01-24-2017, 10:09 AM | #1 |
Big Beaver Smile
2101
Rep 3,791
Door pockets
This is the first BMW that I've owned that doesn't have felt flocking on the bottom of the door pockets (why did they even bother to put it on the one side, it serves no purpose at all). Things slide forward when I brake and backwards when I accelerate, it's kind of annoying. It's a big step down from the nice E92 tilt-out flocked ones!
Do you guys line your door pockets with anything to keep stuff from sliding back and forth? And if you do, beside monkey testicles (I figured I'd give myself a snarky answer so you don't have to) what did you use? thanks
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
01-24-2017, 10:25 AM | #3 | |
Big Beaver Smile
2101
Rep 3,791
** I was just in my car and realized that the coupe's pocket is probably not longer than the sedan's. There's a whole lot of unused realestate in that door!
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch Last edited by wrickem; 01-24-2017 at 02:07 PM.. |
01-24-2017, 10:44 AM | #5 |
Big Beaver Smile
2101
Rep 3,791
That's what I was thinking too, but didn't know if it would look bad or melt into the pocket making a mess, so I thought I'd check out if any other options were out there. Thank you!
01-24-2017, 12:24 PM | #7 |
Rep 14,107
Drives: G82 M4C X-Drive
I don't put anything in there but an insulated water bottle or an umbrella and they don't move around at all. Knick-knacks go in the trunk, glove box, or middle compartment where they can't move. Sunglasses and reading glasses go in the small compartment under the steering wheel on the left side.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-24-2017, 01:37 PM | #8 |
Rep 4,872
Weird, never thought about it. I've never had a vehicle with anything in the pockets before. My E90 sedan didn't have anything but plastic at the bottom (I don't think it did!)
I just put my sunglass case in there, and it's wide enough that it doesn't move, so a non-issue for me. |
01-24-2017, 01:48 PM | #9 |
Rep 4,440
Drives: '23 X1 28i xDrive
wrickem2101.00 stopbeingabozo9.00 |
01-24-2017, 02:14 PM | #10 | |
Big Beaver Smile
2101
Rep 3,791
Yeah, it sucks, at 40 my "reading-eyes" just went but I can still see far perfectly. I am looking forward to bifocal years when they are always on my face instead of on and off.
01-24-2017, 02:18 PM | #11 |
Big Beaver Smile
2101
Rep 3,791
I just looked at Presto felt and so far, it is my top pick since I am used to felt being in there. I am still trying to figure out why they lined the one panel that you can't see with felt flocking. thank you
01-24-2017, 02:21 PM | #12 | |
Rep 1,615
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
wrickem2101.00 |
01-24-2017, 04:07 PM | #13 |
Rep 68
I keep a flashlight and a pair of gloves. The light is a good people beater and the gloves keeps it wedged in there so it doesn't slide around.
01-25-2017, 01:09 AM | #14 |
Just Copacetic!
177
Rep 616
I wondered this too, then figured it was to reduce any knocking, tapping sounds from articles hitting the insides of the plastic panel. Also, notice that there's felt on the seat belt buckles next to the center armrest console. My 2003 E46 doesn't have felt either in the pocket area or the seat belt buckle so there's knocking sounds from those areas. Will have to look for the Presto felt you mention.
wrickem2101.00 |
01-25-2017, 04:13 AM | #15 | |
Driver
465
Rep 1,002
wrickem2101.00 |
01-25-2017, 07:00 AM | #16 | |
Big Beaver Smile
2101
Rep 3,791
And that felt on the seat belt buckles makes a BIG difference in knocking. Mine peeled off of my 911 in the heat and what a racket it made until I glued it back on!
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch Last edited by wrickem; 01-25-2017 at 12:02 PM.. |
01-25-2017, 11:16 AM | #17 |
Rep 31
Drives: 428I 2015
01-25-2017, 12:52 PM | #18 |
Rep 310
I only keep water bottles there and that's what the design implies. Not too sure what you are stuffing in there that's moving around. Other things such as sunglasses I keep in the tiny storage compartment to the left of my steering wheel.
Everything else goes in the trunk.
AWE Cat Back | BBS - LM | CF M Mirror Caps | CF M Trunk Spoiler | CF R-Style Rear Diffuser | ER Charge Pipe | ER Down Pipe | ER Front Mount Intercooler | Enzo Tuned | Injen SR Intake | M Front Grill |
jmg18658.50 |
01-26-2017, 08:18 AM | #20 | |
Rep 932
01-26-2017, 09:34 AM | #21 |
Rep 145
Drives: 2023 M5 Competition
I have an E92 coupe with the tilt-out door pockets. It's a nice feature that seems like a small thing, but gives an upgrade feel to the interior and makes it easier to get things into and out of the pocket.
It's disappointing that this feature was discontinued; it couldn't be very expensive to include. For the extra few dollars per car (if that), it contributes more to the quality of the experience. |
01-26-2017, 10:35 AM | #22 | |
Driver
465
Rep 1,002
When costing up a car to manufacture, this feature would certainly have saved a few $$$ which sadly is more than enough to warrant a downgrade if they're building a car to a certain price point. Imagine all the areas where they saved a few $$ here and a few $$ there, it all adds up to hundreds of $$... |
