06-05-2021, 11:16 PM | #1 |
Rep 113
Will coding void warranty?
Hello
I've had my f30 car for a few months now, and I've done quite a bit of coding. Since I've had the car, it hasn't yet been to a BMW dealership, but I'm planning on doing that soon. My concern is the coding. I still have several months left on my factory warranty, and I'm worried that they'll notice/find my coding changes and void my warranty. Is this a possibility? If so, will restoring each module back to coding defaults erase all evidence Thanks! |
06-06-2021, 02:50 AM | #3 |
Rep 2,806
Drives: F33 430 and F39 M35i
they don't care about the coding.
if they do an update, it will reset all your coding. i did all my coding then went in for the sos module recall and all my coding was wiped. |
rexmatt19.00 |
06-06-2021, 08:12 AM | #4 |
Rep 16,088
If they do a software update it will not only reset all coded items to factory default, it will also render some items no longer able to be coded. Even if you tell them not to update your software they may do so anyway. Between this issue and the exorbitant prices for service often charged by dealers you should reconsider going to one for anything other than warranty service.
06-06-2021, 09:24 AM | #5 |
Rep 4,660
Depends. There was a PuMA case where a customer had issues with their head unit and navigation and when the they tried to reprogram the car, it would keep throwing faults for it. Case was sent to BMW and they found errors for missing microphone - owner had coded Extended/Enhanced Bluetooth. BMW declined any further troubleshooting and the owner's original issue was not covered.
This is not to scare you or anyone, so depending on what you consider programming/coding, you always have to be careful and cautious because you never know what happens once your car gets connected for diagnostics. |
rexmatt19.00 |
06-06-2021, 01:38 PM | #6 | |
Rep 113
06-06-2021, 02:08 PM | #7 |
Rep 4,660
No because any sort of software update is only performed if there is an issue or fault that is currently present and update will fix it or if BMW found something that needs to be fixed - dealerships don't just update software for the sake of it and/or because there is a new software available.
rexmatt19.00 |
06-06-2021, 03:54 PM | #8 | ||
Rep 906
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
06-06-2021, 08:29 PM | #10 |
Rep 906
Strange. My car has been flashed to F020-20-11-540 and I can FDL and VO code just fine. The locked DMEs are a known problem now with the newer I-Step, but that's generally associated with flashing the DME with a tune. FDL and VO coding are settings changes within the existing software to turn on/off certain features.
rexmatt19.00 |
06-07-2021, 05:19 AM | #11 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Coding a custom number of blinks when you use the turn signal lever, after 2016 it's always 3 blinks no matter what you code. The other feature is for cars that have surround view cameras, in the early models you can store the desired behavior when you put the shift lever into reverse between the backup camera and surround view. After 2016 it defaults to the backup camera when you put it into reverse, no matter what you set it to last. |
rexmatt19.00 |
