02-01-2015, 12:20 PM | #45 |
Rep 40,774
If 0714 is the coding date, I would expect any firmware since F020-14-07-502 to work this way, which is 53.0.
02-03-2015, 06:57 PM | #46 |
Rep 524
I was successful in moving the clock to the lower right. However, as Aritaurus had mentioned, changing the build date with the CIC has created another issue- which is the nav directions on the extended instrument cluster. The directions are slightly distorted and the arrows for directions are off the screen. Is there a way to adjust for that by FDL coding a parameter? If not, I might have to just revert to my original build date and keep the clock in the center.
02-03-2015, 08:20 PM | #47 |
Rep 347
can i ask a stupid question? what's the point of all the trouble trying to get the clock slid off to the right under the tach? seems out of place over there all by itself.
at this point, are you all just trying to figure it out as a challenge? lol I have a '15 Gran Coupe and my clock is in the center! |
02-03-2015, 08:28 PM | #48 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
02-04-2015, 09:08 AM | #50 | |
Rep 1,573
2015i Cadillac Escalade ESV
02-04-2015, 11:26 AM | #51 |
Rep 524
fonts fixed on CIC
Aritaurus was kind enough to lead me to the correct setting under KOMBI. if you change the NBT_Nav_Enable to not active, the directions and display shows up correctly on the 6WA cluster with CIC.
02-04-2015, 12:26 PM | #52 |
Rep 219
Drives: '19 G20 330i & '19 G01 X3
I'd love to flash my KOMBI on my 2012 F30/CIC.. Up to this point, I've only ventured into doing the basic coding.. Is there a guide to flashing that someone can point me to? I've not found one yet. Can I do the flash with the engine running to supply enough power?
Thanks! |
02-04-2015, 12:29 PM | #53 | |
Rep 40,774
02-04-2015, 12:39 PM | #54 |
Rep 219
Thanks Shawn.. I'll have to figure out a way to do that. Might be easier to ask the dealer to update my KOMBI when I go in for my brake fluid change this month. :-)
I figured it was more involved! |
02-04-2015, 12:40 PM | #55 |
Rep 219
Shawn -- Assuming I say, jump my car to my wife's Honda Pilot, is there documentation out there on how to flash the modules? Thanks again!
02-04-2015, 12:45 PM | #56 |
Rep 40,774
PM sent.
02-04-2015, 12:54 PM | #57 |
Rep 219
Thanks Shawn! I've been a long time lurker and your posts and information has really helped me with my previous E92 and my new F30. I appreciate the community here and I'm looking forward to giving back when I can.
02-04-2015, 12:59 PM | #58 |
Rep 40,774
02-05-2015, 09:52 PM | #59 | |
Rep 219
I'm getting myself up to speed on what I need to do on Esys, as well as having the full psdzdata v54.. I have the flashing guide from Shawn as well. Not planning on doing more flashing than required, so I'm going to jumper cable to my wife's Honda Pilot. All this because I want a notification that I turned my steering wheel heater on! I didn't even realize the button had an LED in it until earlier today. It's kind of difficult to see, behind the steering wheel! -- Matt |
02-06-2015, 09:08 AM | #60 | |
Rep 1,573
02-07-2015, 05:56 PM | #61 |
Rep 219
I've flashed KOMBI and FEM_BODY on my F30.. Here is what my i-step levels are now/was:
I-Step Current: F020-14-03-502 I-Step Last: F020-13-11-504 I-Step Shipment: F020-11-11-505 After a successful flash of the two modules, I did have an SOS Emergency Call malfunction as well as the steering wheel heater not enabling. After several restarts and a few minutes, the SOS error cleared on its own and the steering wheel heater decided to start working. Just in case someone else goes to do this and has this issue. The steering wheel heater activation and deactivation notification is now showing up on my 2/12 build -- so a really early build. Thanks everybody for the help and hopefully this helps someone with an early F30 build. -- Matt |
10-01-2015, 08:17 PM | #62 |
Rep 524
Sorry to resurrect a dead post, but my car was reprogrammed at the dealership for DME issues. I don't want to change the VO date and want to keep it as the original VO date.
Is there a sub menu in KOMBI that I can change that would move the clock from the center to the right lower corner? Found this online: BASISANZEIGE_VARIANTE" to "aktiv, but wonder if this exists in KOMBI with a CIC headunit. Will test it out during the day. Last edited by hsk1610; 10-02-2015 at 01:12 AM.. |
