BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 435ix MAF Sensor errors
      04-29-2019, 05:47 PM   #1
MatF36mods
Drives: BMW 435ix Gran Coupe (F36)
Wondering if anyone can help with the following errors. I installed and CTS Intake and charge pipe. I didn't get any check engine lights and the car feels like it runs great. Last weekend I ran a diagnostic on the ODB2 port preparing to go to a stage 1 map and I ran into the following error codes:
108001 - Diagnosis monitors the upper voltage limit of the intake air temperature sensor after air filter.
Malfunction monitoring conditions
The fault is detected whenever the voltage of intake air temperature sensor is greater than 5V.
102a01 - The diagnosis monitors whether a signal from the HFM airflow sensor is present.
The fault is detected whenever the period duration of the HFM signal is zero.
108010 - Diagnosis monitors the voltage of the intake air temperature sensor after air filter in terms of impermissible large surges.
The fault is detected whenever the difference between the raw voltage value and the low-pass filtered voltage value is greater than 1 V.
I thought most of the errors were due to the MAF sensor, so I properly cleaned it out with an MAF cleaning spray. Before I change the MAF sensor out for $170, does anyone else have any recommendations? Are these fault codes normal due to the CTS Intake install and increased air flow? Any suggestions or advice would be grateful. Thanks
      05-06-2019, 09:45 PM   #2
TerryGTX
Drives: 2014 Bmw 435xi M-sport
have you resolved this issue'? my MAF caused fuel trim issue. I unplugged it and fuel trim went to normal. waiting for a new maf sensor to put on tomorrow
      10-05-2023, 12:29 PM   #3
Jhouse_01
Drives: 2016 bmw m4
I had CTS intakes on a stock bmw m4 and I never had any issues, now I have vrsf downpipes and CTs intakes and stage 2 bm3 tune and I got the same code 102A01 I’m not sure if it’s my MAF sensor but when it was stock it was fine
      10-06-2023, 07:28 AM   #4
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Would be a good question for the s55 guys in the m3/m4 forums.
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
air intake, cts turbo, fault codes, intake, maf, maf sensor
