09-03-2012, 09:34 PM | #1 |
Rep 537
Drives: 2013 335i M
Help, winter tires 335i M-sport
I have a 2013 335i M-sport in production right now!! (To be completed 09/11/2012). I live in upstate NY state and want a winter tire/wheel set. I ordered the car with the 19" 403m wheels. I would like 18" wheels for the winter.
My question is what is the rubber size for the front and rear. It seems that every day I check Tire Rack, they show a differant size. Is there anybody out there with a 2012 335i that has any helpful imput? Thanks in advance!! |
09-03-2012, 10:11 PM | #2 |
Rep 1,180
winter wheels/tires for 335i M Sport
Since both BMW USA and BMW Canada recommend a 17" set for the F30-335i, that's what I ordered. They also offer an optional 18" set. The 17s will yield a better ride in cold temperatures and the narrower tire treads will track better in snow.
The 17" snow tires, 225/45 x 17 front and rear, recommended are Pirelli Sottozero II RFT mounted on V spoke Style 413 alloys. You could of course purchase a set for much less $$$ @ Tirerack, buy I would not trust my safety to any Chinese-made rims.
09-03-2012, 10:31 PM | #3 |
Rep 1,075
osco1606 - I don't know the answer to this, but if you have the M Sport Brakes, you might want to state that too. Not sure if the clearance for the callipers changes anything....
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT |
09-04-2012, 09:45 PM | #4 |
Rep 710
I had a set of Blizzaks that I bought in 2011 for my 2009 E90 335i. I checked with Tire Rack to see if they would fit on the new F30 I just got and Tire Rack confirmed they will. No, they're not BMW wheels, but then I don't plan on being in the snow with my car....any car....in more than an inch or two of snow.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi |
09-04-2012, 11:39 PM | #5 | |
Rep 537
Drives: 2013 335i M
M5 with lots of goodies
09-05-2012, 07:54 AM | #6 |
Rep 516
I'm going with a 18x8 square setup all around. 225/40/18 tires. Had the same on my 2 RWD E90s and my brother's xDrive E90. On the xDrive E90 it was like a snow mobile with this setup.
Retired: 99' E46 323i AW / 06' E90 330i SG / 09' LCI E90 335i MB / 13' F30 335i EBII
15' F30 / 328i / Msport /// xDrive / Mineral Grey / Oyster / Anthracite Driving: No BMW right now |
09-05-2012, 07:56 AM | #7 |
Rep 516
17s would fit. I believe if you have the upgraded brake kit the minimum is 18s. for "gap" purposes and aesthetics of the m sport go with 18s at least!
09-05-2012, 08:55 AM | #8 |
Rep 3,331
Black wheels make the illusion of 17's look less important since you can't see them.
Also I wouldn't have any qualms with any of the rims on Tire rack. For one, if you go with 17's you're going to have a LOT of side wall, and if you want to spend more money on a quality set of BBS's you can, but why buy nice wheels only to have them pitted to death with salt? Cheap set of black rims, and if you bend one you're out $120 instead of $400 for an OEM rim.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
09-05-2012, 09:27 AM | #9 |
Rep 802
Going w/ OEM M-Sport Staggered setup for my winters.
225/19 front, 255/19 rear ... performance difference is almost not existent. Asthetics of my car in the winter is equally as important to me as safety is. Pricey setup though. A set of Bridgstone Blizzack LM-60s are running me about $1,600.
09-05-2012, 10:53 AM | #10 | |
BMW 4 Life...
148
Rep 3,360
$1600 just for the tires? What about the rims?
09-05-2012, 11:50 AM | #11 |
Rep 821
Looks like the only winter run flats offered so far are the Pirelli's @ $239.00/each. Would be nice to have a choice. Any other run flats out there in 225/45/18?
09-05-2012, 11:56 AM | #12 | |
Rep 821
Dude.. that's not a good idea... 19" 255's for winter will be bat-shit retarded.. I get the aesthetic appeal, but trust me.. go 225 square... |
09-05-2012, 12:16 PM | #13 |
Rep 516
Agreed.
