10-18-2017, 09:12 PM | #1 |
Rep 12
Maybe one of the Fastest F30 0-100km/h acceleration 3.27s
Hi ALL,
A few days ago, my F30 335i xdrive N55 PWG has just achieved 0-100km/h in 3.27s measured by two different 10GHZ accurate GPS. 1/4 mile in 11.1s youtube link: Car: 2014 F30 335i xdrive PWG N55 Mod: Pure stg2 turbo, BMS JB4, BM3, PI and meth 25psi boost Location: Shanghai, China Temp.: 20 degrees C With driver and half tank, the car was around 1800kg. I will try to do some weight reduction, what's the most efficient way to reduce weight on this F30? please share your valuable comments! Thank u in advance! My wechat ID: 1405817816 |
10-18-2017, 09:48 PM | #2 |
Rep 3,622
Very fast. What boost do you drive at every day?
BMW CCA Member #516012
10-18-2017, 09:55 PM | #3 |
Rep 3
thats insane. What mods are in this beast???
10-19-2017, 03:13 AM | #5 |
Human
932
Rep 1,200
Awesome time! Congrats!
Small note: the GPS is 10Hz not 10GHz
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album 2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album |
10-19-2017, 10:43 AM | #7 |
Cheapskate
4447
Rep 4,993
Nice time.
Easiest ways to reduce weight: Go down to a quarter tank of fuel Remove rear seats Remove trunk Lining Remove catback If you get really serious, definitely swap smaller brakes/wheels. Find a salvage 320i and take the set off of it. |
10-19-2017, 01:02 PM | #8 |
Human
932
Rep 1,200
Also look into a set of light forged wheels, if you want to shed some weight.
You want to reduce as much as you can from "rotating" mass
10-19-2017, 01:19 PM | #9 |
Rep 888
Judging from his picture he looks to have BBS FI-R which are about as light as they come...I would assume they are authentic ones but it's hard to tell.
10-19-2017, 03:21 PM | #10 |
Human
932
Rep 1,200
Well spotted!
10-19-2017, 07:57 PM | #14 |
Rep 12
Thank you and I will starts to remove muffler as it was 25kg T309
10-19-2017, 07:58 PM | #15 |
Rep 12
10-19-2017, 09:03 PM | #16 | |
Cheapskate
4447
Rep 4,993
and no matter how your wheels are made, bigger will weigh more and the tires will grip less. i'm telling you, drop down to 17s and some tall tires and your times will jump without changing anything else. removing weight from the inside of the car might not have as big of an effect as you expect, but it'll help too. |
10-19-2017, 09:21 PM | #17 |
Mike: Everyone's Pal
2044
Rep 2,972
Drives: F80 M3
honestly thats a good time and all but my 320i with stock run flats(75% tread) runs this time..
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
10-20-2017, 02:22 AM | #18 | |
Rep 255
10-20-2017, 11:15 AM | #19 | |
Rep 243
If he's really searching for 1/4 mile times then those brakes need to go as well. He'd probably save 50 lbs just dropping down to base calipers, then another 20-30lbs dropping down to base size rotors. This doesn't even factor in the lower moment of inertia on the smaller rotors.. Edit: I'm guessing he'll find much better drag tires with smaller wheels as well. Proper drag tires will help his time more than any weight savings. |
kern4174446.50 |
10-20-2017, 12:41 PM | #20 | |
Rep 12
10-20-2017, 12:43 PM | #21 | |
Rep 12
10-20-2017, 12:50 PM | #22 | |
Rep 17
f30 0-60mph, n55 |
