08-06-2015, 03:55 AM | #9087 | |
Rep 109
In addition to the issue of FEM_BODY, as I mentioned earlier, I couldn't find C_ZSW_Aktivierunggeschwindigkeit_Funktion_low in ICM (CAFD_0000067B_002_003_139.ncd). So at least two ECUs have the issue. Does it look like the beginning of the end for the current approach of coding? If so, it will definitely make people think twice about re-programming their cars during service. |
08-06-2015, 06:25 AM | #9088 |
Rep 40,795
The beginning of the end was Nov 2014 beginning with F020-14-11-502. E-Sys Launcher is merely a workaround with a limited useful life.
08-06-2015, 09:01 AM | #9089 |
Rep 98
I have a torrent file from version 54.0
Can be? Send me a private message sent to you by e-mail.
08-07-2015, 12:03 AM | #9091 |
Rep 40,795
PM sent.
08-07-2015, 05:58 AM | #9093 |
Rep 109
I just noticed that the cafd_0000067b.caf.002_003_139 of 3.56.1 is different from the cafd_0000067b.caf.002_003_139 of 2.49.4. Is this normal? I thought that they would be the same file.
I was looking for the parameter for lowering the Blind Spot Detection activation speed. Two years ago with 2.49.4 I changed ICM -> 3000 Daten,F8 -> HcSwcCPar_i_Hc2_Aktiv_v_low. Now for 3.56.1 in the ICM cafd file with the same name I can not find it as the function parameter. But I did find it in the the comment of another function parameter C_ZSW_SensHellkUmgebEna: 3000 Daten (Data), F8 C_ZSW_SensHellkUmgebEna Comment = yw130314: auscodiert yw120703: umbenennen C_ZSW_Aktivierungsgeschwindigkeit_Funktion_low->C_ZSW_SensHellkUmgebEna yw120417: F25 30kmh yw120412: Codierwert 00,01 yw120411: umbenennen von HcSwcCPar_i_Hc2_Aktiv_v_low ->C_ZSW_Aktivierungsgeschwindigkeit_Funktion_low,we rte von 20 auf 2 reduziert. re090904: DoorsName:HcSwcCPar_i_Hc2_Aktiv_v_low re091012: rename von L6alt-Name:Hc2_i_CPar_Aktiv_v_low OPTIONS false = 00 true = 01 Unknown (UNKNOWN) = 02 Unknown (UNKNOWN) = 03 Unknown (UNKNOWN) = 04 Unknown (UNKNOWN) = 05 Unknown (UNKNOWN) = 06 Unknown (UNKNOWN) = 07 Unknown (UNKNOWN) = 08 Unknown (UNKNOWN) = 09 Unknown (UNKNOWN) = 0A Unknown (UNKNOWN) = 0B Unknown (UNKNOWN) = 0C Unknown (UNKNOWN) = 0D Unknown (UNKNOWN) = 0E Unknown (UNKNOWN) = 0F Unknown (UNKNOWN) = 10 Unknown (UNKNOWN) = 11 Unknown (UNKNOWN) = 12 Unknown (UNKNOWN) = 13 it seems to be the one I am looking for. Last edited by valley_nomad; 08-07-2015 at 06:06 AM.. |
08-07-2015, 06:38 AM | #9095 |
Rep 40,795
Again, this is a CAFD Mapping issue. HcSwcCPar_i_Hc2_Aktiv_v_low does exist in cafd_0000067b.caf.002_003_139. It was removed beginning with cafd_0000067b.caf.002_004_082. As I previously wrote, the CAFD Mapping in E-Sys Launcher 2.x is based on the highest CAFD version in the last Untrimmed PSdZData set, which is 54.1, so it is mapping, incorrectly in this case, based on the newer CAFD. This is why cars with I-Levels <= 54.1 (F020-14-11-502) should not use newer PSdZData and E-Sys Launcher 2.x with CAFD Mapping. They should use 54.1 PSdZData and E-Sys Launcher 1.x without CAFD Mapping.
08-07-2015, 06:43 AM | #9096 |
Rep 40,795
If comparable to BMW Sport Brake Option, I would add to FA HO-Word SPBR, and VO Code DSC.
