02-11-2015, 02:42 PM | #155 |
Rep 280
Hey guys, has anyone got this to work on F32 with LED headlights?
FEM_BODY 3062 MAPPING_STANDL_V_L_PWM_LEVEL_1 32 8 Change Angel Eye Brightness when headlamps on (Left) FEM_BODY 3062 MAPPING_STANDL_V_R_PWM_LEVEL_1 32 8 Change Angel Eye Brightness when headlamps on (Right) |
02-11-2015, 06:11 PM | #156 |
Rep 42
02-11-2015, 06:19 PM | #157 |
Rep 5,316
Drives: G80 M3 6MT
Of course! Glad it worked
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
02-16-2015, 05:01 PM | #158 |
Rep 143
Did some coding today.
My I-Step is a bit low: F020-14-03-503 1. HU_NBT / 3000 / NAVI_FLIGHT (Makes the route simulator available under new menu "Route preview” - Part 1) This line is not found on my car, "part 2" is visible. 2. "HUD_LOGO", what does the different values show? I haven't seen any logo displayed on my HUD, so I guess I need to adjust the KOMBI / 3110 / HUD_STARTUP_TIME. 3. Can this be used to import your own POI? 4. I know my car doesn't have ASD (Diesel), but I tried it anyway. Got a new menu: "MINI engine sounds" And of course none of them work :P I coded the following: HU_NBT 3000 ASD_CONFIGURATION HU_NBT 3000 ASD_SOUND_1 HU_NBT 3000 ASD_SOUND_2 HU_NBT 3000 ASD_SOUND_3 HU_NBT 3000 ASD_SOUND_4 |
02-17-2015, 01:19 PM | #159 | |
Rep 280
"Enable the alert POI funktion and the MMI shows an additional check box / button In the option menu." Somebody now "just" have to figure out how to import POIs and set them to alert POIs (speedcams) |
02-19-2015, 06:12 AM | #160 |
BMW Fanatic
331
Rep 1,076
Hey guys, a slightly off-topic question, but my dealer here in Lebanon does nothing to the computers of the car during checkup and routine inspections (Doesn't check for newer versions). I do know for a fact that Audi do check for updates for their MMI and they do update them. Is there anyway I can get the dealer to upgrade to a newer I-Step? I am also not really sure what I-Step version I have but my gut feeling is telling me it's old haha (They won't do anything to it unless BMW explicitly tells them to, they're really careful about messing around with the computers)
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
02-19-2015, 08:12 AM | #161 |
Rep 1,035
I'm at I-Step F020-13-07-506 |
03-10-2015, 03:57 PM | #162 |
Rep 143
03-10-2015, 05:25 PM | #163 |
Don't care
117
Rep 224
Part 1 is HU_NBT 3000 NAVI_FLIGHT>aktiv
If you don't have NAVI_FLIGHT look for ROUTE_FLIGHT. Last edited by TMD29; 03-10-2015 at 05:35 PM.. |
03-12-2015, 03:21 AM | #164 | |
Rep 143
Tested and preview is working now. I also found an option "Free text search". I enabled it and I got it in my Navi-menu. But when I try to search, I don't get any hits, the "page" is just empty. Anyone else tested this? And, I tried to enable "Navi auto zoom", and it show up in my splitscreen menu, but it's greyed out. Can anyone confirm if HUD turnsignals is working on F30 or not? |
03-12-2015, 05:53 AM | #165 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
03-12-2015, 04:39 PM | #167 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
These really do add a bunch to Nav system!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
03-12-2015, 04:48 PM | #168 | |
Rep 1,479
Before my car's I-Step was updated (shipped I-Step was F020-13-07-503), Auto zoom worked fine. If I had a destination programmed into Nav system, when I approached intersection, map would zoom in and then zoom out after the intersection. Seems to me that there were two items in HU_NBT> 3000 HMI that I coded to aktiv from nicht_aktiv:
Even though I have both still set to aktiv, can NOT get this function to work, current I-Step is F020-14-07-505 Was wondering if anyone has figured out how to get working again myself
Al
04-07-2015, 02:11 AM | #169 |
Rep 13
Drives: 440i (F36) 2018
Enable taillights as Day-Run Lights
I can confirm that the following activate the taillights as DRL:
REM 3062 MAPPING_TAGAHRL_H2_L_OUTPUT sl_2_l off Turns On Left Tail-light (Inner Part) on with DRL REM 3062 MAPPING_TAGAHRL_H2_R_OUTPUT sl_2_r off Turns On Right Tail-light (Inner Part) on with DRL REM 3062 MAPPING_TAGFAHRL_H_L_OUTPUT sl_l off Turns On Left Tail-light (Outer Part) on with DRL REM 3062 MAPPING_TAGFAHRL_H_R_OUTPUT ls_r off Turns On Right Tail-light (Outer Part) on with DRL You don't need to activate those: REM 3063 MAPPING_UNIVERSAL_6_OUTPUT sl_2_l off Turns On Left Tail-light (Inner Part) on with DRL REM 3063 MAPPING_UNIVERSAL_7_OUTPUT sl_2_r off Turns On Right Tail-light (Inner Part) on with DRL (haven't tried them, don't know if they would work too ) Thanks Halsifer for the cheat sheet. Great work |
04-09-2015, 03:25 AM | #170 |
Rep 15
Wonder if this can be added to the cheat sheet, as I am sure it will help others.
In order to add Driving mode configuration for NBT, all you need to do is FDL code Macro_FDS and the Icmkod_b_sportsindividualisierbar. http://f30.bimmerpost.com/forums/sho...3&postcount=52 All hail to robg |
04-09-2015, 08:17 AM | #171 | |
Rep 1,479
I have enabled Navi_Alert_POI by coding: HU_NBT >3000 HMI > NAVI_ALERT_POI > from nicht-aktiv to aktiv This function adds an Along Route Option to POI menu item (circle with a dot in center) on left edge of map; I have found it useful. Am not sure anyone has figured out to be able to import POIs -- sure would be nice
Al
04-09-2015, 08:22 AM | #172 | |
Rep 1,479
Here's an alternative to free text search option, perhaps. Code: HU_NBT > 3000 HMI > GOOGLE_LOCAL_VOICE_SEARCH > from nicht_aktiv to aktiv. This enables local voice Google search (as long as you do not have map displayed) by saying "POI" -- at least the US version does so Sure do wish AutoZoom worked again
Al
04-09-2015, 11:25 AM | #173 | |
Rep 280
I had enabled it once but was apparently to blind to find any differences Are you able to take a pic of this? |
04-09-2015, 01:45 PM | #174 | |
Rep 1,479
Please see attached; you have to have a destination input for this to work. As you progress along your route, you can see POIs of the type that you have selected. Attached are five phone pictures (so pardon the quality) that show screen shots as you work down the menu Hope that demonstrates it well enough
Al
04-24-2015, 01:10 PM | #175 |
Rep 413
every time i read this guide i think...oh my god how fantastic is...
I hava a question, i try to code ACSM to reduce seat belt reminder...when i go inside the value, it is already WERTE 01...can anyone explain what i do wrong?? thanks!! |
04-24-2015, 01:14 PM | #176 |
Rep 40,752
You change only the Drop-Down Box Values and let it change the Werte Value accordingly. Do not worry if Werte Value it chooses does not match some cheat sheet.
