01-26-2022, 05:56 AM | #23 |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
Do you happen to know any of the T/S specs and frequency response for the OEM H/K underseat woofers? As expected, they are not easily available based on my searches. Based on what I have learned from my research, specs like Fs, sensitivity, and even a frequency response plot, can help me better estimate what cutoff frequencies are optimal for me to band pass the stock woofers to maximize performance and prevent distortion.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
01-26-2022, 12:06 PM | #24 |
Rep 16,091
I've only been able to measure my Hi-Fi woofers.
Fs 51 Hz Qes 1.00 Qms 3.02 Qts 0.75 Vas 18.4L Re 2.4 Ohms Le 0.22 mH Sd 200 sq cm xMax 6 mm Impedance aside I doubt that the H-K are significantly different. I doubt you'd have any distortion issues with even a 60Hz high pass on them. Mine don't reach 10% THD at full tilt and they're not high passed. |
jmciver1837.00 |
02-16-2022, 06:28 AM | #25 |
///M SubDriver
1837
Rep 2,784
Quick update on this project…
The 10DSP, MOST interface and H/K harness came in. Hard to believe this much power and capability comes in such a small package. While on the bench (aka my dinning room table ), I powered it up and connected my laptop to take a peek and load up my initial tune files. I actually purchased a demo model that was previously installed in a 630i w/H/K so it already had a tune file installed (EQ'ed with an RTA and everything) so I am curious to hear how that sounds once everything is hooked up. After much searching and back and forth, I finally decided on set of underseat woofers I want to use. I chose the Audison APBMW S8-2. I looked at A LOT of different brands (and even considered using the stock ones), many (but not all) provided the full specs for me to look at. Of the ones that did provide the specs, I liked these the best because of their 2 ohm impedance (allows for max power from the amp, even if I don't use it all), had a higher frequency range of 45-500 Hz (they will be band passed higher than stock woofers since I am using a trunk sub), and they had a high sensitivity spec of 91 dB. Not the cheapest underseat option (nor most expensive), but I am confident they will work well with my setup. Still gathering a few other parts/components before I start the install. But more importantly, I am waiting for the temps to come up a bit. Plastic clips and trim pieces (and my hands) don't do too well working in a very cold garage when it is still sub freezing outside )
02-16-2022, 10:53 AM | #26 |
Rep 1,502
Drives: F36 435xd
Hi there
Forgive my ignorance, but how much plug-and-play is this? You just unplug the OEM amp and plugs in this kit? To MOST connection and to speaker connections? And then tune the setup with your laptop? I have done conversions before with Mosconi Gladden components in my old E91, so im not new to this. That was kinda done like that. Is it done the same kinda way?
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
02-16-2022, 12:24 PM | #27 | |
///M SubDriver
1837
Rep 2,784
The big plug you see plugs into the factory harness to connect the 10DSP to the speakers in the car via the factory wiring. Disconnect the factory MOST plug from the factory amp and then plug it into the SDMI25 MOST adapter (then connect the MOST adapter to the 10DSP with an optical cable). You will need to run power/ground for the amp to the battery since larger gauge wire is needed to power the amp. Search for the Bavsound Revanent Pro amp install video (they install it in a H/K equipped F80 M3). That is essentially the same install process you would do for the UP10DSP. Also, if you want to make your own H/K harness, Technicpnp.com sells a BMW harness kit to create your own H/K plug-n-play harness using the supplied harness that comes with the UP10DSP.
anielsen71558.50 |
02-16-2022, 12:27 PM | #28 | ||
Rep 1,502
Drives: F36 435xd
Could be one of the next upgrades in my F36 😊
Brgds
02-21-2022, 10:37 AM | #29 |
///M SubDriver
1837
Rep 2,784
Another quick update…
The Audison underseat woofers came in. Best price I could find for the pair, including shipping, was from an overseas company. Not unexpectedly, they definitely look “beefier” than the stock H/K woofers (but I am no audio/speaker engineer either ). The pics below are the Audison’s compared to the stock woofers previously removed from my H/K equipped X7 following a Bavsound speaker upgrade I did approx 8 months ago. However, based on my research, the H/K woofers in the F-series cars appear to be essentially the same as those found in the G-series cars. The true test, of course, will be how they sound with the rest of the system in the car - and I am confident they will sound good (and better than the stock ones). Spring has not quite “sprung” yet here in the northeast, but average temps are starting to rise finally so hopefully it will be warm enough soon for me to get to work installing this stuff …..
02-21-2022, 12:03 PM | #30 |
Rep 16,091
The Audison woofers aren't any better than the H-K, although they will go louder with the same volume control setting due to their 2 ohm impedance versus the 8 ohm H-K. That's fine if you're using an aftermarket amp that has 2 ohm load capability. Used with the stock H-K amp it would probably overheat.
