BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Hub centric or lug centric?
      05-29-2012, 04:17 PM   #1
rmnoonan
Drives: F30 328I (July '12 ED)
I bought a set of oem 17" wheels to replace my 18's in the winter. I'm going to get the winter tires mounted tomorrow and am curious if I need to have a new centering ring installed? can they install the ring without the car present?
      06-05-2012, 01:50 AM   #2
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
While you probably already got the wheels installed, it doesn't hurt to answer in case someone else searches and comes across this thread
Newer OEM BMW wheels will have a center bore of 72.56 (72.6) - this is the same size as the hub on your vehicle. Thus, no hubcentric rings will be required for installation.
If hubcentric rings are required for wheels with a center bore larger than 72.6, the rings can insdeed be installed into the wheels without the car being present.
      07-03-2012, 12:25 AM   #3
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
What he said.
