03-23-2018, 01:41 PM | #1 |
Rep 4,724
Need help finding a rattle
As the Title says: Whenever I have my new 340 in sport mode with the MPPSK under low speed load there is a slight rattle or buzz coming from near the passenger seat. I cannot discern if it is under the seat... In the door.
Anyone ever have a similar issue. It goes to the dealer in about a week to put the summers on, but I have no faith in them finding it.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
03-23-2018, 01:52 PM | #2 |
Rep 718
Check the light underneath the door. Both of mine were loose and creating a rattle that was driving me crazy. I accidentally found the problem when I was drying the bottom of the door after a wash.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) |
Blubaron791433.00 |
03-23-2018, 03:19 PM | #3 |
Two many diffs
43
Rep 120
I have the same rattle on mine with MPPSK.
Some say it may be due to an exhaust heatshield being improperly installed or touching the exhaust for some reason. This seems more likely to me because my rattle is very RPM-dependent. I also had a very similar rattle on my old e46 that did end up being a vibrating heat shield |
03-23-2018, 03:54 PM | #4 | |
Rep 4,724
03-23-2018, 04:06 PM | #5 |
Rep 134
Have you changed your cabin filter recently? The plastic cover can rattle if the right edge doesn't fit back in correctly when reinstalled.
Hoping the LCI cars are better for this, but my F30 has had more interior rattles than any other car I've daily driven (CHMSL cover, seat anchor covers, cabin filter cover panel, pillars and dash... what next??). |
03-23-2018, 05:35 PM | #6 |
Rep 163
This is silly but my '15 seemed like it developed a new rattle every once in a while -- it always turned out to be some crap I kept in the arm rest console.
Sometimes sounds like dash, sometimes passenger seat. Always something bouncing in the arm rest. Remove that and gone. I never learn. |
03-24-2018, 08:15 AM | #7 |
Rep 3,291
I just resolved a multi-month-annoyance rattle from under my passenger seat. It was a wire hanging loose that was supposed to be collected with its friends in a round plastic clip. Put your hand under the seat and and see if you can find a loose-hanging wire, go a bit further back and you'll find the clip. You can get any loose wires back into the clip by feel. Multi-month annoyance resolved in about 2 minutes.
Blubaron791433.00 |
03-24-2018, 06:57 PM | #8 |
Rep 354
Rattle
Picked up my 2018 440i with MPPSK about a month ago. Noticed a rattle that seemed to be under the passengers seat. Couldn't find anything loose. Called my CA, and she said if I could bring it in she could have it looked at immediately. Unreal service. The shop manager took a ride with me and clearly heard it. He put it up on a lift and dropped the exhaust down some himself. Said it tends to happen with some port installed, which mine was. Mounted a little too high and hitting a bolt that protrudes under the passenger seat. Rattle gone.
Previous: E36 M3, E46 M3, 135i, M235i, 440i
03-25-2018, 12:30 PM | #9 | |
Rep 4,724
04-21-2018, 08:40 AM | #10 | |
Rep 8
The dealer had the car for four days and could not resolve the problem. Blubaron79, I sent you a PM with more specifics. |
