BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > N20 Tuning: flashing 320i/420i to 328i/428i specs
Studio RSR
      06-18-2015, 06:37 AM   #23
rednose
Australia
65
Drives: F30 330i LCI M Sport
Originally Posted by x328x View Post
Hey
I am about to pull the trigger on a piggy back. still looking into the other brands.
Please put a review up if you can. I don't want to hijack thread so ill just wait for your thread
As soon as I get it on the dyno I'll post results, seat of the pants says it is quicker but will have more of an indication once it hits the dyno.
I believe its still in closed loop so it shouldn't affect anything but will compare power and Afr with and without the piggy back.
      06-19-2015, 02:05 AM   #24
rednose
Australia
65
Hey
Dyno sheet is up.
http://f30.bimmerpost.com/forums/sho...5#post18116185
      08-17-2015, 09:01 AM   #25
etclam
Australia
Drives: F30 320i M-Sport
Hi Stuart,
Interested to know what up take you have for the 28 tune...
Cheers
Ed
      09-23-2015, 07:36 AM   #26
F36420I
F36420I's Avatar
Belgium
46
Drives: Bmw 420I Gran Coupe
Difference between 420i and 428i
Hello
here is the only difference betwen 3/420i and 3/428i
All other parts are the same
      05-23-2016, 07:32 PM   #27
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
808
Drives: a black car
bump on this as I've updated the title of the post to be a bit more accurate/relevant
Flash tuning the 320i/420i is by far the best upgrade out there
      05-24-2016, 03:32 AM   #28
evobda2
evobda2's Avatar
Drives: F31 M Sport
Out of curiosity have you run into any of the gearbox safeguard problems on the 320i when the torque is raised substantially? Some others (be it overseas) have had this problem after add on type tune boxes etc. Or does your tune address this issue as well?
      05-28-2016, 01:13 AM   #29
Hpwbot
Drives: Bmw 320i f30
Hi Stuart, can you please give me a quote on flashing my 320i to a 28 tune? I am located in Melbourne, do you know who could do it for me down here?
Thanks
      06-02-2016, 03:12 AM   #30
808
Drives: a black car
Sorry for the late reply, haven't encountered any issues with reaching torque limiters on the gearbox. When tuning all cars are dyno'd and the torque curves are all smooth and show the gains we expect
Thanks
PM sent
      06-02-2016, 03:13 AM   #31
808
Drives: a black car
Couple more N20 results from this week
F20 125i Stock: 149rwkw, Tuned: 179rwkw, gain of 30kw & 20%
F30 320i Stock: 114rwkw, Tuned: 174rwkw, gain of 60kw & 52%
      06-02-2016, 04:58 AM   #32
evobda2
evobda2's Avatar
Drives: F31 M Sport
PM me a price too please Stuart. Its for 2014 320i
      04-09-2019, 09:16 AM   #33
brianpalvarez
brianpalvarez's Avatar
Drives: 2016 F30
Hi Stuart, thanks for the update. I am also interested in pricing as well as warranty info. Please PM me as well!
Thanks!
      04-13-2019, 08:12 AM   #34
combivan
Drives: 2012 328i
So far we have not been able to identify any hardware differences between the two.
When comparing 2012 320 vs 328, RealOEM shows different part numbers for Pistons, Intercooler, Transmission, Driveshaft, front muffler and Rear exhaust if that means anything.
