BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW Live enabling
      02-29-2016, 03:12 AM   #23
tomsab0
Drives: F48
Hy, I have a problem with activation BMW LIVE. Setup is CIC Business with Combox.
I did the following steps in order to activate it:
1. FDL-code CMB_MEDIA:
MAIN_BOARD_ALONE -> mainboard_alone
TELEMATIK_VIN -> Coding_VIN
2. Edit FA
VIN = "FAKEVIN"
3. FDL-code CMB_MEDIA without further changes
4. "Update services" from the idrive
5. Load and activate original VO
6. FDL-code CMB_MEDIA:
MAIN_BOARD_ALONE -> ecallboard_present
TELEMATIK_VIN -> MOST_VIN
After that BMW Live works!!! BUT only for one day. When I am driving the next day, it doesn't work anymore. Also Bluetooth data isn't showing up anymore... Does anyone have an idea, what the problem could be?
      07-09-2016, 04:56 PM   #24
myszano1
Drives: f30
Originally Posted by Bypx
Originally Posted by bmwdd View Post
What VIN did you use? Is the VIN you use provisioned with BMW Live option? I understand people are using this fake VIN WBAFV31030DZ17872 to activate BMW Live.
Regarding the MP3 album art not showing, there are a couple of codes that you can check but I don't have them now.
For music playing issue, suggest you to update your media / phone software via www.bmw.com/update first. Input your DONOR Vin in order to get the software update for your retrofitted NBT. The latest version of the bin file should be UPD05073 (90.1 MB) for MN-002/TN-002 software series.
Thank you. Problem solved with WBAFV31030DZ17872 .
Hi. Can you please describe step by step what need to be coded to enable live in retrofitted nbt. It's your's still working?
      07-12-2016, 05:28 AM   #25
jalami
Drives: f30
Hi.
It is valid for hu_entrynav???
      07-21-2017, 07:34 AM   #26
jalami
Drives: f30
Originally Posted by jalami View Post
Hi.
Hi again
Someone has advanced something. I have surrendered
      10-10-2017, 05:33 PM   #27
jalami
Drives: f30
Use Emulator?
      10-16-2017, 01:33 PM   #28
sirk77
Drives: F25 LCI 20d
Does it work for factory NBT?
My BMW online service was expired. Is there any way to recover it without buying from BMW?
Is option 616 correct for BMW online? Maybe i should add to FA then buy 1 month service then it should work. I did this way for RTTI so far it works.
You actually don't need to update the modified FA into your car and you shouldn't be doing it. Instead, you should
1. Edit FA and change VIN to WBAFV31030DZ17872
2. Save as a new FA (do not use this new FA for all other purposes other than enabling BMW Live)
3. Do not write the FA to the car
3. VO code NBT (make sure you've disabled VCM and MSM update in eSYS option)
4. Go to ConnectedDrive and update service
5. Edit FA and change VIN to your car's VIN
6. VO code NBT
7. Do not update service anymore
(You also need a emulator for coding someone else's VIN into NBT)
      10-18-2017, 08:21 AM   #29
hsk1610
Drives: 2013 328i xDrive
I have the same issue. My BMW Assist expired a month ago and I tried to code for BMW Live last night but I could not get it to work. Do I have to have a valid BMW Assist membership before I can code for BMW Live? I thought it was one or the other so even without BMW Assist, I should be able to get BMW Live working with tethering with my phone.
      10-18-2017, 11:29 AM   #30
binobinobino
Drives: f30 2014
I have coded internet browser, tethering turned on (weather works) and when I try start it, it closed...what else can i try to do ?
      04-05-2018, 10:38 AM   #31
hsk1610
I tried to do this yesterday, but when I go to try to enter the FAKE VIN, it won't let me type in the V in the VIN number. Can't figure out why it wont take that letter?
      04-05-2018, 04:08 PM   #32
GuMiMoRo
Drives: F31
Does anyone cn share the ultimate coding (FA, fdl and xml) for this to work? so many information but sometimes is to complex!
-remove 612
-have from factory 614 e 615
-FA code HU-NBT
edit the XML with these settingsDOCNUAS user thx)
PHP Code:
Ok!
So these are the settings that for now are working correctly for BMW Online/Live with the weather widget:
PHP Code:
bon>
active>1</active>
onlinemode>1</onlinemode>
url>https://b2v.bmwgroup.de/com/cdpnbtlive/vehicle/nbt/servlet/start</url>
<disable>00</disable>
vmax>FF</vmax>
csdtimeout>600</csdtimeout>
gprstimeout>300</gprstimeout>
widget_url>https://b2v.bmwgroup.de/com/cdpnbtlive/vehicle/nbt/nbt_appstore/servlet/splitscreen</widget_url>
</bon>
bin>
active>1</active>
url>https://www.google.com/ncr</url>
<authurl>https://b2v.bmwgroup.de/com/bin_auth2/de/csim</authurl>
vmax>FF</vmax>
bin>
And
this is to make BMW Online/Live working through bluetooth:
PHP Code:
aclappl>
appname>bon</appname>
appcode>3</appcode>
apppriority>3</apppriority>
devicecost>2;1</devicecost>
datavoicemedia>1</datavoicemedia>
dataclass>2;1</dataclass>
datatype>1</datatype>
switching>0</switching>
appbearer>2</appbearer>
voicedataparallel>0</voicedataparallel>
provmode>1</provmode>
audio>1</audio>
roaming>1</roaming>
mo>0</mo>
mt>0</mt>
clampfollowup>0</clampfollowup>
userauth>0</userauth>
vehauthlevel>1</vehauthlevel>
proxies>2,1/1,1</proxies>
outgoingportrange>25000-29999</outgoingportrange>
qospriority>0</qospriority>
aclappl>
Modify your file in order to reflect these changes.
