06-04-2021, 04:37 PM | #1 |
Rep 75
BMW coolant flush
The car is 6 years old now and the dealer in Southern California is charging 190 for the coolant flush. The other maintenance is free and covered by the package. Should I flush the coolant or leave it in the system for the duration of ownership
06-04-2021, 04:42 PM | #2 |
Rep 943
Drives: F30 328i Msport
200$ isnt much, get it done.
undertaker63.50 |
06-04-2021, 06:00 PM | #4 |
Rep 5,089
Try to do a litmus test, if pH is 7 (neutral) or below(alkaline) then it may be worth changing out the coolant.
Local indies charge $150, at times dealers run coolant + brake fluid combo for $250. |
06-04-2021, 07:43 PM | #5 |
Rep 326
I did mine at 8 years. BMW Coolant is recommended to change at least every 4 years according to my service advisor at the dealership. Apparently, it's the interval that BMW has established.
It isn't a difficult DIY, if you can do it in your circumstances. It would only be the coolant and distilled water that you would need to buy, in addition to other basic tools. I would suggest doing it.
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
Wgosma806.00 |
06-04-2021, 10:32 PM | #7 | |
Rep 906
I was going to change it out last December, but ended up deferring it. The PH levels were still normal after 4 years.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
06-04-2021, 10:40 PM | #8 |
Rep 2,806
Drives: F33 430 and F39 M35i
Check your coolant expansion hose and connections while you’re at it.
Mine blew at 2-3 years (60+k miles though) |
06-05-2021, 07:10 AM | #9 |
Rep 259
BMW's "lifetime" fill just means "leave it there until the part fails." If you plan on keeping the car past warranty, I recommend following BMWCCA Mike Miller's "Old School" maintenance schedule which recommends coolant be replaced every two years.
Garage:
2020 F32 440i 6MT 2018 Mazda 3 6MT 2013 Mazda 3 6MT 2008 Honda Oddyssey |
06-05-2021, 08:20 AM | #10 |
Rep 16,088
Replace coolant every two years? That's nuts. We never changed coolant that often even when engine blocks were still made of cast iron that rusted. Coolant is a condition based item. If it's in good condition there's no need to change it. The BMW recommendation is very conservative, in no small part because dealerships charge $200 for $20 of coolant and an hour labor. If it tests good it is good. You've just got to test it, but that should be part of your regular personal maintenance routine anyway.
06-05-2021, 01:14 PM | #12 |
Rep 562
Drives: 2017 BMW 330i xDrive
That’s what I follow. Unless contaminated, I don’t worry about it until the 10 year/100k mark. And even then, it’s not necessarily indicated since the fluid doesn’t really degrade or perform any mechanical function. Mostly just for peace of mind.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
06-05-2021, 03:28 PM | #13 | |
Rep 259
I followed his advice on my E39 and E90 and both made it well past 150k with zero issues wrt to his recommended intervals. The cars certainly had problems but none were fluid or maintenance-based.
Garage:
06-05-2021, 04:15 PM | #14 | |
Rep 16,088
If I went by BMW's time based recommendation for brake fluid flush I'd have done that twice by now. Since I had the hood up anyway I measured the water content of my brake fluid today. It was zero. |
06-06-2021, 12:34 AM | #15 | |
Rep 5,089
The F30 was sold at 8+ years and 80k+ miles, with one coolant change@6 years/60k miles, since the dealer only refreshed 1L of coolant while completing a thermostat recall(and coolant approached pH of 7 at 6-yr mark). |
06-06-2021, 08:34 AM | #17 |
Rep 16,088
Use a pH test strip for acidity, an antifreeze tester for freeze point. The acceptable pH range is 7.5 to 11. You can get a supply of strips and an antifreeze tester for ten to fifteen bucks. Both should last you through at least two cars.
06-06-2021, 03:48 PM | #18 |
Rep 5,089
I have this antifreezer tester bought@Amazon 20 yrs ago that I used on all cars:
https://www.amazon.com/Prestone-AF-1...3012357&sr=8-2 |
BimR245.00 |
06-06-2021, 04:07 PM | #19 |
Rep 1,437
what I love about recommended it's either an average or worst case.
Testing the anti-freeze and brake fluid has saved me a small fortune over years. its not lifetime, but anti-freeze or brake fluid testing has ever resulted in changing every two years. BTW it worth testing immediately after it's changed - sometimes its not done properly ;-) Wish there was an easy way of testing the lifetime transmission oil - usage makes so much difference to service intervals. |
06-07-2021, 02:41 PM | #21 | |
Rep 1,437
06-07-2021, 04:19 PM | #22 |
Rep 5,089
Yeah towing(together with spirited driving and autobahn speeds) can raise operating temperature, which is cited by ZF as main factor to shorten service interval.
