      01-26-2013, 05:05 AM   #2267
demge01
demge01's Avatar
Drives: F30 320ed
Originally Posted by shawnsheridan
Originally Posted by bmw328jc View Post
thats is good news!! hopefully i dont run into any bullshit like some others have.
I had a guy this morning contact me with 48.2 PSdZData, and he could not connect to his F30, so I am not sure if 48.2 is also affected or not. He is downloading 48.1 (slowly) and will let me know if that is his problem, or if it turns our to be unrelated and due to something else.
The safe bet though is if your car is at I-Step <= F020-12-11-502 (ISTA/P 2.48.1), you can use 48.1 PSdZData.
Anything newer than that, buy the damn updated patch / token. It's reasonably priced...about the cost of two F30 tanks of gas, if that.
If only I could get two tanks of fuel for that money over here...!
Two tanks here for me is about £150 or $240...
      01-26-2013, 07:56 AM   #2268
shawnsheridan
shawnsheridan's Avatar
So then, that is an even bigger bargain for you as the cost is only 1/3 of a tank.
      01-26-2013, 08:01 AM   #2269
shawnsheridan
Originally Posted by GaborB View Post
Last week the dealer reprogrammed my car due to power steering issue, which action unfortunately upgraded my integration from F020-12-03-520 to F020-12-11-505. With this obviously I lost all my previos coded values and can't any longer use my old 46.6 data files.
Can I please get a link to the newest ones and maybe an up to date E-sys as well?
Thanks.
PM sent.
      01-26-2013, 09:11 AM   #2270
GaborB
Belgium
Drives: F30 316d
PM sent.
      01-26-2013, 09:23 AM   #2271
cmarucco
Drives: 2013 F30
48.1 please
I DL'd the new 48.3 files, but I'm glad I returned here before trying to code to learn about this new security token.
My vehicle is still on the old I-level reading: F020-12-07-532.
So I believe I should still be able to use the 48.1 PSdZData, correct? If so, Shawn do you have a link for these? TIA.
Also, is there any advantage or additional functionality of the new version, or am I not missing anything assuming I stay out of the dealership and don't get updated.
Thanks all.
      01-26-2013, 09:31 AM   #2272
Gunnersbury
2013 ///M5 Silverstone
Drives: F10 M5 Silverstone
      01-26-2013, 09:32 AM   #2273
nidfix
Drives: M2 Competition
Quick questions about the new token requiered for 48.3.
I understood that it will be proposed "valid for 1 year". Does it mean that every time that code will have to change (may be for example a new release of psdzdata files) will we get access to a new one or that the delivered key last actually one year (regardless of whether you change the psdzdata files, it just expires) but may not later ( before one-year term due to some additional changes on file contents) ?
      01-26-2013, 09:33 AM   #2274
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Quick question to anyone that can answer
What do i do with the new token i bought? I am assuming i need to drop it in some file somewhere but i havent a clue where. file name is XXXXX-esys
Any help is appreciated
      01-26-2013, 09:37 AM   #2275
Gunnersbury
Files
Could someone PM me with the location of 48.3 files. I have a F10 M5 and i understand this is the version I need. i am very new to coding. I have the cable and E-SYS applications. Also will i need to purchase a token for this version.
Thanks for your help.
      01-26-2013, 10:35 AM   #2276
Morrisadam
Drives: BMW Z4 sDrive35i
Hello, I am new here and can someone tell me that the F12 650i has the same coding that the F10 5-series?
And can I use the same ENET cable?
Forexample this one:
http://codecard.lt/electronics/tools.../prod_651.html
      01-26-2013, 10:41 AM   #2277
shawnsheridan
Thanks all.
There is no advantage to updating your vehicle software, except maybe you gain the M Performance Logo Option in KOMBI, which is not in your ISTA/P 2.47.4 that you have now.
I can't PM you, becasue you do not have enough Posts. I think you can PM me your email though or post it here, and I can send you the 48.1 PSdZData Links.
      01-26-2013, 10:45 AM   #2278
shawnsheridan
The Token has nothing to do with the PSdZData version. It will work with E-Sys and any version of PSdZData fo rone year from the Date of issue, and then it simply expires, and you buy an new one.
      01-26-2013, 10:50 AM   #2279
shawnsheridan
You can put it wherever you want, but you need to go into E-Sys Options => Settings = EST Tab, and set the path to wherever you put it (e.g. C:\ESysData\EST\3.22.5\E-Sys_3.22.5_EST.est).
You also need to replace the two patched .jar files in:
C:\EC-Apps\ESG\E-Sys\lib\PsdZ\psdz-core.jar
C:\EC-Apps\ESG\E-Sys\lib\estcm\est-cm-01.03.02.jar
      01-26-2013, 10:53 AM   #2280
shawnsheridan
You can not receive PM's as you have too few Post. If you PM or post an email, I will send you the links.
      01-26-2013, 11:01 AM   #2281
shawnsheridan
The F12 and the F10 use the same exact PSdZData, so the coding is essentially the same.
Yes, that cable will work, but it is a 5 meter (16.5 Feet) ENET Cable, which is fine if you want to code your car from your couch.
Here is a shorter 1.8 meter version (6 Feet) for $19 instead of $29.
http://www.one-stop-electronics.com/...&product_id=21
Or, contact User April1 if you prefer a local source rather than shipping from China:
http://www.enetcables.com/
      01-26-2013, 11:06 AM   #2282
nidfix
Thank you for your response !
If there is no relationship at all with PSdZData files , why is it required for people that used in the past E-Sys 3.18.4 and simply upgraded their files to 48.3 ?
      01-26-2013, 11:22 AM   #2283
shawnsheridan
Thanks I do not gave enough tokens to PM you. My email is jfdevine@gmail.com. Thanks for your help
Email sent.
      01-26-2013, 11:24 AM   #2284
shawnsheridan
Just to follow up, he got 48.2 PSdZData to connect, so the issue was something else. So, 48.3 on up is the issue.
      01-26-2013, 11:28 AM   #2285
Morrisadam
Thank You very much I just placed my order and the site you mentioned was half the price that I was looking at because the 29 was in EURO. THX again.
      01-26-2013, 11:41 AM   #2286
shawnsheridan
      01-26-2013, 11:45 AM   #2287
shawnsheridan
What I am saying is that typically when new PSdZData comes out, you just update your PSdZData, as we have all done many times over the last year. This will continue as usual, until your Token validity expires. However, if at some future time during your year of validity, BMW changes the security measures, well yes, of course an updated patch / token will be required.
      01-26-2013, 11:57 AM   #2288
GaborB
Belgium
Drives: F30 316d
Or if the old token in the EST folder is not valid any longer with the new 48.3 and beyond, can't we just simply share the same newly generated token amongst us?