08-07-2015, 03:12 PM | #9097 | |
Rep 109
yw130314: auscodiert yw120703: umbenennen (rename) C_ZSW_Aktivierungsgeschwindigkeit_Funktion_low->C_ZSW_SensHellkUmgebEna yw120417: F25 30kmh yw120412: Codierwert 00,01 yw120411: umbenennen von (renaming) HcSwcCPar_i_Hc2_Aktiv_v_low -> C_ZSW_Aktivierungsgeschwindigkeit_Funktion_low,wer te von 20 auf 2 reduziert re090904: DoorsName (name):HcSwcCPar_i_Hc2_Aktiv_v_low re091012: rename von L6alt-Name:Hc2_i_CPar_Aktiv_v_low All in all, C_ZSW_SensHellkUmgebEna should replace C_ZSW_Aktivierunggeschwindigkeit_Funktion_low or HcSwcCPar_i_Hc2_Aktiv_v_low in Coding Cheat Sheet for F020-15-07-502 Last edited by valley_nomad; 08-07-2015 at 03:44 PM.. |
08-07-2015, 04:56 PM | #9098 | |
Rep 40,795
08-07-2015, 06:42 PM | #9099 | |
Rep 109
If this is the case, it certainly poses some issues for coding ECUs that still uses previous versions of trimmed CAFDs, e.g. my 2013 328 now has I-level of F020-15-07-502 after service in July 2015 and still uses cafd_0000067b_002_003_139 instead of cafd_0000067b_002_004_048. Not only do some function parameters' names change, but also some useful ones are not properly displayed (i.e. shown only as daten items) and some bogus ones are incorrectly added by the mapping. Hopefully the new release of tools will solve the issue. One quick fix in this case is to just simply replace the trimmed CAFD file with the untrimmed version of that same file in previous versions (e.g. 54.1) of psdzdata, which can be done automatically with some simple PC tools if many files needs to be replaced. Last edited by valley_nomad; 08-11-2015 at 03:44 PM.. |
08-08-2015, 03:40 AM | #9100 | |
Rep 109
Attachment 1258454
1. For coding ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN, changing the value of PfExternalMirrorMaster_7_7_255 from 04 to 05 2. As you already found out, manually changing the value of BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN from 00 to 01 Update: I thought I located the correct location of ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN by assuming that its position in ncd had not been changed -- i.e. the LSB of 8th (no. 7) byte of 3110. However, it didn't work I checked by reading back from ECU and verified that the coding is ok because that bit has been indeed set to 1. So either BMW changed the location of ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN in ncd or the updated firmware no longer has the feature... Update 2: After some more digging (see http://f30.bimmerpost.com/forums/sho...postcount=9135), here is the real workaround (when editing CAFD_00000794_014_040_122.ncd with ESysLauncherPremium V2.1.2 Build 63): 1. For ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN: PfExternalMirrorMaster_1_1_1 -> aktiv 2. For ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN: PfExternalMirrorMaster_8_8_1 -> aktiv Last edited by valley_nomad; 08-10-2015 at 12:49 AM.. |
08-08-2015, 02:49 PM | #9102 |
Rep 40,795
08-08-2015, 03:15 PM | #9103 |
Rep 109
Hi Shawn, Can I get the link for 54.1 Light? One way to solve mapping issue for older CAFDs is to just simply replace the trimmed CAFD files in new psdzdata with the corresponding untrimmed CAFD files in 54.1. Thanks
08-08-2015, 07:22 PM | #9104 |
Rep 960
Shawn,
Can you hook me up once again with stuff for coding. I'm wanting to code my F30 328 (i-step = F020-13-11-502) and my friend's F20 M135 (nov 2014 build) (i-step = F20-14-11-502? i think??) Just looking at doing some coding via esys? ... hoping the lite PSdZData will do? can you send me links for the data and esys exe, hoping to use on win10 Thanks in advance~! |
08-08-2015, 09:42 PM | #9105 | |
Rep 40,795
PSdZData Lite is all that is needed for coding. Win 10 works fine.
08-09-2015, 12:04 AM | #9106 |
Rep 3
Hi Shawn,
Looking to learn how to code my 2013 F10 and hoping you can direct me to the necessary files including the Psdzdata, e-sys software, launcher and other programs/files needed to get it to work. I just bought a cable and looking to tinker around and learn more about the vehicle. Thanks in advance! |
08-09-2015, 12:05 AM | #9107 | |
Rep 40,795
08-09-2015, 12:27 AM | #9108 |
Rep 40,795
PM sent.
