BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Code out TPMS
proTUNING Freaks
      01-21-2016, 02:28 AM   #23
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Originally Posted by stu14t
Originally Posted by wibbles View Post
try removing 2VB from the VO and then code the ICM, DSC, NBT and KOMBI
I'll give it a go later on.
I take it you mean remove 2VB from the FA and VO code the ECU's you mention? (Just for clarity)
yes, that is what I mean.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      01-23-2016, 04:20 AM   #24
stu14t
stu14t's Avatar
Scotland
451
Drives: 330i MSport Pro
BOOM!!! Solved
Well done wibbles That was it
So remove 2VB from the FA and VO Code (I did it in the order they appear in Esys but I'm not sure that matters) DSC NBT ICM KOMBI
It still has an issue when you press reset but it sorts itself out and now says RPA Active and all the wheels on the display are green
Many thanks to InTheSound for the US / CAN workaround
How-to sheet added:
File Type: pdf F30 F20 Code Out TPMS back to RPA or RFA.pdf (788.2 KB, 13540 views)
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue
Gone - 2015 F30 LCI 320d M Sport+ Step Auto
Gone - 2012 F30 320 ED
Gone - 2011 E87 118d
Urbz8.00
      01-23-2016, 04:28 AM   #25
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Awesome!
      01-23-2016, 04:36 AM   #26
stu14t
stu14t's Avatar
Scotland
451
You do get some warnings from the ABS and the DSC, while VO coding the DSC, on the dash and screen. Just ignore them. they disappear when you turn the car off and on.
      01-28-2016, 06:06 PM   #27
stu14t
stu14t's Avatar
Scotland
451
Found this using token Masters CAFD tool which shows all modules affected by coding. The following is settings for RDC on :
FEM_01 > RemoteControl 30D0 > RC_RDC_ENABLE = aktiv
ICMQL > Daten 3000 > IcmKod_B_S2VBA = verbaut
DSC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RDCi_l = nicht_aktiv [Default]
DSC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RPA_e = nicht_aktiv
DSC_CT01 > DSC_CODIERDATEN_RPA_CONTI 3002 > C_RPA_Extra = nicht_aktiv
HU_NBT_EVO > EXBOX 3001 > RDC = aktiv
HU_NBT_EVO > EXBOX 3001 > RDC_DRUCK_TEMP = druck
HU_NBT_EVO > EXBOX 3001 > RDC_FORTSCHRITTSANZEIGE = nicht_aktiv [Default]
HU_NBT_EVO > EXBOX 3001 > REIFENUEBERWACHUNG_RDC_RPA = rdc
HU_NBT_EVO > EXBOX 3001 > RPA = nicht_aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_ALIVE = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_TIMEOUT = aktiv
KOMBI L7_MID > FZG_Ausstattung 3003 > DSC_MIT_RPA = ohne_RPA [Default]
      02-02-2016, 08:35 PM   #28
Cloud IX
Drives: Quickest Stock Turbo F8X
Sucessfully disabled TPMS and activated FTM. Thanks again stu14t
Quickest Stock Turbo F8x In The World
      03-22-2016, 03:03 AM   #29
veearrsix
Drives: 02 Porsche Turbo, Polar Silver
Sorry for the slight thread hijack...
I've just taken delivery of an F36 on lease, I've ordered a set of 19" wheels for it and rather than have to deal with the vdo tpms, I'd like to code it out like you have.
I have a few questions:
- Is it easy enough to backup the original settings and revert back to them once my lease ends? (Or when I need to service it)
- I've seen a few mentions of using Mac versions of the software, is it wise to use a Mac or would I be better of using windows?
      03-22-2016, 06:19 AM   #30
stu14t
stu14t's Avatar
Scotland
451
- Is it easy enough to backup the original settings and revert back to them once my lease ends? (Or when I need to service it) - Yes, very easy to save original configuration to reverse the process by adding back to the vehicle order and coding the ECU's
      04-07-2016, 05:00 PM   #31
constantin_md
Drives: 2014 F15 X5 sDrive35i
Hi everyone, can you please advice? i had someone code my f30 2013 328i sedan with cic-high(NBT) navigation 8.8 screen in United States with your pdf instruction and no success. I got some error messages after coding as per instructions which cleared and the time erased. After doing the TPM reset on nav and after 15 miles driving a tpms error pops out (same as before the coding, i don't currently have the right tpms installed)
Is this coding supported for US cars? What might have been gone wrong?
