05-13-2018, 03:48 PM | #1 |
Rep 11
I need PDC on the main screen
Hello !
I have done a retrofit of a NBT on my E60 with Cus.tomRetro.fit Emulator but I need parameters to change in E-Sys to change from "Actual" photo to "Desired" photo directly. <= see attachment "ACTUAL" or SCREEN #1 The space at the centre of the screen is for the rear camera (on the "actual" photo) but I don't want a camera. I just want to recover my PDC with drawn car at the centre of the screen. <= see attachment "DESIRED" or SCREEN #2 Cus.tomRetro.fit said this for my problem : "As i said you can not have screen #2 directly because in order for PDC graphic to work correct emulator must send camera information to NBT." but I think it is possible with the good combination of E-Sys setting. I have tried COMMUNICATION_PARKMASTER = gen1 but PDC doesn't display anymore with this setting I have tried too : PDC direction : in "horizontal" setting => nothing changes compared to "vertical" If someone can help me, Thanks in advance ! |
04-14-2020, 11:18 PM | #2 |
Rep 2
Just keep this information for other one to use Full PDC screen without camera like Screen #2,
1. Open Custom emulator and Turn OFF SW4 + SW5 2. FDL coding: PDC_DIRECTION: horizontal |
04-15-2020, 03:35 AM | #3 | |
Rep 11
Hi ! Thank you I will try, thank for the info because I tried a lot of things but it never run as I want to. |
