BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > TRSVC module pinout?
      07-25-2015, 01:31 AM   #1
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
Hello,
Can anyone share some insight on what pins 1 - 10 is for on the TRSVC module?
I'm looking to retrofitting surround view in my car and i have everything except i have no idea where to tap the wires into.
maybe shawnsheridan has some insight?
Thanks!
      07-25-2015, 04:56 PM   #2
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
I'm getting ready to do mine too, but for the rear cam...
The installation manual for the rear camera shows where the 10-pins tap into. There's detailed info on how/where to run the wires. I attached the PDF document at the end of this post...
Actually, only 7 physical wires are used in that 10-pin connector. Rheingold shows them as pins #1 - #7, but the instruction manual labels them as A2 - A8. In either case:
A5 or A167*2B pin #1 (brown-BR) - ground --> to any good grounding post
A3 or A167*2B pin #2 (red-RT) - FBAS+ --> PIN21 A42*1B at NBT head unit
A2 or A167*2B pin #3 (white-WS) - FBAS- --> PIN24 A42*1B at NBT head unit
A4 or A167*2B pin #4 (clear-Shield) - shield --> PIN23 A42*1B at NBT head unit
A6 or A167*2B pin #5 (orange/green-OR/GN) - KCAN --> FEM A173*8B PIN52
A7 or A167*2B pin #6 (green-GN) - KCAN --> FEM A173*8B PIN51
A8 or A167*2B pin #7 (green/blue-GN/BL) - +12v pwr supply --> to Rear Fuse Blk Z2*6B PIN6
EDIT: (7/26) - some of the A* labels for the wires from BMW instructions were mixed up - fixed now
File Type: pdf BMW EBA 361831 Rear View Camera Retrofit Instructions.pdf (428.8 KB, 4332 views)
      07-25-2015, 05:17 PM   #3
Chris@codemybimmer
A2 or A167*2B pin #1 (brown) - ground
A3 or A167*2B pin #2 (red) - FBAS
A4 or A167*2B pin #3 (white) - FBAS
A5 or A167*2B pin #4 (clear) - shield
A6 or A167*2B pin #5 (orange/blue) - KCAN
A7 or A167*2B pin #6 (green) - KCAN
A8 or A167*2B pin #7 (green/blue) - +12v pwr supply
Thanks a lot!
i dont know how you people find anything on rheingold lol
i can NEVER find what i want to find
