11-01-2013, 07:36 PM | #23 |
Rep 230
i tried this and was unsuccessful...it seems they have changed some key/value pairs on the F32...i do not see
Mapping_Nebelschlussl_L_output = nsl_l Mapping_Nebelschlussl_L_Function = nebelschlusslicht Mapping_Nebelschlussl_R_output = nsl_l Mapping_Nebelschlussl_R_Function = nebelschlusslicht The closest i have are MAPPING_NEBELSCHW_L_OUTPUT AND MAPPING_NEBELSCHW_R_OUTPUT i figured i'd give that a shot and change those values from "off" to "nsw_l" but when i coded the fdl it came back with an error...so i tried again but i think the error was pretty severe and i could not read coding data of the CAFD any longer...i had to basically reset FEMBODY to get it to work again which erases any coding you did and resets it back to stock ...but i'm an idiot and thought maybe i did something wrong the first time and i tried again...same thing...so i gave up if anyone has any suggestions please let me know...it would be nice to get this working as i wouldn't mind having some extra light back there when i'm reversing...the current backup lights are way too dim |
11-01-2013, 08:31 PM | #24 | |
Rep 40,662
2) Those 4 codes are in REM (Rear Electronics Module) not FEM_BODY (Front Electronics Module).
LittleSamurai4.50 |
11-01-2013, 08:54 PM | #25 | |
Rep 230
ah yes you are right, i was looking in FEMBODY for those 2...they were indeed in REM...thanks for the millionth time! got it to work although i don't think these are quite as bright as the ones posted earlier...if anyone knows how to increase the backup light brightness, PLEASE let me know! thanks to the OP for the very clear instructions...entire mod took about 30 minutes...the thing that took the most time were smoothening out those tabs that wouldn't allow you to press the button in |
LittleSamurai4.50 |
11-04-2013, 11:38 AM | #27 | |
Rep 230
11-20-2013, 05:05 PM | #28 |
Rep 524
I ordered the ECS switch but the rear fog button does not light up. Does the button light up only after you activate the rear fog function? Just installed it but haven't had time to take the laptop out to the car to program it.
11-20-2013, 08:52 PM | #29 |
Rep 387
No idea, the US spec one does not have an LED.. Let us know after you code it. I would guess not.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
tmdals0213210.50 |
11-21-2013, 12:04 PM | #30 | |
Rep 524
Finally got it to work. I wasn't saving it correctly. Last edited by hsk1610; 11-21-2013 at 12:37 PM.. |
12-27-2013, 01:59 PM | #31 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
Hell yeah!
Awesome DIY! My rear fogs now work so I'm not eventually hassled by control technique here in Belgium! The only small difference, the nsl_r was the value for the right side:
Mapping_Nebelschlussl_R_output = nsl_l >>>>selected nsl_r and worked great! no nsl_l value selectable Again, great job! |
LittleSamurai4.50 |
01-03-2014, 04:38 PM | #32 |
Rep 108
Drives: 2024 i4 xDrive40
Thanks for this write up. It was very helpful to make this modification.
01-04-2014, 07:30 PM | #33 | |
Rep 25
Some research would need to be done to figure out the exact led that is being used by BMW on these PCB's… but you could easily solder one on. |
01-04-2014, 07:31 PM | #34 | |
Rep 25
01-04-2014, 07:34 PM | #35 |
Rep 25
azwillnj… excellent post thus far… I have only been able to complete the physical switch portion as I am still trying to locate where and how to download the e-sys program and the data files. I have read the complete post by svache, however, are any of you guys able to point me in the right direction of actually getting the software itself downloaded.
thanks, |
01-05-2014, 03:11 PM | #36 |
Rep 387
You need to PM shawnsheridan, he will give you the links and hook you up with a key.
01-05-2014, 03:21 PM | #37 | |
Rep 40,662
01-05-2014, 10:20 PM | #38 |
Rep 25
Hate to be that guy... but I have a 2013 F30 and am new to coding but did a bunch tonight. I cannot locate the proper area in the code mentioned above... Any help with that?
01-05-2014, 10:29 PM | #39 |
Rep 40,662
Did you look in REM module instead of FEM_BODY?
01-06-2014, 12:24 AM | #40 |
Rep 25
So I edited the two values as shown in the attached picture, but it ended with an error.
01-06-2014, 12:27 AM | #41 |
Rep 40,662
So you did the left only and not the right?
What is the error?
01-06-2014, 12:31 AM | #43 |
Rep 40,662
This is a coding issue, not an FDL Setting issue. Are you able to successfully code other things?
01-06-2014, 01:10 AM | #44 | |
Rep 40,662
