10-19-2012, 03:30 PM | #89 | |
Too much is never enough
655
Rep 3,079
I personally don't think it really matters WHERE it's built, but rather WHO is overseeing the operation. It's not like they're subcontracting the build out to a 3rd party. It's still BMW building the cars. Only the folks holding the screw drivers and pounding the plastic clips in are different. I really think the only issue is the lengthier trip to North America. |
10-19-2012, 03:31 PM | #90 | ||
Rep 3,780
That's part of the appeal to me. My other car is sitting at about 500hp at the crank right now. It impresses me when I average 20mpg. I am confident the N20 will net me 285-300whp and still average 30mpg.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
10-19-2012, 03:35 PM | #92 | |
655
Rep 3,079
I seem to recall hearing that BMW did in fact put a moratorium on ED orders outside of dealer allocation recently. I have a feeling that they're having a tough time getting plant capacity ramped up to meet demand. Since ED doesn't come from allocations, it's difficult to predict demand and schedule production. By forcing dealers to use their allocations they can better control demand and strike the balance they need between the various models at the plant. |
10-19-2012, 03:35 PM | #93 |
Rep 3,780
10-19-2012, 03:41 PM | #95 | |
655
Rep 3,079
I haven't been following N20 aftermarket developments so I didn't realize how much progress the vendors have made. I'm getting a bit below 20mpg in my current car. Dependent of course on my restraint and drive cycle. Once I get around to installing my 6 speed box I expect I'll be able to reach the mid-20s. But I suppose it's obvious fuel economy isn't a top priority when you're running around in a blown V8. |
10-19-2012, 03:47 PM | #96 | |
Rep 3,780
I have 100more hp in there before I have to look at creative things like internals. I think 460+whp will be a bit retarded in a car a bit larger than a Miata. On a Mustang Dyno on the base tune after install I did 380whp at 13psi with a maf issue. So even in it's crappy state I am 400+ on a Dynojet. Fix the maf, bigger injectors, upgrade the head gasket, re-orient the bypass valve(worth a psi), upgrade the center exhaust and cats, 16psi...I should be there. YAY for taking this even more off topic :P
10-19-2012, 04:11 PM | #97 |
S0THPAW
8717
Rep 7,846
10-19-2012, 04:31 PM | #98 | |
655
Rep 3,079
I'm all about tangents! I agree, there's a limit to what you should logically run in a given chassis. I assume you're referring to the Roadster in your sig. Power that you can't use isn't very useful. I'm about at the useful limit in my car at 15 pounds. I'm running a twin screw so it's very easy to manage the power on the street. Hell, if I'm just putting around I don't even get into the boost. The motor has plenty of torque on its own. But it's always nice to know what's there waiting for me. I didn't really spend a lot of time on it when I tuned it. I mainly wanted to make sure the pistons didn't ooze out of the tail pipes. I installed a dual fuel pump, big injectors and a larger MAF to make sure it has plenty of fuel when it needs it. I already had long tube headers, full exhaust and high flow "cats". After the blower was installed the cats might as well be actual feline cats. They'd be just as effective. And, your first guess was correct Apologies for taking the thread even further off topic! |
10-19-2012, 04:53 PM | #99 | |
Rep 3,780
I figured it was a Mustang as you said 6spd swap, remembering only the very recent '11+ feature 6mts. I drove a co-workers '07 GT 5mt only a couple of months ago. Long hood, big car, I was imagining what a couple hundred more hp would do to transform it into something quite fun. Two spots over another friend has a Bullit and we have an SS Camaro. Lot's of car guys at work.
10-19-2012, 05:26 PM | #101 |
Rep 867
Not mind at all~~ Enjoy ur 4 banger~~
2022 BMW X4MC
2018 Tesla Model X 100D Last edited by Sharp_Cai; 10-19-2012 at 05:44 PM.. |
10-19-2012, 07:25 PM | #102 | |
655
Rep 3,079
I had a '95 Z/28 myself. Over time it became more of a track car than a street car. I really loved that car. Interestingly, it was actually that Z/28 that got me into BMWs. With two of us driving the car hard (my wife and I are both HPDE instructors) I was wearing out or breaking parts every weekend. The last straw was following a 3-day event at Summit Point which consumed 6 tires, 2 sets of Hawk Blue front pads, a set of Hawk Black rear pads, both front hubs and an axle bearing. THAT was an expensive weekend. I had a decent suspension and ZR1 brakes so it handled and stopped great. But it was so heavy that the components I couldn't upgrade just couldn't take it. Did you know the front hubs are actually rear hubs from a Pontiac Bonneville? It's funny the things you learn as you go. My current track car, an E28 535is, was sitting on the front lawn of the house across from my office. I did a little investigation to see what these little BMWs were all about...and the rest is history. I think my new F30 will be my 12th BMW in 12 years. I'm glad to see there are other guys on here with an eclectic mix of cars like me! |
10-19-2012, 07:54 PM | #103 |
Rep 533
"The 328i is better than the 335i.
