01-19-2018, 02:36 AM | #1 |
Rep 31
Some Dinan tune questions...
Hi guys,
Tax season is upon us and I'm already planning how I am going to spend it and I was thinking about getting a Dinan Tune Stage 3. My car is currently stock so I am gonna run it with the stage 1 map and change it as I pick up parts. However I'm still on the fence between Dinan stage 3 and a JB4. The reason I'm interested more in the Stage 3 is because I can retain my cat and pass smog ( I live in CA) without having to revert anything back but I wanted to know how does Stage 3 compare to Map 2? (Drivability wise) Also does the Dinan tune 1 require an aftermarket charge pipe? I feel like it should. |
01-19-2018, 03:39 AM | #2 |
Rep 804
as per dinan for stage 3"Dinan Intercooler for the BMW F30 335i is required. Dinan cold air intake for the BMW 335i is highly reccommended. Dinan Free Flow Stainless Exhaust for the BMW F30 335i is recommended."
i would add charge pipe is required because they will fail I live in CA and have jb4.it takes less than 15min to install/unistall and its stealthy oem look dinan stage 3 $2600 vs jb4 new $550/ used $300 or get boostmod $350 which i hear is #1 popular now save that $2k and upgrade your weak components you say that you will pick up parts as you go but dont change the cat you will still fail smog test for visual inspection. there is no carb for intake or charge pipes. its not hard to install them. i once thought that but after attempting to do it myself i feel confident if i need to reinstall my oem for smog one day i can do it again. good luck Last edited by bmwchue; 01-19-2018 at 03:46 AM.. |
01-19-2018, 08:06 AM | #3 |
Rep 775
Because you're in CA that's a tough one per se. First, yes change the stock CP because it could blow and so may as well do it as you're adding power (strains the stock CP). As for JB versus Dinan, your call as want to avoid ye ol' can-o-worms about the law versus what is possible versus...
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
01-19-2018, 08:33 AM | #4 |
Sedan Driver
389
Rep 1,018
I recall some kind of trade up from stage 1 to stage 3 but better to contact Dinan sales to confirm this.
Also, you didn't mention warranty but most buying dinan assume it. It only covers what's left of the new car warranty if you're the first buyer. If you're CPO or out of warranty, it only covers the dinan parts and not your BMW. I would highly recommend a CP for the 335i in general but it's possible the dinan parts don't crack the CP more or less as much as stock boost.
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug Last edited by anotheran; 01-19-2018 at 11:26 AM.. Reason: deleted some possibly wrong information. rather not circulate wrong info |
01-19-2018, 08:45 AM | #5 | |
Rep 31
Easy To Use Dinan's ECU is Bluetooth® Smart meaning that you can change maps simply via a Bluetooth connection on your iPhone or Android device. Just install and you are done! |
01-19-2018, 08:56 AM | #6 | |
Sedan Driver
389
Rep 1,018
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
01-19-2018, 10:48 AM | #7 |
Rep 4,329
the stock cat is a bottleneck and going "big" (i.e.stage lll) in front of a stock cat doesn't make sense to me. since you have to keep the stock cat, i think a more modest approach is more preferable.
While Dinan is good stuff, as anotheran said, it costs a lot more because of the warranty that is offered if you did the upgrade during the original vehicle warranty. if you buy it near or after the original BMW warranty is expired, imo, it is vastly overpriced and you can achieve same results in other ways. since your stock cat must remain, i'd just go typical bolt-ons such as FMIC, charge pipe(s), exhaust, maybe intake** and a flash tune based on your mods or JB4(for removability) *do NOT get short ram=hot air, open filter, "just for sound" type *Do get closed box, non metal construction(plastic,carbon fiber, etc.) |
01-19-2018, 12:34 PM | #8 | |
Rep 31
01-19-2018, 12:36 PM | #9 | |
Rep 31
01-19-2018, 12:47 PM | #10 |
Rep 804
01-19-2018, 01:14 PM | #11 | |
Rep 4,329
from a performance standpoint, flashing is is way better than a piggy-back but you have to be very informed about it all. if this is too complicated for you then JB4 is a great and easier alternative i suggest you look through the N55 engine mod sub forums and post more questions there. http://f30.bimmerpost.com/forums/forumdisplay.php?f=421 Last edited by alohasurftoad; 01-19-2018 at 02:41 PM.. |
enjoythemusic364.00 |
01-19-2018, 06:38 PM | #12 |
Masterchief
362
Rep 1,012
I dont know why anyone would want to waste their money buying dinan... the cost itself is a huge rip off, bmw can still even void your warranty with dinan and you would have to take the claim to dinan
jb4 > dinan all day, performance and cost wise. you can go FBO and jb4 for the same price of a dinan tune you shouldnt even have to worry about smog until 2020 since your car is newer and you will only fail smog if you have a catless dp. a piggyback tune like jb4 will allow you to delete the CEL so many flash tunes coming out now since the dme is cracked... bootmod3, mhd, enzo, vr, AP and more
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
