09-08-2015, 11:49 PM | #1 |
Rep 16
Turn signal lamp LED replacement
I have changed turn signal bulbs as follows,
1st trial BAU15S PY21W 1156PY CREE LED Bulbs for front http://www.aliexpress.com/item/2pcs-...444_5,201409_2 BA15S S25 P21W CREE LED Bulbs for rear http://www.aliexpress.com/item/2-x-O...444_5,201409_2 Compare with original bulb 2nd replacement ----- 6pcs 3rows + 3pcs on top total 21pcs For front http://www.aliexpress.com/item/2-X-W...025926808.html For rear http://www.aliexpress.com/item/2PC-A...284446908.html Compare with 1st LED I think this is the best LED bulb for BMW F30 turn signal. Cording change FEM_BODY→FRA_V_(L/R)_KALTUEBERWACHUNG FEM_BODY→FRA_V_(L/R)_WARMTUEBERWACHUNG aktiv → nicht_aktiv FEM_BODY→FRA_V_(L/R)_IS_LED nicht_aktiv → aktiv REM→FRA_H_(L/R)_KALTUEBERWACHUNG REM→FRA_H_(L/R)_WARMTUEBERWACHUNG aktiv → nicht_aktiv REF01(REM)→FRA_H_(L/R)_IS_LED nicht_aktiv → aktiv Last edited by naga9201; 09-09-2015 at 12:01 AM.. |
09-10-2015, 07:55 AM | #4 |
Rep 68
Drives: F31 Sportline
Does this seller has brake and reverse light too?
Thanks! |
09-11-2015, 06:43 PM | #5 |
BMW Fanatic
331
Rep 1,076
Horizon has everything haha
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
01-14-2016, 05:31 PM | #9 | |
Rep 94
01-14-2016, 07:09 PM | #10 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Try coding these in REM:
RFS_L_KALTUEBERWACHNUNG from aktiv to nicht_aktiv RFS_L_WARMUEBERWACHNUNG from aktiv to nicht_aktiv RFS_L_IS_LED to aktiv Same above three, but prefix is RFS_R, rather than RFS_L Hope that helps |
04-12-2016, 12:07 AM | #11 |
Rep 5
05-08-2016, 05:17 PM | #13 |
Rep 808
http://f30.bimmerpost.com/forums/sho...d.php?t=996012
For reverse lights, you can use the PN/coding I have in this thread - it's in there somewhere. |
