06-18-2018, 01:28 AM | #1 |
Rep 10
Engine oil Sensor not working
My Oil level sensor, was not working, So as a first step i replaced it with new got the sensor function reset from mechanic at that time still it is not showing engine oil service due but at the same time it is not measuring the engine oil then after running my car for few hundred kms it again started showing engine oil service fault , then i checked my wiring the wiring was OK. Went for all the resets May be its a DME problem as i have a repaired DME and after its repair this prblm start occuring plz reply with solution Don't know how to get it fixed.
Shehneil
06-18-2018, 05:49 PM | #2 |
Rep 307
I recently had issue with my oil sensor where my oil change duration dropped from 6000 to 600. Oil level indicator was showing as Inactive.
Took it to dealer and they said some rodent chewed the wire and they replaced it. $400 to get it fixed
2014 BMW 335i - M-Sports, 19inch 403 Wheels, M-Sports Brakes, Tech pkg, Prem pkg, HK, SunShades, Auto, Driver Assist...
