03-31-2014, 07:28 PM | #1 |
Rep 68
Drives: F30 328i Sport
N20 Blown Turbo - Blowing White Smoke - Video
Noticed my 328i was blowing a little white smoke during a cold startup. I was going in for a scheduled oil change anyway so I snapped this video to show my service advisor.
I dropped it off saturday and they just called me and said I won't have it back for a few more days because they are replacing the turbo. It's weird to me because it wasn't down on power or throwing any codes. Maybe a seal or something? I drive the car like it was designed to be driven. Only 2-3 times a week and sometimes a little spirited driving on the way. But nothing crazy. Anyone else having any reliability problems with the N20? |
04-01-2014, 03:11 PM | #4 |
Rep 1,369
I'm not an expert by any means but doesn't white smoke usually mean coolant is leaking into the exhaust? I understand how a turbo works but I'd be curious to know how white smoke appears from the exhaust due to a defective turbo. I guess if the turbo was blowing coolant into the engine that wouldn't be good. Let me guess . . . . coolant is circulated around the turbo and if the casing cracks, the coolant leaks and the turbo is toast?
Mind you, both from personal and from experiences shared online, stories of a dealer blowing smoke out their a*s is not uncommon. Any time any car I had with a technical issue went in for service, I always asked to talk to the tech working on it. Not all SAs are bad but I've run into a couple who couldn't tell you the difference between a walnut and a lug nut. |
04-01-2014, 03:16 PM | #5 |
Rep 1,369
Wasn't it designed to be driven on the Autobahn, a highway in which there are sections with no speed limit?
I thought the 328 was 'speed limited' to 200-250 kph? I think it's designed to go pretty fast and for more than a few minutes. A turbo that dies an early death I'm sure wasn't part of the design. |
04-01-2014, 03:22 PM | #6 | |
Rep 674
White spoke can be either oil or water/coolant but more than likely this is just a bad seal in the turbo. Bad valve guides/seals give off a similar symptom but would be a bit more unlikely I suppose... |
04-01-2014, 10:23 PM | #7 | |
Rep 129
if they are replacing the turbo because of white smoke = bad turbo seal and its burning coolant. |
M2_MEDUSA664.00 |
04-01-2014, 10:34 PM | #8 | |
Rep 68
04-02-2014, 02:34 AM | #9 |
Infidel
122
Rep 1,102
Did you have any aftermarket mods? (tune, DP etc)
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
04-02-2014, 10:06 AM | #10 | |
Rep 44
It is hard to see from the video quality, but if it is ONLY at startup, it could just be condensation if there is no blue in it. If you also start to notice an occasional puff sitting at a stoplight or idling long after startup then it is the turbo. What constitutes the "seal" in the turbo is stronger when the turbo is spinning, and weakest when the turbo is not and that is why you get seepage of oil when the car has been sitting for a period or when the car comes to a stop. Any car can get a defective turbo but my eyebrows always go up when someone says "I drive it like it is meant to be driven." If you beat on it, and shut it down hot, turbo life will be shortened. Last edited by vader1; 04-02-2014 at 10:51 AM.. |
04-02-2014, 06:57 PM | #11 | |
Rep 129
08-28-2014, 10:59 AM | #13 | |
Rep 33
08-28-2014, 11:17 AM | #15 |
Rep 648
[QUOTE=ntalekt;15700358]Noticed my 328i was blowing a little white smoke during a cold startup. ........
Could be many things. Can't wait to hear what the reason was. I have never hear of this, so I guess even a small fault would make BMW want the turbo back in order to investigate. Thus you get a new one. Warranty is a good thing. /Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
10-14-2014, 08:13 PM | #19 |
Rep 3
I have bluish smoke when I start my car up plus a rattling in the engine. Taking it to the dealer tomorrow to see what's the 411 on it.
Ntalekt did replacing the turbo fix ur problem? |
10-15-2014, 08:30 PM | #21 | |
Rep 1,490
Are you tuned?
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
10-16-2014, 12:45 PM | #22 |
Rep 190,687
Good thing it is covered
