BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 335i LED Conversion (work in progress)
      10-06-2014, 10:44 PM   #45
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Other pic didn't upload from my mobile
      10-15-2014, 10:39 AM   #46
Rxpert
Rxpert's Avatar
187
Drives: 2018 F80 M3 ZCP 6 Speed Manual
I've been following this thread for awhile. Your LEDs look great by the way!
I just coded my rear turn signals and will install bulbs later today or tomorrow night.
Quick question though, is there a consensus on what values in REM to code for the break lights? A couple posts back BL_ was mentioned but it said "un-tested". I have two sets of bulbs and want to put in the break lights at the same time as turn signals.
Has anyone successfully coded the outer break lights?
Thx in advance
      10-16-2014, 10:10 PM   #47
Rxpert
Rxpert's Avatar
187
Boo.....
So I installed the red LED rear turn signal bulbs (Bimmian Part Number WTSAAA8R2) tonight and they look great. But the bad news is that the same bulbs do NOT fit into the outer break lamp slots. Totally different bulbs. Owner manual states P21WLL for turn signals and H21WLL for outer brake lamps.
I will be retuning the extra set of red LED bulbs to Bimmian and would like to exchange for either reverse lamps or preferably outer break lamps.
Does anyone know the Bimmian Part Numbers for the outer brake lamps (H21WLL) or for the reverse lamps (PW16W)????
Sorry if this was already answered in the thread. I'm just confused between all the BMW manual part numbers and Bimmian part numbers.
      10-17-2014, 02:03 AM   #48
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Originally Posted by Rxpert
Boo.....
They fit fine in my brake lights... What doesn't fit?
Look at my first few posts and I linked straight to the bulbs
      10-17-2014, 06:53 AM   #49
Rxpert
Rxpert's Avatar
187
So to double check, the rear turn signals and outer brake lamps use the same bulb type on your car?!?!?
On my car they are two totally different bulbs with two completely different bases. It is physically impossible to insert the same bulbs into both (I tried). The turn signals are a larger P21 bulb whereas the outer brake lights are about half the size and H21 bulbs.
I'm starting to think this may be a subtle difference for the F32. Wish I took a picture of the bulb assembly last night.
I followed the links several times, way to many options. Do you have the exact Bimmian part numbers you ordered?
      10-17-2014, 09:17 AM   #50
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
I have a 2014 328i so I think the bulbs will be the same. Here's what I have changed out from Bimmian with WeissLicht LEDs (both were P21W -- in spite of what owner's manual said)):
  • Amber Rear Turn Signals: WTS302RAY
  • White Reverse lights: LVL302VWY
Al
Retired: 2014 328i
BMW CCA
      10-18-2014, 12:36 AM   #51
Steve33
Steve33's Avatar
Drives: 2018 SQ5
I'm on my phone, but I used the same as the blinkers on the first page of the thread. Same bulb for both
EDIT: Ok off my phone now
http://www.bimmian.com/WeissLicht-LE...r-F80-3-Series
Front ambers: WTS302FAY
Reverse: WTS302VWY
Rear blinkers and brakes: WTS302RRY
      10-19-2014, 03:26 AM   #52
obriennathaniel
obriennathaniel's Avatar
Reverse: WTS302VWY
Where in tx are you located? I have my LED bulbs but I'm just waiting to get my car out of the shop. I have the cable and Esys to code my car(no token, still not sure how to get one), but I was wondering if you could show me how to do it so I won't risk fkn anything up lol. I'm in Houston.
      10-19-2014, 01:53 PM   #53
Steve33
Steve33's Avatar
Drives: 2018 SQ5
I don't live there anymore. Message Shawnsheridan for a token
      10-19-2014, 01:56 PM   #54
shawnsheridan
shawnsheridan's Avatar
PM sent.
      11-07-2014, 05:46 PM   #55
Yuqi
Drives: 14 335i Xdrive
Do you know if WTSZZA8R2 are the same as WTS302RRY?
      11-09-2014, 11:09 PM   #56
Steve33
Steve33's Avatar
Drives: 2018 SQ5
No clue. Where do you see those?
      11-10-2014, 09:32 AM   #57
carzaddict
Drives: 2015 Cadillac Escalade ESV
in the midst of your LED coding........were you able to figure out a way to keep the car from switching from Cold white to warm white when you open the door?
2015i Cadillac Escalade ESV
      11-10-2014, 08:15 PM   #58
Yuqi
I think the rear is PY21W? This is what I see from Biamian
Pair of 7507/150 AKA: PY21W Style Spektrum Bulbs
Red Illumination WTSZZA5R2
      11-10-2014, 08:24 PM   #59
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Nope, and it's pretty annoying
      11-10-2014, 08:27 PM   #60
Steve33
Steve33's Avatar
Drives: 2018 SQ5
WTS302RRY Rear blinkers and brakes (Red)
WTS302FAY Front blinkers (Amber)
LVL302VWY Reverse (White)
      11-10-2014, 11:54 PM   #61
saason.ez
Drives: 2013 328xi sportline
just to confirm with you guys the upper break light on the back windshield uses the pair of red turn signal bulbs, and the same can be said for the brake lights as when you break will light up in red LED
      11-11-2014, 06:28 PM   #62
Steve33
Steve33's Avatar
Drives: 2018 SQ5
The middle is already a LED (so there's no need to change it). If it's different for you, I'm not sure why
      11-12-2014, 07:44 PM   #63
saason.ez
ok but to do the break signals in LED i would just have to buy another set of rear turn signal bulbs from bimmien?…. Also lastly, have people been successful in coding the car to prevent hyper blinking from the turn signals or are people experiencing it from replacing their turn signal bulbs with these ones?
http://www.bimmian.ca/WeissLicht-LED...r-F80-3-Series
      11-12-2014, 10:39 PM   #64
Steve33
Steve33's Avatar
Drives: 2018 SQ5
You need:
One set for the front blinkers
One set for the rear blinkers
One set for the left/right outside brakes (Don't need a set for the inners, they're not used - at least here in the states. Middle is already LED)
One set for reverse lights
There is no hyperflashing nor the blinking to check if there is a bulb out. I coded before I installed so not sure what happens if they're not coded but from what I've seen, you'll have the flashing problems
      11-12-2014, 11:19 PM   #65
saason.ez
Which bulb is that to order on there site
      11-13-2014, 12:37 AM   #66
Steve33
Steve33's Avatar
Drives: 2018 SQ5
On the link you pasted above:
Rear Turn Signal Bulbs
Red Illumination (pair)
WTS302RRY
