BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CAN message error in 6WB
      04-25-2022, 12:52 AM   #1
Vortex8
Drives: BMW GT 328xi
Hello all,
I'd like to ask you if any of you have ever seen a rather strange DTC:
B7F68C - Instrument Panel: Selector level indication, shift point indicator, CAN messages faulty.
ISTA fault description: The graphics board in the KOMBI detected erroneous message from the transmission control unit or engine control unit.
Background of how thigs are in my car:
Car is pre-LCI, with retrofitted 6WB and NBT EVO. All is coded to the VIN (no emulators in the way). Zeitkriterium is moved to 2017/11. Just to point out that everything works as expected, I see the gear indicator in the cluster and all.
In ISTA it always shows that fault is not present, but when I try to clear it it always comes back. As I mentioned, all works well, it's just annoying me that I always see it in ISTA.
I was thinking of flashing the transmission unit to newer i-step level, but I'm not sure if it is a good idea with different zeitkriterium, etc.
Any advice would be much appreciated.
      09-27-2023, 07:13 AM   #2
Mbradac
Drives: Bmw f15
Hi,
Did you ever get some info regarding B7F68C error?
Regards,
      04-22-2024, 05:29 AM   #3
Vortex8
Hi, nope. But I have a suspicion that this error is triggered by transmission ECU going off too soon or something similar...
Everything works from functional perspective, and as mentioned I just see it in ISTA all the time, so I guess I will leave it like that. Maybe I will update Transmission SW to later PsZD, and see if it improves...
      05-01-2024, 11:31 AM   #4
JuniorTech
Drives: F30 340i Msport & G05 X5 40i
Dont change zeiketrum, then edit FA original + 6WB.
Code HU and Cluster
F30 : Bowers Wilkins, ID6 Touch, RSE , 3AG, 6WB, 508, 322
G05 : 5AU, 2VW, 2VH, 5DN, 6F1, 610, 7M9, 3AK
      05-01-2024, 02:14 PM   #5
Siki78
Siki78's Avatar
139
Drives: F30,G30
Code HU and Cluster
So stupid answer. Update your car to higher I level
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
