07-28-2013, 12:23 PM | #4159 |
Rep 263
07-28-2013, 12:32 PM | #4160 |
Rep 40,779
I do not understand what you write. Your brother can Code Video over USB if he has NBT.
07-28-2013, 01:15 PM | #4162 | |
Rep 40,779
API_USB_VIDEO = both ENT_CODEC_OGG = aktiv ENT_CODEC_VCD = aktiv ENT_CODEC_XVID = aktiv ENT_MC_VIDEO_SUPPORT = aktiv ENT_MC_WLAN_STREAM_DMP = aktiv ENT_MC_WLAN_STREAM_DMP_COVERART = aktiv ENT_MC_WLAN_STREAM_DMP_VIDEO = aktiv
07-28-2013, 01:39 PM | #4163 | |
Rep 263
I can only say, thank you chef |
07-29-2013, 11:58 PM | #4164 |
Rep 473
Can anyone help me with doing the same with mine... would like to activate cornering lights aswell, Cheers, Matt
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned Current - 2019 BMW G20 330i M Sport Alpine White Retired - 2018 - Range Rover Velar SE D240 Retired - 2015 - Mercedes Benz C250d AMG Line W205 |
07-30-2013, 02:16 AM | #4166 |
Rep 40,779
What is it you need? Software or guidance?
07-30-2013, 02:45 AM | #4168 |
Rep 40,779
I can help you with the tools. PM sent.
I don't do any Exx Coding though, so I wont be of any use to you for Guidance.
07-30-2013, 03:26 AM | #4169 |
Rep 263
-how coding>> Fog lights come on at unlock with welcome lights
-Also, is it possible to increase the sensibilté sensor wipers, because it goes too slowly thank you Last edited by thebadboy; 07-30-2013 at 09:35 AM.. |
07-30-2013, 05:28 PM | #4170 |
Rep 7
Going in for a mid cycle oil change tomorrow, not sure if they're going to update my car or not. Getting first post out of the way so that I can receive PMs in case I need to get a token for 3.22.5.
Anyone know the odds that they'll flash it? I'm @ F020-12-11-502 / 48.1 right now. |
07-30-2013, 08:22 PM | #4171 | |
Rep 40,779
If while it is there though, there are also applicable Service Bulletins that they decide to apply to your car, and one of those SIB's calls for programming the car with an ISTA/P Level higher than your car currently has on it, then it will be programmed too.
07-30-2013, 08:25 PM | #4172 | |
Rep 40,779
FRM => WL_FUNKTION_NSW = soft_on or hard_on. Maybe F30 has the same or similar code in FEM_BODY.
07-30-2013, 09:21 PM | #4173 |
Rep 34
Looking to program mine (remove chimes, auto lock of doors) - Where can I get a proper cable and the software?
Also - Can this cable DISABLE the tire pressure monitoring? I want to run winter tires on separate rims without buying TPMS sending units... |
07-30-2013, 09:30 PM | #4174 |
Rep 34
If I deactivate this option (once I get my cable and software!), will this allow me to run my winter tires and rims without tire pressure senders in the winter rims, and not throw an error code? F30 - no NBT.
07-30-2013, 11:19 PM | #4175 |
Rep 263
07-30-2013, 11:34 PM | #4176 |
Rep 40,779
I doubt it. We had an F10 where we completely removed all TPMS Coding (2VB, ICM, etc.), and could not kill TPMS. In the end, the Fuse had to be removed.
07-30-2013, 11:35 PM | #4177 |
Rep 40,779
I have no idea, otherwise I would have made a suggestion for it too.
07-31-2013, 09:06 AM | #4178 | |
Rep 1,892
Settings -> Locks. |
07-31-2013, 10:07 AM | #4180 |
Rep 40,779
Do you have a 9C FSC Enabling Code Imported and Activated in Head Unit for 6NR BMW Apps?
