12-17-2015, 03:54 AM | #89 | |
Rep 938
Thank you for this! I'm still holding tight until I get more reviews. Ideally with the same set-up as my own. (Base stereo with a BSW S1 upgrade). As soon as I start hearing positive reviews, I'll place my order but I'm very happy with the S1 right now. Made a huge difference to the junk that came standard. |
12-17-2015, 10:26 AM | #90 | |
Rep 241
Drives: 435i, X3M40i, X5
I want to see some reviews comparing them with the other drop-in replacement options. Last edited by 83883; 12-17-2015 at 06:31 PM.. Reason: sp |
12-17-2015, 05:33 PM | #92 |
Rep 4,323
Can we do a GB on this guys??
12-17-2015, 06:48 PM | #93 |
Gettin It Figured Out
1820
Rep 2,669
unlikely...per BavSound, they stated they'd "never" discount again... .
12-18-2015, 12:55 PM | #94 |
Rep 241
EDIT: Update at bottom
----------------------------- 12/18 Initial review (before gaskets) Summary: Noticeably better when cranked up, kind of 'meh' otherwise. Would be happy at a lower price point... but not at $500. I assume it is because of the lower efficiency of the Ghost's, but I have to really crank the volume to hear the benefit (they were run for hours before pushing them). Anything below 75% volume there just isn't enough there to differentiate much from stock. However, when really cranked up, the difference from stock is immediately obvious as they will get louder than stock, go a little deeper, and maybe more musical (<- subjective). Midbass is much better. Fortunately for me, I listen at higher volumes so they will be in the sweet spot a lot. Still wish there was more oomph down low though. I may eventually add a Musicar enclosure and filter out the sub freq's from the Ghost's. For the very high price of these drivers I expect more. Physics are a bitch though and only so much can be done as an easy DIY in that little space and on OEM amp power. I suppose they could still open up a bit more more but they were supposedly pre-broken in, at least partially. I will update if they improve more during the audition/return period. ------------------------------------- 12/19 after installing the missing gaskets Mine must have not been airtight before, because there is noticeably more bottom end and output is increased with doing nothing other than adding the gasket material. Those were my only two gripes before adding the gasket. I guess the airspace is a tiny fraction of a cubic inch more now too. The Ghosts will shake the car with authority, and cleanly, surprising for a shallow 8" driver in a tiny enclosure. My next door neighbor heard the ruckus and came over to see what I had installed, and I was in my garage with the garage door shut. Gotta love that. Very happy camper now. ----------------------- 12/22 A few more enjoyable hours on them now. They are much more controlled than the stock woofers... and the boominess and nasty peaks are gone. ----------------------- 1/5 Installed full Stage 1 kit and added some Dynamat around the drivers in the doors and side panels. Finally it sounds like it should. Greater detail, noticeably better highs, better vocals, better low-mids and much better integration with Ghost woofers, obviously. The Ghosts sound better now too after a few weeks. I don't know why I waited so long to do the upgrade... the stage 1 system will really crank on the OEM HK amp and stays clean at high volume. Very happy with the Ghosts and Stage 1 set. Last edited by 83883; 01-05-2016 at 09:30 PM.. Reason: update |
12-18-2015, 05:02 PM | #97 | |
Rep 335
They're sending some generic weather strip material via Amazon Prime. Or, it's a basic Home Depot item if you don't want to wait for that to arrive... http://www.amazon.com/Frost-King-V25...5%3A2470955011 |
12-18-2015, 05:11 PM | #98 | |
Rep 241
Sounds like with the gasket and more hours we can expect them to improve in overall output, which is exactly what they needed. |
12-18-2015, 08:45 PM | #99 |
44
Rep 208
Micah with Bavsound here. So glad you're starting to enjoy them -- give them a little more time to break in and I think you'll really start to love them.
Also, as we noted in the e-mail, tuning in vehicles with Harman Kardon is relatively important to let your new woofers shine (if you have Standard Hi-Fi this isn't really relevant). Here are those instructions again: Finally, we also want to provide some important information regarding the design, tuning, and performance of your new woofers. When we engineered the woofers for your BMW, as with everything we do, our focus was on maximizing sound quality and usable performance first, and total bass output second. |
12-18-2015, 09:04 PM | #100 | ||
1820
Rep 2,669
Anything to add concerning quote below? Quote:
12-19-2015, 12:27 AM | #101 | |
Rep 1,035
Your last paragraph was what i was suspecting ... that it was going to be an Ok upgrade, but not a $500 worth-it upgrade. The number one reason people jumped all over this was that it was an easy install - a direct drop-in replacement DIY for the OEM underseats, and most people who are leasing don't want to mess with the car - or mess with it as little as possible. If you look at that tiny hole under the seat, there just doesn't seem like there is enough volume of air space to properly locate a real kick-ass woofer there. My $500 is going towards a dual sub trunk set up for sure now. |
12-19-2015, 09:51 AM | #102 |
Rep 241
Thank you. I am certainly not trying to push anybody away but just giving an honest initial opinion. I think Bavsound makes very well engineered, quality products. They do sound much better than stock, especially as you bring up the power, and based on the email and video that early adopters received from Bavsound last night I expect them to only get better.
12-19-2015, 11:26 AM | #103 |
Rep 1
First of all, thanks to everyone on this thread and others; the forum's been a huge help in upgrading the sound in my new (to me) 328d.
I just installed the ghost subwoofers and already love them. They're not broken in yet but they're already a substantial improvement over OEM. I have Stage Ones and the Bimmertech amp upgrade with some tuning using their software, and I added the weatherstripping to the drivers as per the email others mentioned. They're not going to hit as hard as trunk units but I guess that's the trade off for an easy plug and play install and OEM look. My sense so far is a balanced sound with depth and clarity. We'll see as they break in but I'm very optimistic about these. |
12-19-2015, 11:44 AM | #104 |
Bud Light General
130
Rep 402
I ordered the bavsound underseat as well and they are arriving today. However I did not recieve a email talking about a weatherstrip or a video about it.
12-19-2015, 11:56 AM | #105 | |
Rep 241
PM me your email addy if you want, and I'll shoot them over to you. |
12-19-2015, 12:43 PM | #106 |
44
Rep 208
Not every vehicle / audio system combination requires the weatherstripping -- if you didn't get an e-mail about it, you don't need it.
12-19-2015, 12:43 PM | #107 |
Rep 2,989
12-19-2015, 12:55 PM | #108 | |
Rep 77
How do you decide which one needs and which one dont? |
12-19-2015, 12:58 PM | #109 | |
44
Rep 208
For example, we did testing on our F80 M3 with HK with 4 Ohm woofers (instead of the 8 Ohm version we shipped to HK customers) and the output was, frankly, absurd -- but we don't know the long-term ramifications to the factory amplifier in such a setup, and our goal is always reliability first and foremost, both of our components and the factory amp, etc. (which is why we elected to go the safer route). That said, as we said in our initial e-mail about our products, and on our site description, if you want to go further and your goal is the kind of output you'd expect from a very powerful trunk sub configuration, an amplifier upgrade with our subs is really all you need. In our internal testing, we frankly couldn't believe what we were hearing with our Ghost Subs + around 100W per channel on a quality Class G/H or A/B amplifier. (Don't use a Class D amp, at least with HK systems, as you're likely to have noise issues). We'd put it on par with nearly any well designed, high end 10" sub system -- but with much more impactful midbass. |
12-19-2015, 01:01 PM | #110 | |
44
Rep 208
But here's what you need to know: if you didn't get an e-mail, you don't need a gasket. |