      04-07-2016, 05:53 PM   #32
constantin_md
The guy that coded the car advised to disconnect the RDC/TPMS module. Does anyone know it's location, or maybe a fuse that can be removed for disabling RDC ?
      04-07-2016, 10:58 PM   #33
johnjohn444
Drives: F36
Guys it's really a brilliant work!!! Just wondering my car doesn't come with the TMPS system, can i code it with just BMW TMPS installed? Cause someone just told me that the reciever is already build-in and it's just the matter of coding. If this is not the case, can i install the 433MHz reciever by myself and code it? I already have the sensors in my wheels. Thank you.
      04-07-2016, 11:56 PM   #34
InTheSound
InTheSound's Avatar
Drives: BMW M2 '18
BOOM!!! Solved
How-to sheet added:
I've previously performed FDL Coding for the ECU's. Will this VO Code drop my changes and reset to factory? :
Thanks
      04-08-2016, 04:01 AM   #35
stu14t
stu14t's Avatar
Scotland
451
If you have done any FDL coding on the DSC NBT ICM KOMBI ECU's then this will have to be done AFTER VO coding them.
Essentially, what you are doing is removing TMPS from the vehicle order and re-coding the appropriate ECU's to the factory default.
If you wish, you can FDL using the instructions from a previous post and avoid any changes you have made on the above ECU's (see below) BUT YOU MUST NOTE THE EXISTING SETTINGS SO YOU CAN RESET BACK TO TPMS
      04-08-2016, 04:11 AM   #36
stu14t
stu14t's Avatar
Scotland
451
It's necessary to remove fuse #132 found in the rear fuse box in the boot / trunk for US / CAN cars.
I'm not sure if there are differences between US and EU cars but the coding works on Canadian cars ok. I suggest you check the settings in the post above to make sure you have changed the coding or try doing it again.
      04-08-2016, 04:20 AM   #37
constantin_md
Thank you!
      04-08-2016, 04:26 AM   #38
stu14t
stu14t's Avatar
Scotland
451
Not sure John, you may have to inject a CAFD into the unit. Try adding 2TB to your vehicle order and VO code the ECU's. you never know??
      04-09-2016, 12:57 AM   #39
constantin_md
We searched everywhere with the coder and we couldn't find any RPA values in any modules before or after removing the 2VB in US Cars
I guess only Canadian, European and other countries that have RDC (TPMS) as an option from factory may revert back to RPA (TPM)
For US F30 the only option from factory is RDC (TPMS)
      04-09-2016, 03:16 AM   #40
stu14t
stu14t's Avatar
Scotland
451
Silly Question but did you VO code the ECU's after removing 2VB?
If that's the case it's worth noting for US cars.
      04-09-2016, 03:40 AM   #41
constantin_md
I don't know the terminology but I think the coder did everythink right. i was getting dsc errors and some other errors on the nav screen. But before and after doing it, he couldn't find any rpa values through search bar or manual search in the modules. Thanks again for the list, it was easy to detect the fault.
      04-09-2016, 11:02 AM   #42
InTheSound
InTheSound's Avatar
Drives: BMW M2 '18
Makes sense to me now. So, change VO first by removing 2VB. Then Code FDL all settings listed across ECUs. This method is additive to any other programming changes I've made in the relevant ECUs previously. Alternatively, Code ECUs and redo my other changes.
Thanks for all your help and contribution to the community.
      04-10-2016, 06:03 AM   #43
stu14t
stu14t's Avatar
Scotland
451
You don't really need to alter the vehicle order if you are going to FDL code all the settings. This is only needed if you intend to VO code the ECU's to the default for that vehicle order.
The settings above are default settings if you do have TPMS valves installed. However, you will note that there are some settings that can be changed from RDC to RPA - the flat tyre monitor based on wheel diameter. These are the ones that need changing. Unfortunately, I can't run the tool to show the changes when you remove 2VB from the VO only what it changes when added.
      04-10-2016, 12:33 PM   #44
InTheSound
InTheSound's Avatar
Drives: BMW M2 '18
I decided to code to default and all went as expected, except... RPA reset still hasn't completed (I drove around for about 20-25 min.).
Incidentally I performed a wheel swap prior to the coding and there seems to be a remaining TPMS Reset log in the iDrive Vehicle Info menu. I'm not sure how to clear it. In essence I'm trying an RPA Reset while the TPMS Reset had already been initiated prior to coding. Hard to tell if they would conflict? My previous 1 series would reset RPA within minutes of driving.
Anyone have thoughts on how to clear or cancel all resets so I might isolate?
