09-12-2017, 10:29 PM | #23 |
DINAN SELLER
147
Rep 530
09-13-2017, 08:15 AM | #24 |
Rep 1,637
09-15-2017, 07:55 PM | #26 |
Rep 49
The only member I've seen on here to do it successfully is sonyvein, and the only explanation her gave is that physically it is plug and play, but his programmer had to do some coding to make it work... and he is in China lol. I've had the F80 gear selector for a while but have yet to find anyone in the states that knows what coding magic would be required.
09-24-2017, 11:09 AM | #27 |
Rep 19
Would it require coding if you just went for the looks? I do not need the "sport" programming, just want to get rid of the "legacy" (E60) look in a 2016 car
Like MaxBlast, I'm driving a 330e |
09-24-2017, 04:29 PM | #30 |
Rep 616
01-19-2018, 02:43 PM | #31 |
Rep 60
Hi, one question please. I have a stock 2TB shifter but there seems to be an error in its ECU because led light that shows gears goes off time to time and only comes back on after car goes to sleep. I have read on the internet that there is no fix for that, just replacement.
According to ISTA+, when replacement is done programming has to be performed. Is that necessary or not? I am asking because I do not have ISTA-P and if that is correct I would have to visit my dealer. Or could be done via ESYS?? Thank you! BimmerSI |
02-18-2018, 02:48 AM | #32 |
Rep 65
Does anybody know if the Gear selector switch, Sport from the F10 F11 F12 F13 F06 F25 will fit in a BMW F3x? REALOEM say it doenst, but if I compare these two... the look the same.
02-18-2018, 12:58 PM | #33 | ||
Rep 10,473
Even though below is the DCT shifter, the same issues apply with the 2TB shifter, which is why realoem correctly says it will not work. Last edited by IK6SPEED; 02-18-2018 at 01:06 PM.. |
04-13-2018, 09:34 PM | #35 | |
Rep 1,953
Drives: 2013 328i xDrive
It won't go any higher because the trim is in the way but not sure how to move it out of the way. |
04-13-2018, 09:37 PM | #36 | ||
Rep 10,473
04-13-2018, 09:39 PM | #37 |
Rep 1,953
Nuts, the only real way to get to it is to move the trim but I'm afraid of breaking it. I've already broken a mirror and door handle..
ArizonaErik95.00 |
04-13-2018, 11:20 PM | #38 | |
Rep 10,473
You talking this screw? I thought you were talking something else on the left side of the shifter. That one is easy. The cosmetic trim piece has to come out. It really is easy. However the retaining screws need to come out and one is under the buttons....which need to come out. For a quick change, I don’t even take it all the way out as 12v for lighter and the keyfob receiver need to be unplugged for that. I just tilt it up and quickly take out bolt (or reinstall bolt). Last edited by IK6SPEED; 04-13-2018 at 11:37 PM.. |
04-14-2018, 06:19 AM | #39 | |
Rep 1,953
04-14-2018, 10:16 AM | #40 | |
Rep 10,473
Kailec594.50 |
04-14-2018, 10:59 AM | #41 | |
Rep 1,953
04-14-2018, 11:33 AM | #42 |
Rep 10,473
04-14-2018, 12:03 PM | #43 |
Rep 1,953
No worries! I think I may have bent the plastic slightly. Wasn't paying attention before but it's not 100% flush with the shifter trim. Not visibly apparent though
04-18-2018, 02:27 PM | #44 |
Rep 49
Hey guys, thought I'd give you a little update. I found a good deal on an F80 gear selector so I decided to just plug it in and give it a shot. It works! Well, kinda haha. It throws an error message which you can bypass (maybe coding could get rid of it altogether), and manual shifting semi-works. You can upshift and downshift, but the car won't stay in M or S mode, it just kicks you back to D. As far as the lack of a Park button, I just turn the car off and it goes into park. Definitely still needs some work on the coding side, but I'm glad to find out that it can potentially work.
