06-04-2021, 12:38 PM | #1 |
Rep 899
Drives: F32 428i Xdrive
Hey y'all,
So yesterday I had taken off that bmw warranty sticker in the top left since it was a little annoying and came to my car to clean up the residue today, and came across a decently sized crack What's worse is that it's not on the outside but in. I can't feel it from the outside but can from the inside but I have no idea what caused it. My girlfriend thinks it could be the heat/cold temperature changes as my car sits outside but I'm just surprised if that's the case it didn't happen before Has anyone else experienced this? What did you say to insurance? Edit: I just realized it wasn't yesterday I took the sticker off but it definitely was not because I took the sticker off if thats even remotely a consideration XD
06-04-2021, 12:57 PM | #2 |
Rep 4,878
Never seen that, but having it inside, exactly where you had the sticker that you pulled off sort of points the smoking gun to you removing the sticker.
06-04-2021, 01:13 PM | #3 | |
Rep 899
And I drove yesterday with no crack
06-04-2021, 01:34 PM | #5 |
Rep 899
I guess one can only hope…
06-04-2021, 01:44 PM | #6 |
Rep 16,091
Since the crack extends to both sides of where the sticker was you should have seen it when the sticker was there. Is that the windshield? If it's a side window it's really odd, as a crack in a side window should cause it to shatter. Looking at the picture I thought it was a scratch going though tint.
06-04-2021, 01:49 PM | #7 | |
Rep 899
Yeah this just happened yesterday as I drove a couple times yesterday with no crack, I definitely would have seen it as it's in the upper portion of my vision I don't think it's just the tint? As far as I can tell when I run my fingernail across it I can feel it but it doesn't feel deep, but I'm not an expert on that so I could be wrong there too
06-04-2021, 01:55 PM | #8 |
Rep 562
Drives: 2017 BMW 330i xDrive
To me, it looks like the crack started at the top right and spread down to the bottom left. Very odd for it to have come from the inside. Extreme frame flexion can crack glass, but I'm pretty sure you'd know if that were the case.
The only other thing I can think of is that the sticker was covering a defect in the glass and sort of dampening road vibrations, and removing the sticker made the defect split. But I don't see any evidence of that and it would be very unlikely, anyway. You didn't make your girlfriend mad recently by chance, did you?
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
Billfitz8246.00 |
06-04-2021, 02:25 PM | #9 |
Rep 259
Maybe if there is a problem with the outside windshield gasket/seal, pulling on the sticker flexed and cracked the glass? Weird.
Regardless, make sure you clean off that adhesive residue *before* the adjuster sees it ;-)
Garage:
2020 F32 440i 6MT 2018 Mazda 3 6MT 2013 Mazda 3 6MT 2008 Honda Oddyssey |
Wires1645.50 |
06-04-2021, 02:29 PM | #10 |
Rep 517
Extreme heat can definitely blow out a window. Usually it's a side or rear window though and also usually need to have tint for the heat to be trapped inside. With the windshield though I doubt it would be heat/pressure causing that since the front window is multi layered and reinforced.
06-04-2021, 03:24 PM | #11 | |
Rep 899
auburnf30x434.50 |
06-04-2021, 03:48 PM | #13 | |
Rep 899
06-07-2021, 04:01 PM | #14 |
Rep 899
Quick update for anyone who may have this problem, it seems the issue is most likely a stress crack due to temperature.
While I haven't had any confirmations yet, I'm in the process of communicating with safelite and progressive to figure out what to do There's no damage around the crack but knowing Texas, anything can happen and a sudden temperature or pressure shift could definitely cause this, especially with the recent storms we've had, going from 90 to 60/70's with storms seems like a probable cause Will update again hopefully later this week with good news Update: appointment is scheduled, none for the next month basically, but we're scheduled for July 2nd. To limit my over caring nature for my car and any risk of the crack developing further I will try limiting my driving only to groceries, since I don't go out much other than that anyways Thanks for all the advice so far, and let's hope my rates don't go up
06-08-2021, 08:55 AM | #15 | |
Rep 844
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
djacinto373.00 |
06-08-2021, 08:58 AM | #16 | |
Rep 4,451
Drives: '23 X1 28i xDrive
djacinto373.00 |
06-08-2021, 09:03 AM | #17 | ||
Rep 899
06-08-2021, 09:04 AM | #18 | ||
Rep 899
06-08-2021, 01:17 PM | #19 |
Rep 133
Mine is a little different but I had a decent sized chip in my windshield from a rock that had struck the windshield maybe a year prior. It was at the very bottom and was a very minor chip so I didn't bother having it patched (rookie mistake).
The day my son was born I was dropping off my dogs etc. with the folks before I went to the hospital, probably about 30 degrees outside, car had been outside overnight. I left the car running with the defroster running full blast for about 20 minutes and when I came back, that tiny chip had turned into a massive crack that spanned essentially the entire windshield. Point being, the factory windshield seems prone to cracking in extreme temperature swings, at least when its already been damaged. Very possible you had an extremely minor chip or crack at the VERY TOP of the windshield from some debris damage and a major temperature swing caused it to spread. |
06-08-2021, 02:11 PM | #20 | |
Rep 899
Since the chip was on the outside, I assume the crack was only on the outside as well? Such a crazy situation, I definitely could see that being a cause for me as well, the only trips I usually take long distance are between Austin and Dallas to see the fam, but rarely have I heard something large enough to concern me hitting the window I can only hope they can repair it, I'd much rather not pay another cost after doing all my maintenance a couple weeks ago now lol
06-08-2021, 02:57 PM | #21 | |||
Rep 180
As far as the type of glass - I let Safelite install the generic Fuyao and it's been absolutely fine. I do not have HUD so can not offer any help with that. Definitely make a point to chat up the installer, as the care taken during the install is just as important, if not more so than the brand of glass. I was extremely impressed and have no complaints (very rare for me…) with my F30 replacement. |
djacinto373.00 |
06-08-2021, 03:45 PM | #22 | |
Rep 87
Anyone from a cold climate will tell you that has nothing to do with the factory glass, it's ANY glass. If you have a windshield with a chip on it, get it cold and then blow hot air on it, it cracks, and if it's already cracked the crack will grow. Gotta get the stone chips fixed immediately before a crack starts.
A crack on the inside though? I'm guessing the edge of the windshield was damaged during install or transport and the timing of the crack forming in relation to removing the sticker is just a coincidence. Quote:
djacinto373.00 |
