07-27-2023, 09:37 AM | #1 |
Rep 33
FS: Match PP82DSP w/ HiFi Harness and Power Wiring
Match PP82DSP Amp, Hifi Wiring Harness, and 6ft Power Cables with 40 amp fuse block pre-installed from knukonceptz Similar to the bimmertech options available. The main difference is that the power comes directly from the battery instead of via the harness (20 amp vs 40 amp fuse). Does not have a metal mount to clip into the factory amp location as the bimmertech option has. Requires HiFi Sound System (676) systems (will not work with HK systems!) Amp is in great condition and was used for two years on my F30. Will need to be reconfigured with a new configuration file once connected to your car (unit needs to have an input source to be turned on and Windows laptop connected) Configured to have G and H as sub channels, so you can also hook up an aftermarket sub if you want. Remote turn on out is available from the amp. Includes USB Cable and Manuals The positive cable will connect directly to the battery via 10MM socket Negative cable can connect to a post near the factory amp in the wheel well Shipping is included for United States buyers |
07-28-2023, 10:32 PM | #3 |
Rep 33
Would not be full plug and play like that model. This setup requires power from the battery directly and a grounding point on the car. Cables are included and there’s a 10 MM bolt on the positive terminal that I’ve used with no issues and a negative post on the top of the driver side rear-wheel by the factory amp.
To install the amp, you’re pulling the carpet off anyways, so it only adds a couple of minutes to the install the power wires. |
08-23-2023, 06:10 AM | #7 |
Rep 177
Will this work with not HK or HiFi but a basic/entry level setup that I am looking at upgrading along with upgraded seat subs, and HK pillar tweeters and possible an additional sub in the trunk?
08-23-2023, 08:59 AM | #8 | |
Rep 33
Here's some more information that should help: https://f30.bimmerpost.com/forums/sh....php?t=1801823 |
amp, audio, bimmertech, f30, match, pp82dsp, pp86dsp, sound |
