08-18-2016, 02:53 PM | #288 |
Rep 31
I had that problem and found somewhere to download but can't find the link anymore even after going through my browser history.
PM me and I sort you out with the file.
435i GC with MPPK and MPE
08-30-2016, 03:17 PM | #290 |
Rep 1,455
Thanks to this forum thread I've successfully updated my 328i with Pro Nav to the latest maps.
I bought a cable from Amazon, less than a tenner delivered. I downloaded the esys software and maps from the provided links, it took around 8 hours to download the maps on my fairly poor internet connection. I followed the instructions carefully from the top of this thread. The first time I generated a key it did not work. This was because I had entered the command line for the base64 utility in lower case. It seems the parameters and hence VIN MUST be in capitals. I went into nav with the ignition on but engine off. I then put the first USB stick in, it takes perhaps 30 seconds before anything happens, then prompts for the key. After a while it will prompt for the second and third sticks. In total it took around 55 minutes to load all three sticks. Once complete the nav restarts - at this point the version information was blank. I believe this was because the third USB stick was still in the slot. Once removed and the nav restarted it reported the version as expected. I checked that a new postcode that I know wasn't in the original 2012 version worked (SA1 8EN) Job done ! If anyone local to me (Herts) needs any help with this or wants to use my esys installation let me know - am happy to pass on some knowledge gained here |
10-21-2016, 05:38 AM | #291 |
Rep 8,081
European NEXT 2017-1 is now out. Anyone know the modification that's needed in the XML file to generate the new code?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
10-21-2016, 06:00 AM | #292 |
Rep 40,664
0xA9 0X29
x-m4n148.00 |
10-21-2016, 06:05 AM | #293 |
Rep 8,081
Thanks as usual Shawn. So the relevant part begins:
<SgbmId id="NAVD_000014B9_255_002_185" SWID_FscShort="00A90029" name="Road Map EUROPE Next 2017-1"...... Is that right?
Ian
10-21-2016, 06:16 AM | #294 |
Rep 40,664
All that matters is "FscShort="00A90029" name="Road Map EUROPE Next 2017-1" The rest can be gibberish.
10-22-2016, 05:48 AM | #295 |
Rep 272
are you able to share the Loopup.xml with me and I don't really understand how to do it?
10-22-2016, 07:09 AM | #296 |
Rep 1,846
I've altered the XML and it says my generated key is wrong when I've come to update?
I added in the XML <SgbmId id="NAVD_000014B9_255_002_048" SWID_FscShort="00A90029" name="Road Map EUROPE Next 2017-1" supplier="NTQ" sop="01.09.2016" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> Last edited by Ajs_435d; 10-22-2016 at 07:29 AM.. |
10-22-2016, 07:45 AM | #297 | |
Rep 1,894
Start Tag: <Sgbmld End Tag: </SgbmId> Scroll down to the bottom of your lookup.xml and make a space between the last </SgbmId> and </LookupTable> and insert this in between: <SgbmId id="NAVD_000014B9_255_002_185" SWID_FscShort="00A90029" name="Road Map EUROPE Next 2017-1" supplier="NTQ" sop="20.10.2016" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> It'll end up looking something like this: </SgbmId> <SgbmId id="NAVD_000004D3_255_002_049" SWID_FscShort="002D0027" name="Road Map North America PREMIUM 2016-2" supplier="TAS" sop="07.28.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> <SgbmId id="NAVD_000014B9_255_002_185" SWID_FscShort="00A90029" name="Road Map EUROPE Next 2017-1" supplier="NTQ" sop="20.10.2016" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> </LookupTable> |
10-22-2016, 07:47 AM | #298 | |
Rep 1,894
10-22-2016, 08:16 AM | #299 |
Rep 1,846
10-26-2016, 06:09 AM | #301 |
Rep 1,455
There seem to be different release dates for different regions and versions
I loaded Premium 2016-2 Europe West a while ago Does anyone know when 2017 maps will be available for Premium (CIC Pro Nav) ?? |
10-26-2016, 06:09 AM | #302 |
Rep 1,846
10-27-2016, 03:44 AM | #303 |
Rep 2,046
I didn't see a link posted, could someone PM it to me? Please
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport |
10-27-2016, 03:58 AM | #304 |
Rep 766
There is a link to the very first post/page of this thread - the post hopefully get updated as we go.
But you can find links in the forum - if you search, you will find posts like this one http://f30.bimmerpost.com/forums/sho...postcount=1195 |
RichardM133.00 |
10-27-2016, 05:52 AM | #305 |
Rep 400
Drives: F30 LCI 330e M Sport
On my LCi with the OTA updates, it's telling me latest version is 2016-4, not 2017-1. Interestingly though, the OTA update never installs and I have to download them from the Connected Drive site.
10-27-2016, 06:53 AM | #306 |
Rep 1,846
11-19-2016, 07:32 AM | #308 |
Rep 40,664
00880029
