03-23-2018, 11:13 PM | #1 |
Rep 379
Need advise 225/45R18 vs 245/40R18 Also RF vs NRF
Hi All,
Need advise on 225/45R18 vs 245/40R18 Also RF vs NRF ... i have 2016 328i with M Sport Pkg and Staggered wheel setup. Front : 225/45R18 Rear : 255/40R18 Today i purchased Michelin Pilot Sport A/S 3 Plus in above mentioned size in discount tire and went for installation. After completing the installation of rear tires, the sales guy called me and said they have some problem in the inventory and could not find the front tires in 225/45 size and said he will install 245/40. In case if i am not satisfied with the handling, he said he will replace them with 225/45. In the evening i took the car out for a drive and see some issues while cornering. On a 55mph curved ramp i was on 60mph and i feel the front side of the car wobbling badly. I tried multiple ramp at some random speeds and feel the same thing. Can you guys suggest if the wobbling is due to different tire size or because of Non run flats as it will have softer side walls ? Thanks & Regards, Kishore. |
03-24-2018, 01:37 AM | #2 |
2JZ-GTE
3031
Rep 3,992
Don't they rub? I would ask the Tire people to put the proper size tires on.
You want to run Michelin pilot super sports or greater. |
03-24-2018, 01:58 AM | #3 |
Rep 7,484
Yes it can cause wobble and handling problems. Due to the tyres he put on your speedo is out by 1 per cent - not a big deal. However, you have lost more than 3mm on wheel arch gap with a bigger tyre. This in turn impacts on the front geometry. Your options are get the original tyre size intended or get a full geometry done i.e. alignment, camber and, toe adjustment.
It's nothing dangerous it just means your car won't handle as intended and you won't enjoy it. Get the proper tyre size and give back the ones you are unhappy with because now you know. |
otay826.00 |
03-24-2018, 04:04 AM | #4 |
Rep 878
What pressure is the tyre inflated to?
03-24-2018, 08:57 AM | #6 |
Rep 379
The tire shop had it inflated to 37psi all around , felt wobbling with that psi then i changed it to 34psi and 33psi still the same feeling.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
03-24-2018, 08:58 AM | #7 |
Rep 379
what's the tire inflation you are using ? is it AWD ?
03-24-2018, 09:10 AM | #8 |
Rep 847
rwd still working out the ideal psi, been raining a lot here so havent done the chalk test
03-24-2018, 09:12 AM | #9 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Are the tires too wide for the wheels? Ran 245/275 X 19" NRF on a RWD 335is with no handling issues. Current owner Auto-X's the car.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
03-24-2018, 09:16 AM | #10 |
Rep 379
doesn't feel too wide ... may be i can post some pics in few hours.
03-24-2018, 09:19 AM | #11 | |
Rep 379
03-24-2018, 09:21 AM | #12 | ||
Rep 847
03-24-2018, 09:44 AM | #13 | ||
Rep 7,484
03-24-2018, 10:48 AM | #14 | |
3127
Rep 5,264
The car might have wheels that are too narrow for the tires. Michelin spec is: 225/45R18 Rim width 7" to 8.5" Sweet spot 7.5" 245/40R18 Rim width 8" to 9.5" Sweet spot 8.5" I have no idea what your stock wheel size is so you need to look it up.
Kevin
eluded3030.50 |
03-24-2018, 01:23 PM | #15 | |
2JZ-GTE
3031
Rep 3,992
There is no way I'd run 245 with 255's in the back on this car. That would totally mess up the handling and it would probably make the car a little tail happy. |
03-24-2018, 02:09 PM | #16 | ||
Rep 847
03-24-2018, 03:15 PM | #17 |
3127
Rep 5,264
Agree, no reason for the handling to go south over the tire size switch. That said if it was good before the tire change & bad after it has to be tire related.
Out of round tire, bad balance, did something get damaged on the lift? etc. Problem is "wobbly" is a non description to try to trouble shoot.
Kevin
03-24-2018, 11:59 PM | #18 | ||
Rep 379
03-25-2018, 08:59 AM | #19 |
Rep 41
I would have the proper size tire put on the fronts and then evaluate how you like the tires. I can tell you I recently put on pirelli p zero all season non rft tires. I drove on them for about two weeks. At first I liked the new tire as impacts over bad pavements where less harsh . As i drove more on themI noticed the steering in the car felt more disconnected and the suspension was bouncier. After two weeks I returned the tires and swapped them for the original pirelli p7 cinturato all season rft. The rft definitely are harsher over broken pavement but I think they handle much better and feel more planted on the highway. I have the base x drive suspension. I am lucky as Discount Tire in my area matches tires racks pricing and lets you return your tires with in the first 30 days and re select if you are not happy. Most posters seem to like the switch to non rft. For me I am way happier with the way the car feels with original rft. Maybe non x drive suspensions would drive and handle better if you switch to non rft tires?
Machinebuilder278.50 |
03-25-2018, 09:18 AM | #20 | |
Rep 379
