06-10-2018, 07:40 AM | #1 |
Rep 69
BimmerCode
New to this so after I download the app what is next to do some coding..I want to do a headlight coding so I don’t have flickering issues..Kind of step by step please..
Thanks |
06-10-2018, 03:05 PM | #2 | |
Rep 5,458
Drives: F30
You'll need a way for your car to communicate with coding software, first. |
06-10-2018, 03:59 PM | #3 |
Rep 16,144
06-10-2018, 04:56 PM | #4 |
Rep 69
06-10-2018, 05:19 PM | #5 | |
Rep 143
After that open up BimmerCode you will see the initial ECU read and automatic backup run for about 1 min. Once you see the ECUs menus just go to the ECU module you want to code and change the settings. You will see the "code" option enable after you change at least one setting. Hit that and wait for the Coding flush it done (usually 5-20s depends on ECU). Same process for each individual ECU. |
06-10-2018, 08:53 PM | #6 |
Rep 1,702
Drives: 2014 428i and 2018 X5
Did you even bother to read the BimmerCode Quick Start Guide???
That should be your first thing to look up. http://bimmercodeapp.com/support/
06-11-2018, 05:26 AM | #7 |
Rep 69
Looking at the selection for the adapters the one I have may not be to good..
The Vgate I Car2... Should I send it back and get a different one like the 4?.. Thanks Guys |
06-11-2018, 06:44 AM | #8 |
Rep 8,942
Ok I'll be the asshole and say it - Bimmercode has good instructions and is very user friendly borderline idiot proof. If you don't feel like you understand it don't mess around with your car you can get someone to do it for you for like $100.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-11-2018, 07:21 AM | #9 |
Rep 30
Hey man, I don't mean to be a dick but if you're not comfortable with bimmercode (it's pretty easy to use) then maybe don't do it, or pay for someone else to do it.
I had some issues where I lost idrive and it was a pain to get back, so proceed with care. Good luck! |