09-05-2012, 12:20 PM | #14 | |
Rep 802
For the winters we get in Toronto, it will make almost no difference. 3 cm wider tire at the rear makes very little difference in the grand scheme of physics (i.e. braking distance). Re: Rims. Ordered a set of ZCP Competition Replica's (M3 Competition Replica). Cost was $750 for a staggered set of 19s (8.5F, 9.5R) + $150 for shipping + $100 taxes = $1K. Might end up using these rims for my summer setup (as I think I will prefer the offset on these + looks better than the OEM stocks). ET+ 35F, ET+38R. Once I mount my winters and see how it looks on my car in teh winter, I may remount my summers on the ZCPs and use the OEM M Sport rims for my winter setup. Time will tell.
09-05-2012, 12:27 PM | #15 |
Rep 802
Guys ... Many suggest a square setup, not because of the winter performance (as everyone says slimmer is better), but because you can rotate them + narrower tires cost less.
It doesn't actually make much a difference in driving performance (as much as you want to convince yourself that it does)... it really doesnt. Benefit of a higher profile tire (i.e. larger sidewall) means you will get more "flex" out of the tire which is important in cold weather, but again, one inch makes little difference (i.e. 18" vs. 19"). Same hold trues to going slightly wider in the rear. Yes, less physical contact w/ the snow reduces slippage (i.e. less surface area), but when you calculate how much of the tire actually makes contact w/ the road at any given point, you're talking about an increase of 3 square cm's. I would put my money on it that if you calculated braking distance between a 225 square setup vs. a 225+255 staggered setup w/ the exact same winter tire, the results would be almost identical. To each their won. I've done research and have had extensive experience driving rear wheeled cars in teh winter. If the added expense is not an issue, then a staggered setup is totally fine.
09-05-2012, 12:37 PM | #16 |
Rep 802
And in case anyone is interested in the price difference:
18" vs. 19" rims - would have saved $100 had I gone w/ an 18" version Tires - would have been around $1350 for 18" staggered setup - would have saved about $250. Had I gone 225 all the way around, I think price would have been reduced by another $100. All in - going 19" staggered vs. 18" 225 square is approx $450 more expensive for same rim style/tire type.
09-05-2012, 12:39 PM | #17 | |
BMW 4 Life...
148
Rep 3,360
I'm sticking with a square setup as I had a bad experience in snow once and dont want to repeat it. Bananachipz, What are you going to do this winter? Getting new tires or using a "winter-beater"...
09-05-2012, 12:44 PM | #18 | |
Rep 802
Not trying to down play other's opinion's - but one person claiming that it would be "retarded" to drive w/ 19s + 255 w/ absolutely no support and subsequently gain such followership on here makes me seriously question how much knowledge people actually have on here. Opinion vs. fact - two very different things. I guess I'll keep my "facts" to myself.
09-05-2012, 12:48 PM | #19 | |
BMW 4 Life...
148
Rep 3,360
Dont worry about it man. You go ahead with the 19" staggered setup. I read your detailed explanation and clearly there's no difference in the setup you're talking about. However for MY PERSONAL comfort, I'm going to stick with 18". Yes, my car's not gonna look as good as your's with the good looking 19" but I want to keep my mind happy and go with what I want. Good luck bud!
09-05-2012, 12:50 PM | #20 | |
Rep 802
09-05-2012, 01:07 PM | #21 |
Rep 802
In case anyone's interested to check (as a reference point)...
Audi' S4 (via headoffice) suggests the following winter tire setup: 245/40/18 square setup. http://www.audiusa.com/us/brand/en/o...l_offers.html# So going 255 doesn't seem to be that "retarded" afterall (again, tire "width" is the question here). Staggered setup means nothing other than not being able to rotate your tires + cost. Yes, 19 will reduce tire "flex", but marginally so. And before someone says ... "the audi is all wheel drive", all wheel drive does nothing for braking. That's ultimately what is the concern here. Sorry for the ongoing responses here ... but so many times, people are led down the wrong path by one post here or there.
09-05-2012, 01:48 PM | #22 | |
Rep 821
If anything, and winter is what it was last year - nonexistent - then we'll all be good |
