BEDIENELEMENTE Ceramic appliques for controls S4URA AMBIENTES LICHT Ambient interior lighting S508A PARK DISTANCE CONTROL (PDC) Park Distance Control (PDC) S552A ADAPTIVER LED-SCHEINWERFER Adaptive LED headlight S5A1A LED-NEBELSCHEINWERFER LED Fog lights S5ACA FERNLICHTASSISTENT High-beam assistant S5AGA SPURWECHSELWARNUNG Lane-change warning S5ASA DRIVING ASSISTANT Driving Assistant S5DLA SURROUND VIEW Surround View S609A NAVIGATIONSSYSTEM PROFESSIONAL Navigation system Professional S610A HEAD-UP DISPLAY Head-up display S655A SATELLITENTUNER Satellite tuner S697A AREA-CODE 1 Area-Code 1 for DVD S6ACA INTELLIGENTER NOTRUF Intelligent emergency SOS call S6AEA TELESERVICES TELESERVICES S6AKA CONNECTEDDRIVE SERVICES Connected Drive Services S6AMA REAL TIME TRAFFIC INFORMATION Real-Time Traffic Information S6ANA CONCIERGE SERVICES Concierge Services S6APA REMOTE SERVICES Remote Services S6F2A BANG&OLUFSEN HIGH END SURROUND SOUN Bang&Olufsen High End Surround Sound S6WBA MULTIFUNKTIONALES INSTRUMENTENDISPL Multifunctional instrument display S710A M LEDERLENKRAD M leather steering wheel S715A M AERODYNAMIKPAKET M Aerodynamics package S760A INDIVIDUAL HOCHGLANZ SHADOW LINE High gloss shadow line P7MHA M SPORT EDITION M Sport Edition S840A HOCHGESCHWINDIGKEITSABSTIMMUNG High speed synchronisation S8KLA OELWARTUNGSINT. 15.000KM/12MONATE Oil service interval 15,000 km/12 months S8S4A DECODIERUNG VARIABLE LICHTVERTEILUN Decoding variable light distribution S8THA SPEED LIMIT INFO SPEED LIMIT INFO S8TNA TAGFAHRLICHT UEBER LICHTMENUE EINST Dummy-SALAPA S925A VERSANDSCHUTZPAKET Transport protection package S9AAA AUSSENHAUTSCHUTZ Outer skin protection S1CCA AUTO START STOP FUNKTION Auto start/stop function S1CDA BRAKE ENERGY REGENERATION Brake Energy Regeneration S212A AUSSTATTUNG BREMSANLAGE LAENDER Equipment, brake syst. country-specific S2TBA SPORT-AUTOMATIK GETRIEBE Sport automatic transmission S302A ALARMANLAGE Alarm system S4ASA EDELHOLZAUSF. PAPPEL MASER GRAU Fine-wood trim poplar grain grey S4U2A FAHRERLEBNISSCHALTER INKL. ECO PRO Driving experience switch incl. ECO PRO S5DSA KOFFERRAUMNOTENTRIEGELUNG Emergency release, luggage compartment S645A RADIO-STEUERUNG US BMW US Radio S6NHA FREISPRECHEIN. M. USB-SCHNITTSTELLE Hands-free with USB interface S823A HEISSLAND-AUSFUEHRUNG Hot-climate version S845A AKUSTISCHE GURTWARNUNG Acoustic belt warning S850A ZUSAETZL. TANKFUELLUNG EXPORT Additional Export tank filling S853A SPRACHVERSION ENGLISCH Language version English S876A FUNKFREQUENZ 315 MHZ Radio frequency 315 MHz S8SMA FAHRGESTELLNUMMER,V.AUSSEN SICHTBAR Car ident. number visible from outside
07-05-2014, 12:05 AM | #6838 |
Rep 1,976
I coded an F32 435i the other day build date 05/2014 and the VIN said it had 6NH but he still had the Bluetooth Audio option enabled but not office.
I think 2015 models and some 2014 models will have just the Bluetooth Audio streaming enabled if they are on NBT with 6NH.
07-05-2014, 12:27 AM | #6839 |
Rep 40,785
As I suspected, as loaded out as your F13 is, it has 6NH Basic Bluetooth and not 6NS EBT. You need to change it an code EBT.
07-05-2014, 01:17 AM | #6840 | ||
M3AT LOVER
322
Rep 1,853
http://f80.bimmerpost.com/forums/sho...5#post15730245
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
07-05-2014, 05:31 AM | #6842 |
Rep 40,785
F82 uses F20 PSdZData (target).