02-21-2022, 12:24 PM | #31 | |
///M SubDriver
1837
Rep 2,784
At least, that is the method to my madness…
02-21-2022, 03:09 PM | #32 |
Rep 16,091
I doubt that the Audison go higher than stock, nothing in the specs indicate that, and you don't want to venture far into the directionally locatable frequencies with the woofers anyway. But you're right in not getting a woofers that go lower than stock, as that results in lowered broadband sensitivity, and when you've got a trunk sub anyway there's no upside to using underseats like the Earthquakes.
As for the claimed 91dB sensitivity of the Audisons, it's actually 85dB at 1 watt. It would be 91dB at 2.83 volts, but that's 1 watt into 8 ohms, not 2 ohms. In the business we call that a marketing department writing a check that the engineering department can't cash. Still, with the same applied voltage the Audisons will go audibly louder than stock. |
02-21-2022, 05:02 PM | #33 | |
///M SubDriver
1837
Rep 2,784
I am looking forward to playing with the tuning…
02-21-2022, 05:20 PM | #34 |
Rep 16,091
Beaming only occurs above where the cone diameter is a wavelength. Most eights have a cone diameter of around six inches, which is one wavelength at 2200Hz, and even there it's not really beaming, it just has no more than a 180 degree dispersion pattern. I run tens and twelves to 2kHz without a problem. You can have midrange response roll-off from an eight, but only those with very low Fs and a commensurate high Mms. You'd see that in some subs with Fs lower than 35Hz, like the Dayton Ultimax 8, but even that runs OK to 1kHz.
02-24-2022, 07:24 PM | #35 |
Rep 611
03-09-2022, 11:36 AM | #36 |
///M SubDriver
1837
Rep 2,784
Ok, quick update so people don't think I abandoned this project . It is still pretty cold here in New England, as Spring can't come soon enough. But there have finally been some warm enough days I could work in the garage without seeing my breath while working… .
I added some sound deadening material to the trunk. Both to help with road noise a bit and also to help the trunk sub perform better and limit some vibration/resonance. I also specifically added sound deadening material to the driver side area of the trunk as that is where I will put the trunk sub now (previously I was going to put it on the other side). As far as the Match UP10, I have made some progress getting the amp rack done, but still need to work on the cable routing/management a bit before final install as the space is tighter than I originally thought. That said, for anyone else installing this amp, what I am doing is not required - I just want to have a more "tidy" install . Also, one other feature of the UP10 that I am looking to incorporate is to have my V1 radar detector interface directly with the amp, that way any V1 alerts will come through the car's speakers instead of from a remote speaker I have installed behind my dash. With the DSP functions, I can even pick which speakers I want the V1 alerts to come from (like only the front driver speakers for example). So still more to come but hopefully I will have music coming from the amp this weekend and possibly even start playing around with tuning a bit….
J555568.50 |
03-09-2022, 01:28 PM | #37 | |
Rep 5,394
If you would like to gather information on the HK subs I could easily ship you mine to test. I'll pay the return shipping too to contribute to the knowledge base. I can probably send you an HK midrange and a tweeter at the same time too. Please let me know. John |
03-09-2022, 03:00 PM | #38 |
Rep 16,091
I thought I already agreed to that in a PM, like a year ago. I'd post the measured specs and frequency response charts so anyone can compare them to aftermarkets, although finding them for most aftermarkets is like playing 'Where's Waldo'.
03-16-2022, 07:26 PM | #40 | |
Rep 46
03-16-2022, 08:05 PM | #41 | |
///M SubDriver
1837
Rep 2,784
03-17-2022, 03:09 AM | #42 |
Rep 4
If you don't mind me asking, where did you purchase your Match / Helix gear online? There does not seem to be a whole host of retailers with an online presence. Looking to pick up the same set-up and have been struggling to find a source.
thx |
03-17-2022, 05:51 AM | #43 |
///M SubDriver
1837
Rep 2,784
I had similar issues as well and after several negative search results, including using the "find dealer" feature on the Audiotec site, I found a vendor in the UK, via eBay. Search "allwoodsaudio" and they even offer remote tech support as well (which I have not needed to use yet, but may in the near future).
03-17-2022, 06:44 AM | #44 |
///M SubDriver
1837
Rep 2,784
So for those of you wondering about the amp rack part of this project, I chose this route (as opposed to using Velcro and/or double sided tape) because I wanted some additional install flexibility. After watching a lot of YouTube videos by car stereo shops/influencers, I decided to give it a shot. This is my first time with this type of project.
Unlike the UP7BMW amp by Audiotec, the UP10 does not have the OEM mounting bracket on the back of the amp that mounts to the factory amp bracket. I purchased a cheap, used BMW HiFi amp off eBay from a F25 X3 to serve as a donor for the mounting bracket. I attached the slightly cut/modified bracket to the back of a cellular PVC board purchased from Home Depot (pic below). I mounted the amp, MOST interface, and power distribution blocks to the cellular PVC board using screws and screw inserts to make removal of components easier if necessary - and I needed to remove/install components on the PVC board several times as I figured things out. The power distribution blocks, one for power and the other for ground, were used so that I could easily get power to the separate amp for the subwoofer that is coming. While moving slower than I would like, it has been a fun DIY project so far .
