09-11-2018, 10:39 PM | #199 | |
Rep 8,364
• F32 = Production after 07/13 • F33 = Production after 11/13 • F34 = Production after 03/13 • F36 = Production after 03/14 |
09-28-2018, 04:54 PM | #200 | |
Rep 5,457
Drives: F30
09-28-2018, 11:47 PM | #201 |
Rep 8,364
09-29-2018, 07:00 AM | #202 |
Rep 5,457
Drives: F30
I believe so. I have BimmerCode which is what others from here have used to code these features. Just tryna follow suit.
10-01-2018, 09:16 PM | #203 |
Rep 8,364
12-14-2018, 05:52 PM | #204 |
Rep 24
sport+ coding with vgate
Hi my friend just trying to code sport+ with no luck I bought vgate dongle to code in bimmer app I confuse can you help me out thay told me I have to change some values in order to see sport+ on screen and working do you think that mabe is not available for my car
12-28-2018, 10:45 AM | #206 |
Rep 2,672
This question may have been answered but why did my car not come with sport+ originally? It’s been great to use esp given my other mods. The steering is more responsive, gear shifts quicker and exhaust sounds better. Just wondering why it didn’t come with it originally - and is there any harm in using it?
04-24-2019, 11:05 AM | #207 |
Rep 25
Hi,
I have F10 manual transmission. I change: ICM/IcmKod_B_S2TBA -> verbaut and now I have sport+ but only DTC off, i need DSC off with sport+ how coding? Last edited by rychu9191; 04-24-2019 at 02:10 PM.. |
04-28-2019, 01:27 PM | #208 |
Rep 387
I tried coding it through Bimmercode originally, but could not. I just got my car back from the dealer to replace a faulty thermostat, and while there, they appear to have updated the software because all my settings were set back to factory default. When I went in to re-code, I selected Sport+ just for the hell of it and it worked. My HVAC also doesn't default to "on" on startup like before either.
I think if you are not able to code these options, it's because the current version of software in you car doesn't support those functions. You may need to take it in for service and request a software update. Last edited by IraHayes; 04-28-2019 at 02:23 PM.. |
05-13-2019, 06:46 PM | #210 |
Rep 54
Can someone finally explain other than turning DSC off in Sport+ , do you actually FEEL the difference?
My F30 , 2016 328xdrive does not have it, and no paddle shifters. Is there any benefit in sport+ comparing it to Sport? I just wanted to know if it worth the hassle |
08-08-2019, 04:30 AM | #211 |
Man
Rep 2
Hello!
Does anybody coded fully sport+ (with DTC OFF) with the manual gearbox successfully?? I have 320d with manual transmision. I am really green with the coding. I would be very grateful if You could help me step by step. Thanks!! Last edited by Kozenko; 08-08-2019 at 04:39 AM.. |
08-11-2019, 04:43 PM | #212 |
Rep 5
Bimmercode for Android
First go to Integrated Chassis Management Set SPORT + driving mode to Active and then CODE After that go to Instrument Cluster and set there aolso SPORT + to active |
09-02-2019, 04:39 AM | #213 |
Man
Rep 2
Thanks for reply.
I will try to code this week. I have the bimmercode for iPhone, but I guess it's the same. Those two options to code and that's all? I'm just asking because the thread looks quite complex so I don't want to miss something. Last edited by Kozenko; 09-02-2019 at 06:15 AM.. |
12-11-2019, 03:17 PM | #214 |
Rep 71
Drives: 2014 520D M-sport
On my 2014 f10 coding ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut throws a driving stability error that doesn't go away. Once I code that option back it's perfectly fine.
01-18-2020, 02:08 PM | #215 |
Rep 54
Really confused with all this.
Is sport+ only available for Autos? If not can someone tell me what I need to code in esys for my manual. All instructions I am finding are for SAT included |
10-10-2020, 11:31 AM | #216 | |
Rep 50
11-23-2020, 06:57 PM | #217 |
Majesty
Rep 18
I hate to resurrect this really old thread, but I’m having one small issue with the Sport+ coding on my 2017 3 Series. I managed to code the menu and modules correctly, but I’m missing the “Sport+” indicator in the instrument panel. When I switch modes via the console, I get confirmation of Sport+ mode on the display and instrument panel under the gauge, but not in the small dialog box that’s in the center of the instrument panel. I’m assuming that I need to edit another FDS menu file. Anyone have an idea which one I’m missing?
11-24-2020, 07:47 AM | #218 | |
Majesty
Rep 18
01-08-2022, 08:09 AM | #219 | |
Rep 24
Hello guys, stupid question: are these steps performed in E-sys? If yes, can you please point where these changes should be applied? |
01-08-2022, 10:54 AM | #220 |
Rep 40,884
Yes. FDL Codes are in KOMBI, ICM, and EGS as written.
SharkGrogu0.00 |