Sorry about the delaybut here's how to enable pictures at destination:
You just need to make two small changes (I hope)
First:
Where you have:
PHP Code:
<pictures>
        <url/> (or any other url)
      </pictures>
Change it to:
PHP Code:
<pictures>
        <url>https://b2v.bmwgroup.de/com/cdpnbtlive/vehicle/nbt/nbt_pictures/servlet/cab</url>
      </pictures>
Second:
If you have:
PHP Code:
<b_pictures>0</b_pictures>
Change it to:
PHP Code:
<b_pictures>1</b_pictures>
This should be enough!
Ok! So these are the changes required to get weather information on the navigation map:
PHP Code:
<weather>
<active>1</active>
<url>
https://b2v.bmwgroup.de/com/cdplive/cdp/release/vehicle/connnav/servlet/getOnlineWeather
</url>
</weather>
And to get the weather information via bluetooth data:
PHP Code:
<aclappl>
<appname>weather</appname>
<appcode>41</appcode>
<apppriority>3</apppriority>
<devicecost>2;1</devicecost>
<datavoicemedia>1</datavoicemedia>
<dataclass>2;1</dataclass>
<datatype>1</datatype>
<switching>0</switching>
<appbearer>2</appbearer>
<voicedataparallel>0</voicedataparallel>
<provmode>1</provmode>
<audio>1</audio>
<roaming>1</roaming>
<mo>0</mo>
<mt>0</mt>
<clampfollowup>0</clampfollowup>
<userauth>0</userauth>
<vehauthlevel>1</vehauthlevel>
<proxies>2,1/1,1</proxies>
<outgoingportrange>40700-40709</outgoingportrange>
<qospriority>0</qospriority>
</aclappl>
Change your files to reflect the changes in these sections and it should work!
And FDL:
HU_NBT->3000 HMI->Funktionen->CONNECTED_DRIVE->aktiv (already aktiv)
HU_NBT->3000 HMI->Funktionen->ONLINE_BROWSER_LIVE->aktiv
HU_NBT->3003 > ONLINE_BROWSER = Beide aktiv (both aktiv)
HU_NBT->3003 > ONLINE_SERVICES = nicht_aktiv
HU_NBT->3003 > ONLINE_SERVICES_GLS = nicht_aktiv
HU_NBT->3003 > DUN_PROFILE->aktiv
HU_NBT->3003 > PAN_PROFILE->aktiv
HU_NBT->DATACOMM SIM>Aktiv
HU_NBT->BLUETOOTH_SAP_SUPPORT--> AKTIV
RESULT:
  1. Only Internet via phone bluetooth data work!
  2. BMW Online gives me an Internal error popup
  3. NO BMW Live on connectedDrive menu
  4. NO Widgets on tge splitscreen
Any help? advice?
Thx you all
      05-27-2018, 08:59 PM   #33
sacaman
Drives: F25 x3 X-line 2016
put your XML that i can check it for you
      03-29-2019, 09:25 AM   #34
niksss
Drives: 2016 BMW F10 535i
Which XML do I have to edit with the data from the post above ?
Can anyone tell me how to enable BMW Online, Internet, Weather etc ? My car is BMW E9x with NBT ID4 retrofitted. I have an emulator (obviously). I have currently coded this:
3003 > DUN_PROFILE - aktiv
3003 > PAN_PROFILE - aktiv
3003 > ONLINE_BROWSER - beide_aktiv
3003 > ONLINE_SERVICES - nicht_aktiv
3003 > ONLINE_SERVICES_GLS - nicht_aktiv
3003 > ASSIST - nicht_aktiv
3003 > ONLINE_BROWSER_LIVE - aktiv
3003 > DATACOMM_CSIM - nicht_aktiv
But nothing shows up. I have only Mobile Care, Hotline and Your Service, which show up a phone number when I press them. I read that I have to code some VO, but I doubt I can code VO on a retrofitted NBT car.
Is this going to work for me:
6. VO code NBT
Also what exactly does "VO code NBT" mean ? Does it mean Activate FA and then just code FDL ? Sorry for the noob questions, but I am coding with esys from yesterday.
      05-05-2019, 02:15 AM   #35
Rich84Ts
Re-Builder
Rich84Ts's Avatar
17
Drives: 320d
I’m looking to achieve this too. Would someone let me know if they think this emulator would be suitable, I’m sure it already has a donor vin embedded but not sure if you’d be able to code it... https://rover.ebay.com/rover/0/0/0?m...2F153465728272
      11-16-2019, 02:07 AM   #36
Justy
Drives: BMW driver
BMW Live on HU_ENTRYNAV
Hi, I drive a F31 2014 with Entrynav and no standard connection to the internet (Connected Drive, BMW Live BMW Online Services etc.)
In the SA List I only got this 6XX options:
606
698
6NH
6WA
So, is it possible to get BMW Live or Internet?
Have already tried some things with donor VIN, but E-Sys brings a negative response error...
Has anyone any suggestions?
Thanks
      12-15-2019, 01:53 AM   #37
Justy
Drives: BMW driver
Nobody here who can help?
      12-23-2019, 12:26 PM   #38
biomed27
Drives: f30
Cant get bmw assist to disappear and bmw live to appear. Any help would be appreciated.
