12-05-2014, 06:36 AM | #23 |
Rep 524
Thanks for the info, so if I understand it correctly, either the dealer has to update the KOMBI or I have to change the build date and flash the firmware, in order to change the istep to something 54 or higher, right?
12-05-2014, 11:47 AM | #24 |
Rep 286
You can update or the dealer. You don't have to change the build date. I used my factory FA (0312) and flashed all the modules. I'm not sure if just flashing the Kombi is enough, I haven't tried it. But I would recommend flashing all the modules if you are going to flash it.
It took me about 20-30min to flash all the modules besides the NBT. As I have a retrofitted NBT with different build date. I usually flash NBT/Trouch Controller and then using my factory FA flash rest of the car so SVT gets updated properly on VCM. To flash Load your FA under Tal-Calculation menu. Read SVT_Actual. Activate your FA Complete flash Select ISTEP shipment for your build calculate.. Then calculate TAL Then you are good. Then follow the proper flashing procedure. Use minimum 25AMP charger. I know it's recommended to use 70AMP, but I have flashed a few cars using my 25AMP one. |
12-05-2014, 11:53 AM | #25 | |
Rep 524
01-07-2015, 02:35 PM | #26 |
Rep 33
I am updated to the latest integration level on my 14 F32, but my clock is still centered between the tach and speedo. It seems like only the newer 15s have the clock in the bottom right corner. I'm going to play with KOMBI tomorrow and try to figure this out.
01-07-2015, 06:28 PM | #27 |
Rep 40,789
Try VO Coding Kombi using a 2015 Build Date.
01-08-2015, 11:20 AM | #28 |
Rep 524
01-08-2015, 11:26 AM | #29 |
Rep 40,789
VO Date cannot be random. For F30 MY 2015, use 1114 as date.
01-14-2015, 04:32 PM | #30 |
Rep 1,649
hold on, we can code in the function so I can (permanently?) set my steering to sport and leave the throttle mapping as comfort? If so I will so happy.
01-15-2015, 04:46 PM | #31 |
Rep 524
Were you successful in moving the clock to the lower right?
01-16-2015, 08:54 AM | #32 | |
Rep 1,573
however you cant program it to start in sport mode everytime you start the car
2015i Cadillac Escalade ESV
01-17-2015, 10:52 AM | #33 | ||
Rep 1,649
01-20-2015, 04:59 PM | #34 |
Rep 524
updated Kombi with extended cluster but still no icon
Finally successfully updated the KOMBI firmware with 54.2 but still no heated steering wheel icon. I do have the extended cluster. I don't want to change the build date to 1114 since I was told that with the CIC, the dash nav directions will get messed up with the resolution and what not. Does any other module need to be updated as well? Just did the Kombi, out of fear, I might brick something. Also had a cow when I got the SOS malfunction light after the flash, but it finally went away after two starts of the engine.
Also changed the build date to 1114 but did not move the clock to the lower right either. Last edited by hsk1610; 01-20-2015 at 07:19 PM.. |
01-20-2015, 08:16 PM | #35 | |
Rep 1,573
01-20-2015, 10:02 PM | #36 | |
Rep 524
01-21-2015, 06:29 AM | #37 | ||
Rep 46
01-21-2015, 08:57 AM | #38 | |
Rep 1,573
Maybe you should update one module at a time until it works? I mean, only if you're really bored and really want it haha
01-21-2015, 04:34 PM | #39 |
Rep 524
I'll retry flashing the KoMBI, since supposedly with the new PSDZdata, the m_performanance logo should display m550 but mine still shows M_performance. And then go from there to the FEM_Body and so on...
01-22-2015, 07:06 PM | #40 |
Rep 524
Updating the FEM_Body to the latest finally made the heated steering display on the dash to show up. But gave up trying to move the clock to the lower right. LOL.
01-26-2015, 04:28 PM | #41 |
Rep 33
01-26-2015, 04:29 PM | #42 | |
Rep 40,789
Charger is needed for Flashing not Coding.
01-26-2015, 04:31 PM | #43 |
Rep 33
02-01-2015, 12:12 PM | #44 |
Rep 5,316
Drives: G80 M3 6MT
If you are on the new I-Level and you VO Code the KOMBI with an 0714 build date the clock will move. I just did it.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
