08-28-2014, 05:37 PM | #1 |
Rep 335
F10 wheels and tires
From what I've read here, it seems this will work, but a reality check would be really helpful. I have a chance to pick up a set of wheels and tires and want to be sure that there won't be any issues with them on my F30 xdrive. It appears that these are about 2% taller than OEM and there is a difference in the F and R diameters of 0.6%...I've never seen an exact spec for how close this has to be for xdrive.
F: 19x8.5 ET 33 - 245/40 R: 19x9 ET 44 - 275/35 If anyone could point me to a picture with similar wheel/tire size on an F30 AWD or RWD, I'd appreciate it. |
08-29-2014, 08:44 AM | #2 |
Rep 5,140
Here is two members with 20" F10 wheels, the offsets and the tire widths is exactly the same as on 19".
20" style 356 and 373 for F10: F: 8.5x20" ET33, 245/35-20 R: 9x20" ET44, 275/30-20 F30 335i with 20" oem style 356 Gorgeous: f30.bimmerpost.com 328i Msport with 20" style 373M on HR sport: f30.bimmerpost.com |
08-29-2014, 12:28 PM | #4 |
Now in the dark side !
65
Rep 1,136
On 20" wheels, the closest match for front and rear tires are:
F 235/35R20 - 26.48" R 275/30R20 - 26.50" This is the exact setup I'll have on my car. The 245/35R20 are 26.75" high, original 225/40R19 (on my car) are 26.09" Usually, I don't exceed +- .5" (about 2% difference, depending on tires size) For the 19" wheels: Original: 225/40R19 - 26.09" F 235/40R19 - 26.40" F 245/40R19 - 26.72" R 275/35R19 - 26.58" Seems like the F245 - R275 are closer (by 0.04") on 19", but the front will be slightly higher (.14"). To calculate tire ratio: 245 (width of tire) / 40 (tire height ratio in%) R 19 (size of wheel) (width of the tire) / 25.4 (to convert in inch) * o.(tire height ratio) * 2 (adding the lower and upper sidewall height) + (size of wheel) 245 / 25.4 = 9.65 9.65 * .40 = 3.86 3.86 * 2 = 7.72 7.72 + 19 = 26.72"
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
08-29-2014, 07:38 PM | #5 | |
Rep 335
Many thanks to those who responded. Since the 245/40/19 and 275/35/19 combination are a couple percent taller than stock, would I be OK going with a square setup of 255/35/19 on the 8.5" ET 33 wheels? Those tires seem to be almost the same as the OEM diameter. Of course I'm open to any good ideas.
08-30-2014, 04:43 PM | #6 |
65
Rep 1,136
Dunno, and maybe others have done it, but isn't 255 too wide for the front ?
08-31-2014, 07:27 AM | #8 |
Rep 335
I found a year-old thread where a couple of guys were running 255/35-19 and 245/40-19 both square. The latter was on an xdrive...245/40-19 is the OEM square setup on the F10 xdrive.
http://f30.bimmerpost.com/forums/sho...d.php?t=866093 In this thread, the OP had 245/40-19 on RWD, but followed up with a report of a little rubbing. http://f30.bimmerpost.com/forums/sho...d.php?t=851622 IMO, the 225/40 OEM tire shown below looks a little stretched on the 8x19 wheel and the wheels I'm considering are 8.5". It appears that 235/40-19 is only marginally larger than stock diameter at 26.4". If that's workable, I wouldn't mind filling up the xdrive tire gap a bit. So many tire sizes, so little time. |
09-01-2014, 01:18 AM | #9 |
Rep 38
09-01-2014, 10:19 PM | #10 |
65
Rep 1,136
Did it rubbed at all with this setup ?
And on the picture, any drop or stock RWD height ?
09-02-2014, 01:19 PM | #11 |
Rep 38
08-11-2017, 01:47 PM | #13 |
Rep 883
Resurrection...Any chance you can post more photos? (assuming you are still a member, etc...)
Current: 2021 Carbon Black w/Cognac X5 M Sport
Sold: 2018 Dark Graphite 540i M Sport Sold: 2013 Mineral Grey 335i M-Sport Sold: 2010 Sapphire Black E90 335i |
