08-16-2017, 01:21 PM | #1 |
Rep 18
20" wheel options for 356m f32 xdrive
I have a 2014 435 xdrive I just bought 356m wheels w the following tires installed.
245/35-20 fronts 275/30-20 rears I think the rolling diameter is 26.75" if I calculated correctly What I'm wondering is if these are alright to run or not. I don't want to damage any drivetrain components if that's the case. And if I need to run different tires any recommendations would help. Tirerack was recommending 225/35-20 front and 255/30-20 rear |
08-16-2017, 09:23 PM | #2 | |
Rep 1,015
08-16-2017, 09:42 PM | #3 | ||
Rep 18
08-17-2017, 06:05 AM | #4 |
Rep 554
The style of wheel wouldn't make a difference.
Boston CCA 383036
'20 M340i '18 MB GLS550 '07 4Runner V8 Limited 4WD |
08-17-2017, 06:38 AM | #5 | |
Rep 18
08-17-2017, 07:29 AM | #7 |
Rep 18
08-17-2017, 08:38 AM | #8 |
A family of bimmers
2745
Rep 7,741
thats way off for a xdrive. you need to be less than 1% difference
08-17-2017, 09:08 AM | #9 |
Rep 554
I just saw you mention the style of wheel which wouldn't matter. The diameter (19" vs 20") changes the tire size anyway, and regardless, you should be within 1% of the overall diameter of the factory setup. Seems you already know how to calculate this so you can size the tires accordingly.
Boston CCA 383036
'20 M340i '18 MB GLS550 '07 4Runner V8 Limited 4WD Last edited by skw; 08-17-2017 at 10:55 AM.. |
08-17-2017, 09:18 AM | #10 | |
Rep 18
08-18-2017, 08:18 AM | #11 |
A family of bimmers
2745
Rep 7,741
Those tires are pretty tall for the f30 platform. more than likely better for the f10. nevertheless they fall under 1% difference.
you could hypothetically run a 235/35/20 up front putting it at 26.48f, 26.49r.
Nbarrett1.00 |
08-18-2017, 08:50 AM | #12 | |
Rep 18
235/35-20 front 275/30-20 rear |
