12-09-2014, 08:22 AM | #815 |
Rep 817
Drives: E30 M3 Darth Vader Trackcar
Guys its very simple. The rubber seal at the top corners of the driver and passenger doors has a gap under it when the windows are rolled up. If you put a folded up piece of paper in the interior corners while driving all of the "wind noise" that sounds like an open window is gone. I'll be going to the dealership to shown them and ask how they want to fix it.
T Ill try to get a pic for you today. Here |
12-09-2014, 10:06 AM | #816 |
Rep 4,979
I may be in the minority, and maybe it's because I have a MY2015, but the wind noise is almost non-existent unless I pay attention. Coming from a 2011 E90 it's like night and day.
The turbo drone on the other hand...
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
12-09-2014, 12:58 PM | #817 | |
Rep 817
T |
Duke3D3.00 |
12-09-2014, 02:00 PM | #818 |
Rep 623
Wind and tire noise is there for sure, on all F30s. How much one perceives it or is bothered by it, that's a different matter.
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara |
12-11-2014, 12:38 PM | #819 |
Rep 817
Here is the test that passed with flying colors. With the SIB for the windshield trim and somehow fixing these moldings, there will be minimal wind noise.
T |
12-11-2014, 03:57 PM | #821 | |
Rep 817
The parts installed were: 51 13 7 321 818 B1-Clip (Qty 10) 51 31 7 258 187 B1-Drip moulding, left (1) 51 31 7 258 188 B1-Drip moulding, right (1) http://realoem.com/bmw/showparts.do?...51&fg=70&hl=23 |
12-12-2014, 12:04 PM | #822 | |
Rep 127
2012 335i | silver | Sport | Premium | DHP | Lane Departure | Nav
12-12-2014, 12:21 PM | #823 | |
Rep 1,892
I mentioned the SIB for the windshield trim and they refused to install it; they said there was nothing wrong with mine. Took my car to another dealer and complained about the wind noise and they immediately installed the SIB. The noise was greatly reduced, but not as quite as other F30's I've driven in. I've subsequently complained about the wind noise every time I take it in for server, but it anyways comes back normal behavior, no trouble found. I've just learned to live with it by turning the radio up. |
12-12-2014, 12:22 PM | #824 |
Rep 1,568
I tried this a couple of months ago. Actually taped the entire window/frame joining areas on both front doors with no difference noted. My wind noise begins around 45-50 mph and increases from there.
Does anyone have the text for the SIB mentioned? I took the Dealer Service manager for a drive during my last service appt. back in Sep. He agreed the noise is there and said that he has heard it in many of the F30s. He checked BMW's database and nothing was shown there addressing the issue Real annoying. |
12-12-2014, 12:52 PM | #825 | |
Rep 1,892
I tried your paper test (what a great idea!) and noticed the same behavior. It's very tight at the top and sides, but very lose at the bottom. I'm trying some ideas (currently using 3/8" backer rod stuffed into the of the door frame seal "U" area all along the bottom) and will report after I've had enough time to test it. Initial results are excellent, but I need to do more testing. Background: My wind noise is intermittent; sometimes it's very quiet, other times the wind noise is really loud. It's not road / tire noise, that's a different sound. I've had the windshield trim fix and the outside windows trim gap fixed (as previously posted), but I still have what I would call intermittent, but significant wind noise. I've always suspected that it's the door seals not making strong enough contact, but I have not been able to prove it. I don't think it's the door alignment (mine looks perfect), but possibly a misaligned / mis-installed seal installation on the door. I just couldn't figure out a way to verify it. The paper idea is brilliant! A misaligned seal might explain the intermittent noise; sometimes the door seals just enough to prevent air from getting through, but sometimes not. I have mentioned my misaligned seal theory this to my SA, but he said that the seals have pins on them so that they can't be misaligned. But, looking at RealOEM, I don't see the pins on the picture of the seals and there is a note saying that a set of templates must be ordered along with the seals; so if you need a template to install them, then I'd guess there aren't any pins! If the backer rod fixes the issue, I will definitely report this to my SA and try to get him to have the door seals re-installed / replaced. |
12-12-2014, 01:02 PM | #826 | |
Rep 1,892
I've tried taping the windows, the sunroof, etc. No change. So, at least for me, I think it's leaky door seals. I've been on many test drives with the SA and the mechanic, they either say it's normal, or they don't hear anything. When I tell him I've been in several F30's that don't have any wind noise at all, he just shrugs. I've also asked him to look it up on their computer, but he says there is nothing about the issue there. |
12-12-2014, 01:33 PM | #827 | ||
Rep 4,979
12-12-2014, 01:47 PM | #828 |
Rep 817
I don't know how more simple to explain it then this. It is not the door seal. Wind is getting in up under the window sill on the outside. the edge of the window is not touching the back of the track so the wind goes around the back of the track and comes through the corner. If you watched the window when it is raining you will see a low-pressure zone all the way across the top of the window right back to where the gap in the seal is. There's a major low-pressure zone there in the noise you're hearing is the air being sucked out of the car up through the corner of the window. Here's a video of exactly what I'm talking about.
Put headphones on and listen to it see you can hear exactly what it sounds like in the side of your head while you're driving on the road. I drive 4000 miles a month and it's driving me crazy. |
12-12-2014, 04:09 PM | #830 | |
Rep 817
12-12-2014, 05:35 PM | #831 | |
Rep 1,267
12-12-2014, 06:10 PM | #832 | ||
Rep 817
12-13-2014, 01:53 PM | #833 |
Rep 2,266
Yes the back of the front window is tight against the glass. If I run my fingernail along it, it's very uniform.
F30 Sapphire Black M-Sport 335i 6MT
12-13-2014, 01:56 PM | #834 | |
Rep 817
T |
12-13-2014, 09:03 PM | #835 |
Rep 588
Drives: F30 320d & G29 M40i First Edtn
Mangler have bmw resolved this gap for you?
12-13-2014, 10:29 PM | #836 | |
Rep 817
noise, wind noise, wind-noise, windnoise |
