03-06-2017, 10:48 AM | #1 |
Rep 181
Car hesitates after installing intake/cp/dp
I installed an Injen intake and ER CP/DP this weekend and I'm getting a hesitation during part throttle. It seems as if the car has a hiccup, hahaha. I have a JB4 that I need to install, ran out of time/energy when I installed everything else.
Before I put it on, I want to resolve this issue first. I've seen where some people have unplugged their MAF because of aftermarket intake issues. Should I give that a try? |
03-06-2017, 11:50 AM | #3 |
Rep 367
I believe you can only unplug the MAF when running a tune such as a JB4...I don't think the stock DME signals would be okay with running MAF less. Double check for boost leaks, specifically the o-rings on the charge pipe.
03-06-2017, 12:08 PM | #4 |
Rep 2,948
I misread that part, thought he had JB4 already. Def check the CP for leaks. MAF should be ok with stock tune
03-06-2017, 02:26 PM | #6 |
Rep 181
is there supposed to be an o-ring on the throttle body side of the cp?
when i took my stock cp off, it didn't have one at the top. i did move the o-ring on the intercooler side over to the new cp. also, im wondering if an exhaust leak could be the issue because it sounds like there is an exhaust leak. |
03-06-2017, 02:42 PM | #7 | |
Rep 2,082
03-06-2017, 02:50 PM | #8 | |
Rep 709
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
03-06-2017, 03:17 PM | #9 |
Rep 181
i haven't checked the spark plugs, but this only started happening saturday after i installed the mods.
im swinging by the dealership after work today to get an o-ring |
03-06-2017, 04:35 PM | #11 |
Rep 100
I had this issue also. It's your intake. I installed the jb4 and unplugged the maf and it went away.
mine would occur when partially on the throttle, around 3-4krpms it would hesitate and then abruptly pick up speed. As if I had instantly hit a wall of boost. |
sickF3053.50 |
03-06-2017, 05:09 PM | #12 |
Rep 2,082
Seems that most of the issues are open intake. When I got my bms intake I had the same hesitation issue when my car was stock. A week after, I sold the bms intake and I got the afe momentum pro intake that is sealed and issue was resolved.
03-11-2017, 10:33 PM | #14 |
Rep 5,776
Would not worry a great deal if you have an exhaust leak--I had a small on on my DP and it was just a sound. You can re-seat the DP later. Most likely there is an issue with the intake. Once again this is why I always say to install one mod at a time as you will know the variable--you have 3 items to evaluate in this case.
Last car: 2011 335i Msport. JB4. Vrsf CP |
03-12-2017, 09:36 AM | #15 |
Rep 181
This would have never worked when I built the engine myself on my last car. That 6 month rebuild would have taken years doing one thing at a time. lol
03-12-2017, 11:29 AM | #16 |
Rep 5,776
03-20-2017, 05:29 PM | #18 |
Rep 709
Glad to hear the issue is resolved. Maybe look into the implications of leaving MAF unplugged long term as I would assume they have it for a reason
03-20-2017, 05:47 PM | #19 |
Rep 625
Hey everyone...
sorry to sound nooby... which one is the MAF?? the one on the intake (BMS INTAKE for me) ... the wide black plug? I have the same issue with BMS intake and catless DP... no JB4 yet (being shipped atm) |
03-20-2017, 05:57 PM | #20 |
Rep 367
03-20-2017, 09:48 PM | #21 |
Rep 693
Ive been having jb4 for a while but i just installed a bms intake last week. I havent noticed anything weird except for a stumble when i floor it during 3rd gear logs. Stumbles/bogs then takes off fine.
03-21-2017, 09:49 AM | #22 |
F30 328i Msports N20+ERDP+CP+TIC+FMIC+MPE+ JB4
Rep 80
i recently did similar mods with ER FMIC + DP + CP+ TIC running on JB4 map4, i have the same hesitation as well normally at 3k++ the power just releases upon hitting this RPM. I did not change the intake, does it mean that i can remove the MAF as well from my intake and i would get a smooth power/torque curve.
i also posted my logs to BMS and there does not seem to be any boost leak but i have been asked to provide another log with a wider RPM band to be sure. I'm hitting max 23-24psi of boost in my logs but the hesitation is unberable for me. and there seems to be some turbo lag at lower RPM, im suspecting the FMIC is too large compared to the stock version which has very minimal turbo lag |
