03-08-2013, 12:16 AM | #1 |
Rep 21
Retrofit comfort access?
How hard/expensive would it be to add comfort access to my 2013 328i? Even to add just the doors and skip the kick pop trunk.
03-08-2013, 01:39 AM | #2 |
Rep 606
The cost would probably not be worth it just to have the doors unlock without removing the fob from your pocket. The issue is not the recode but the fact that you would need to replace the drivers side and passenger side ext. door handles as well. There is a ribbed portion on these door handle which is electronic and control the locking and unlocking. I have heard figures as high as 1,500 US. BMW now has their new cars able to start with the fob in your pocket which years back was draw to the comfort access.
03-08-2013, 10:20 AM | #4 |
Rep 195
I think the door handles might be most of the hardware that's actually needed (if it's even possible to install CA without the trunk sensor). I know that all the wiring and harnesses are already in the door because my non-CA equipped car had to be taken in for service for a door rattle shortly after delivery. Apparently, the CA wiring harness had shaken loose and was rattling against the panels.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy. |
03-08-2013, 09:11 PM | #6 |
Rep 606
Honestly, just to have the doors lock and unlock without the key in hand is not worth the money or effort. As for the trunk pop, mine is hit and miss at best and more miss.
03-08-2013, 09:21 PM | #7 | |
Rep 1,831
Drives: 335i MSport + MPS/MPPK
I was skeptical of paying for the CA and I have to say, I am a lazy bastard. I absolutely love it. One of my favorite features. |
03-09-2013, 12:45 AM | #8 |
Rep 606
I am only working on my 3rd week of owning this car. So, I really have not even used the trunk feature all that much. So far I have found it to be very touchy. Funny enough my CA was able to pop the trunk every time he tried without fail. I seem to get it 1 in 5 times. Guess I'm still in the learning stage.
03-09-2013, 08:06 AM | #9 | |
Rep 1,831
03-09-2013, 07:41 PM | #10 |
Rep 21
Interesting, so essentially I could purchase the two front handles from here.
http://bmwpartsunlimited.com/parts/2...e%2C%20outside Link up the wires to the new handle and code up CA according to a post in the coding page. "If you add the hardware, the you should be able to just add S322A Comfort Access to your VO and VO Code CAS module." - ShawnSheridan And half a half way Comfort Access? Is there anything I'm missing? And on a sidebar, can anyone submit a picture of their trunk kick sensor to see if maybe I can makeshift a 3/4 Comfort Access. |
03-11-2013, 10:03 AM | #11 | |
Zooombie attaaack!!
136
Rep 1,179
03-11-2013, 11:46 AM | #12 | |
Rep 2,710
Drives: MB E350 4MATIC Estate
My trunk works 99% of the time since I figured out how to do it. My kids can do it now! |
03-13-2013, 01:42 AM | #13 |
Brit Abroad
392
Rep 707
Drives: 2016 Frozen Black M4
My kick works 99% of the time. The only time it doesn't, is when i try to run by, like OC40 said.
07-05-2013, 08:51 PM | #14 | |
Rep 473
Hey have you or anyone else managed to retrofit CA yet? Interested to know how it all went.
Cheers , Matt Quote:
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned Current - 2019 BMW G20 330i M Sport Alpine White Retired - 2018 - Range Rover Velar SE D240 Retired - 2015 - Mercedes Benz C250d AMG Line W205 |
07-08-2013, 09:47 AM | #15 |
Rep 84
07-08-2013, 12:20 PM | #16 |
*burp*
Rep 537
This sounds interesting. I bought my car off the floor and ca was one of the options I wanted but couldn't add. Interested to know what parts are needed
07-20-2013, 02:54 PM | #18 |
Rep 19
Note: I have not done this yet.
I did some research on my F10. For F10 , I need - a new CAS4 (Car Access System) module that supports CA. ie. F10 has 2 types of CAS module. One CA , another Non-CA - 2 new CA front door handles Note: For F10 you can code CAS to indicate that the CA handle are not installed in the passenger and rear doors. - 3 exterior antennas and 3 interior antennas - Maybe need new pair of keys. ???? - Wiring harness and connectors. For F30 , the CAS function is integrated into FEM module. FEM - Front End Module. I've checked realoem and it seems that F30 only has one type of FEM module. This mean that F30 FEM might already support CA function. (Maybe need some coding to enable it). If that is the case , then F30 owner only need CA capable door handle ,antennas, keys and wiring harness. You can check if F30 is prewired with CA or not by removing your door handle. Check following link on how to remove door handle. http://f10.m5post.com/forums/showthread.php?t=778634 Note that CA door handle has additional 4pins connector. The other 2 pins connector is for Welcome Light. For those that dare, buy one door handle and try out. Can get coding help from bimmerfest. Hope that the above information will help F30 owner that wants to retrofit CA. Cheers. Last edited by mikessc; 07-20-2013 at 03:39 PM.. Reason: Missed out antenna and keys |
02-14-2015, 02:52 PM | #21 |
***** noob
1368
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Everyone should complain to BMW not having CA as a stand alone option
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