We are not the only ones claiming that the entry-level BMW 3 Series, fitted with a clamorous lightweight turbocharged four-cylinder engine, is more agile and tossable than its turbocharged six-cylinder sibling – it appears to many that the segment leader has been displaced by its weaker brother. The 328i is objectively superior to the 335i because it is significantly less expensive, more fuel efficient, better balanced, lighter and nearly as quick (BMW says the 335i 6MT will do 0-60 in 5.4 seconds while the 328i 6MT does it in 5.7 seconds). In an un-biased and non-emotional decree, most everyone should choose the four-cylinder 328i over the six-cylinder 335i." Emission's Autoblog Review http://www.autoblog.com/2012/03/30/2...w-335i-review/ BJ |
10-19-2012, 08:03 PM | #104 | |
Rep 475
Well know for sure in a couple of weeks. |
10-19-2012, 09:13 PM | #105 |
Rep 537
Drives: 2013 335i M
335 all day, not sure i would spend that amount on a 4cyl. Yet i admit, never test drove a 328.
M5 with lots of goodies
10-19-2012, 09:24 PM | #106 | |
Rep 3,780
I always have a thing for cars that are kind of seen as underdogs.
10-20-2012, 12:05 AM | #107 | |
Rep 518
On another note. SA vs. Germany. I would be lying if I said I'd rather have a SA build. That being said, if BMW is putting their name on it then that's good enough for me. To try to denegrate the cars made in SA is just asinine, especially when the people saying this have ZERO experience or facts about German builds being better when they have no freaken idea or evidence of this. It's just ignorant. |
10-20-2012, 03:51 AM | #108 | |
S0THPAW
8717
Rep 7,846
Well said. +1. And the SA vs Germany thing is super super ignorant to say the least! What I read from E90Fleet(from SA) and many members overhere from SA, the total quality of the SA BMW plants is even better than the already superb quality of the German BMW plants.... Cheers Robin |
10-20-2012, 11:39 AM | #109 | |
Rep 307
But in the back of my mind was knowing it's a 4 cyl and when the time is called for some serious HP the 335 was going to deliver. The 335 has earned the respect of being called a high performance machine. It's not a M, but it's in the same neighborhood with a few mods. I personally think it’s great more 28's are in the game of getting serious about performance and handling. It will get more vendors making parts which in most cases will apply to both cars. I think the F30 has changed the dynamics of 328 to 335. I have taken some crap for driving a 3 series, which some call a "girl's car", to a better understanding of what these cars are all about. I had to justify my E90 3 series to some called “friends and enthusiast” by saying it's a 335, it’s not a 328…. Then 1 day later I see a 76 year old grandmother driving a Sport Model 335 in the CVS parking lot! And I just smile. I went with the 335 because I wanted to know if I needed it, I had it... And maybe in the back of my mind I was dealing with the old E9X 328 vs. 335 stigma. Most HP cars on the road don't speed from stop light to stop light. They cruise with the attitude, "You know I got it if needed"... That what I like and why I went with the 335... |
10-20-2012, 01:07 PM | #110 |
I saw the light!
Rep 269
I was all set for my 328 MSport. Had already talked to the dealer about it. Then I did the drive for Team USA and drove them back to back. 328 is plenty of car for 99% of people, myself included, but that test drive made me go big. It's the first time I went with the bigger engine in a car, and I didn't regret it on my Nordschleife laps, Autobahn runs, or Grossglockner corners. It's overkill, but fun.
Even though mine is a Munich build, the SA built cars are just as good, if not better, in build quality ratings. At least according to the founder of Bimmerfest, whom I trust.
2013 335i F30 M Sport (ZMM, EBII, ZDH, ZTP, 2TB, 688) My ED Trip
2002 E36/7 Topaz Blue Roadster BMWCCA Member ID: 456926 |
