      06-12-2012, 03:11 PM   #177
demge01
demge01's Avatar
Drives: F30 320ed
Originally Posted by svache
Originally Posted by demge01 View Post
Hi, I've taken the plunge and have an ENET cable on the way plus I have downloaded the E sys program successfully.
I've tried to start downloading the datafiles but the first one gets half way through and then fails?
I've followed the link in the text file and paid the extra for faster download times.
Any one else?
Could be a glitch in Rapidshare.. I just tried the first file and it downloaded with no problem. Perhaps you could give it another try later today or see if any of the other files show the same problem?
Also, make sure you have enough free space on your hdd.. the total space needed is about 10gb for all files, each file is about 480mb.
No probs on the space on the hdd.
Download manager has done the trick!
Might need some more help on file save location and where to save/copy as I'm not a techie!
Excellent thread this.
      06-12-2012, 03:26 PM   #178
svache
svache's Avatar
Drives: 2012 F30 328i
Originally Posted by RASHID007 View Post
I was hoping that to just be able to use the regular white apple cable wouldn't require extra hardware. I do expect that extended Bluetooth would require hardware.
Ahh that's what you want to do. Hmm.. I don't know if this is possible to code, or if there is still some need for the additional hardware. Thing is, the Y cable has a separate output for audio which might indicate that cars without that specific option might have a different connector thingie underneath the armrest than those who do have the option, and then you wouldn't be able to code it.
The only thing I can advise is to try it yourself
      06-12-2012, 08:41 PM   #179
johntchow
#beastmodeallday
32
Drives: 2024 iX M60
I have to admit, a lot easier than I thought. whoever made the analogy to editing the windows registry is pretty dead on.
There should be a thread detailing each function and what it does. Basically like your cheat sheet but one that the community can add on to....
Now on to our f25 which has the tech package!
      06-12-2012, 09:00 PM   #180
dcshoes23
Drives: 2012 328i
How long does it normally take for your car to be detected after turning on the car but not the engine? mine doesn't seem to get detected but the lights flash on my network port. Windows says the network cable is unplugged. Any suggestions?
      06-12-2012, 09:06 PM   #181
Raspartan
Drives: F15 X5
Very quickly in my experience. No more than a few seconds. Bad cable?
One thing I did when I built my cable was to pull out the trusty multimeter and test each pin and also the resistor.
      06-12-2012, 09:13 PM   #182
svache
svache's Avatar
Yeah making a connection shouldn't take any longer than 30 seconds max, usually faster. I agree with Raspartan, it might be worth it to check the cable
      06-12-2012, 09:35 PM   #183
dcshoes23
Drives: 2012 328i
checked the cable, seems fine, resistor is reading 503 Ohms, is that fine? I'm thinking it''s a problem with the laptop i'm using, it's my work one and they have a bunch a crap that takes over the network interface for vpn and what not. Going to try with a mac laptop and if that fails, I'll need an extension cord for my old laptop that can't hold a charge anymore.
      06-12-2012, 09:45 PM   #184
Silver F30
Silver F30's Avatar
Drives: F30 Sportline
Hello all. I have a F30 Sport with a 6 spd. I work in the service department at a BMW dealer. I have access to the coding cable that the techs use. They don't want to help me with much because they are afraid of losing their jobs. I am about ready to start coding after almost a week of downloading the files from rapidshare. But here is a question. I am a little unclear as to what to do with the .rar's. When I unpack them I get an error every file is this normal? Again a step by step guide for what to do with these psdzdata files would be AWESOME! I'll let you guys know how easy this is with the dealers cable.
      06-12-2012, 09:49 PM   #185
johntchow
#beastmodeallday
32
Drives: 2024 iX M60
ive got a lenovo and i make sure to disable wireless first. lenovos have a network manager that depending on configuration will only allow one wired or wireless adapter to work at a time.
but yeah, my connection only takes a few seconds to connect to my laptop
      06-12-2012, 09:50 PM   #186
johntchow
#beastmodeallday
32
Drives: 2024 iX M60
make sure to have all the rars downloaded first and in the same folder. when you unpack the first one it looks for the second and so on in the sequence. so you need them all downloaded first. once it unpacks them all it will put the files/folders together the way they need to be.