Also if you click on each part then you can see different weights like FMIC is 30% heavier in the 328 or you can see the 328i has 75mm mid pipe vs 320i has 65mm mid pipe
Piston:
320i - http://www.realoem.com/bmw/enUS/show...diagId=11_4770
328i - http://www.realoem.com/bmw/enUS/show...diagId=11_4770
Rear Exhaust:
320i - http://www.realoem.com/bmw/enUS/show...diagId=18_1105
328i - http://www.realoem.com/bmw/enUS/show...diagId=18_0974
Transmission:
320i - http://www.realoem.com/bmw/enUS/show...diagId=24_1330
328i - http://www.realoem.com/bmw/enUS/show...diagId=24_1330
Driveshaft:
320i - http://www.realoem.com/bmw/enUS/show...diagId=26_0240
328i - http://www.realoem.com/bmw/enUS/show...diagId=26_0240
Front Muffler:
320i - http://www.realoem.com/bmw/enUS/show...diagId=18_0975
328i - http://www.realoem.com/bmw/enUS/show...diagId=18_0975
FMIC
320i - http://www.realoem.com/bmw/enUS/show...diagId=17_0632
328i - http://www.realoem.com/bmw/enUS/show...diagId=17_0632
      12-04-2019, 03:12 PM   #35
330i_sportshadow
Costa Rica
Drives: BMW F36 420i 2016
Super exciting news for all 320i / 420i owners!! (and anyone else with a detuned N20 engine)
As you may/may not know the 320i runs an N20 engine with flywheel engine outputs of 135kw/270nm.
The 328i makes 180kw/350nm. So far we have not been able to identify any hardware differences between the two.
We're pleased to announce we can flash the 320i to 328i levels and then some
At the same time we can tune the 328 with a proper flash tune, although the gains are less as we are obviously starting in a higher state of tune.
We are offering two levels of tunes:
- the '28' tune; and
- the '28+' tune
The 28 tune is designed to take the 320i to 328i levels of power. At this level the car will perform the same as a standard 328i (which is no slouch!). The fuelling, boost and ignition mapping is virtually identical to a 328i.
The 28+ tune is designed to take it one step further, similar to what a tuned 328 would be.
Dyno numbers from a 420i
Stock 420i: 117.5kw
28+ tuned 420i: 172.9kw
For comparison, a stock 328 will make approx 155kw on this dyno and 172kw tuned. Here is a 328 with JB4 dyno sheet I posted up a while ago:
How does it drive?
Brilliantly! I have driven stock 320s and 328s, and both models with JB4s and the flash tuned vehicles drive noticeably smoother and better than the JB4.
That's not to discount the JB4 though - it's still a brilliant unit that offers excellent bang for buck, and you wouldn't pick the difference unless you had driven both back to back.
One advantage the flash tune has over the JB4 comparing the dyno sheets above is the flash tuned 420i will hold power and torque up top better, whereas the JB4 tends to fall away.
Next steps
We are hoping to do a downpipe/intake combo on the 320i/420i combined with the 28+ tune to see if it gives similar results to what we would see on tuned 328i/428i (around 195rwkw)
Pricing
please refer to the BMR website *link to be provided shortly*
At the end of the day this is a fantastic upgrade for any 320i/420i owner, particularly those who may have wanted the 328i/428i in the first place, but ended up with a 320i/420i whether due to availability or lower purchase price. Now 320s and 420s no longer need to miss out on that extra power enjoyed by their bigger brothers
So I own the 420i EUR 2016 (n20) and planning to do this
downpipe upgrade with sport cat
FMIC.
However, the FMIC I am trying to buy is from US, and made for 428i. based on your message there are no hardware differences so 428i FMIC should fit 420i as long as both are using n20?
      12-04-2019, 03:15 PM   #36
330i_sportshadow
Costa Rica
Piston:
Rear Exhaust:
Transmission:
Driveshaft:
Front Muffler:
FMIC
That's true, that's why I am asking the question on the previous post. I saw part number and wheight differences.
What I am thinking is that maybe part numbering is different considering that versions are EUR and US?
      05-07-2020, 11:22 AM   #37
brianpalvarez
Drives: 2016 F30
- the '28+' tune
Stock 420i: 117.5kw
How does it drive?
Next steps
Pricing
Totally interested! Please email me the link to see more about this tune. I purchased a 320i a year ago and would love to explore the chance to add that much HP to my 320i as a 328i would have. Let me know! brian@stage1films.com thanks!
320, 420, bmr autowerkes, sydney, tuning