      06-13-2012, 12:46 AM   #187
Raspartan
Drives: F15 X5
I get pretty close to 511 oms (510/512) in both cables that I ended up building, but I think 503 should be fine for this. As far as I know the car connection is TCP/IP so you're probably right about the network adapter configuration on the laptop end.
      06-13-2012, 01:54 PM   #188
dcshoes23
Drives: 2012 328i
Ya, it was the laptop, tried another one and it worked right away. Thanks everyone for your help!
      06-13-2012, 04:02 PM   #189
svache
svache's Avatar
btw guys, if you discover new things, or changed some things, that I didn't put in the cheat sheet yet, please list them here (together with the values and where the options are located) so I can add them to the cheat sheet, thanks
      06-13-2012, 11:06 PM   #190
Raspartan
Drives: F15 X5
Coded some additional traffic info settings today in an attempt to get the traffic to show up. We'll see tomorrow.
      06-14-2012, 04:04 AM   #191
svache
svache's Avatar
Btw, for those who were interested in having their E series coded, please see this thread: http://www.e90post.com/forums/showthread.php?t=451145 and in particular, this post: http://www.e90post.com/forums/showpo...8&postcount=15
      06-14-2012, 04:17 AM   #192
CasZy NL
CasZy NL's Avatar
Netherlands
17
Drives: M4 | X5 | Z1
2008 BMW X5 35d  [10.00]
2015 BMW M4  [10.00]
1991 BMW Z1  [10.00]
I think all of this is amazing! BMW dealers should offer the change of these preferences themselves! Will definately ask my Amsterdam dealer, however their response is probably NO....
Anyway, good work!!
      06-14-2012, 05:52 PM   #193
08bmw128i
Drives: 2018 X5M
F10
Would anyone know how to code the rear camera to stay on when you activate it while driving? I have a 2012 f10 and would love this feature.
      06-14-2012, 07:43 PM   #194
rayseng
Drives: F10 M5
traffic infro
Hi, how's your coding for traffic info?
      06-14-2012, 08:15 PM   #195
svache
svache's Avatar
Here ya go:
PDC -> 3009 -> V_SCHWELLE_1 -> Werte = FF (max speed to disable top camera view, default 24)
PDC -> 3009 -> V_SCHWELLE_2 -> Werte = FF (max speed to disable rear camera view, default 0F)
PDC -> 3009 -> D_SCHWELLE_1 -> Werte = FF (max distance in meters to disable top camera view, default 32)
PDC -> 3009 -> D_SCHWELLE_2 -> Werte = FF (max distance in meters to disable rear camera view, default 0A)
Only downside is with this that the speed cutoff gets disabled but the distance cutoff not. So after about 255 meter or about 0.2 mile, the camera will still shutoff. They haven't found a fix for this yet (I'm unsure if they're actively searching for this, though).
      06-14-2012, 09:02 PM   #196
Raspartan
Drives: F15 X5
Didn't seem to have any effect but I think I need to test for one more day. Here in Toronto the RDS traffic is only broadcast Monday to Friday 6am - 7pm, so tomorrow is the last day of the week that I can test.
      06-15-2012, 06:25 PM   #197
omarliendo
Drives: 2012 335i Sport Line - Red
Svache, i am looking at the "Installation" file for the E-sys and i need clarification on step 5. I did download all of the 24 "2_46.3_psdzdata.partX" files but now i need to copy the 7 folders that are inside every single one of the 24 "2_46.3_psdzdata.partX" folders into C:\ESysData\psdzdata\ folder?
Am i reading this correctly?
      06-15-2012, 07:17 PM   #198
johntchow
#beastmodeallday
32
Drives: 2024 iX M60
after you extract all 24 rar files it will package together a folder with 7 subfolders. you need to move those 7 subfolder into the C:\ESysData\psdzdata\ folder
