BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Does 340i Have a Fuel Reserve?
      06-17-2017, 08:57 AM   #1
blckz06
Drives: 340i
Anotherwards, when the remaining mileage range reaches 0 will the car literally have no fuel left, or is there like a gallon or so of safety reserve that's not accounted for in the 'range to empty?
      06-17-2017, 09:06 AM   #2
bimmer456
Drives: 340i
It typically shows fuel reserve when there is just under a quarter left or 50 miles indicated. I usually fill up before then to avoid stressing the fuel pump. I've seen folks indicating about a gallon left at 0 miles so maybe 20 miles driving normally I'd guess. I wouldn't run it that low though.
      06-17-2017, 09:13 AM   #3
blckz06
Drives: 340i
Thanks. Starting to supplement with E85, so just trying to figure out the easiest way to get the right mix.
      06-17-2017, 10:12 AM   #4
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
About 1/2 gallon IME.
      06-17-2017, 01:28 PM   #5
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
Anotherwards
In other words
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
      06-17-2017, 02:53 PM   #6
mfstrby
mfstrby's Avatar
Drives: 2013 328i xDrive
I am curious why this question comes up often, why risk to be stuck in the middle of highway with no gas with a relatively expensive car I always refill when there is a quarter left (2 quarter in the winter)
BMW11279.00
      06-17-2017, 04:31 PM   #7
BMW11
Drives: M340
since so many people said I'm wasting my time filling up (in a similar thread) lol when at half a tank i decided to start waiting till it goes down to zero sounds fun naaa it won't be harmful to my 64k BMW its fun and ill save time LOL
      06-17-2017, 04:31 PM   #8
BMW11
Drives: M340
I am curious too...
      06-17-2017, 05:09 PM   #9
rlmesq
Drives: 2018 440i M Sport
P.J. O'Rourke once said running out of gas is the stupidest thing a person can do.
BMW11279.00
      06-17-2017, 05:14 PM   #10
BMW11
Drives: M340
lol yeah he said a lot of funny stuff . just looked this one up--- "Giving money and power to government is like giving whiskey and car keys to teenage boys". lol
      06-17-2017, 05:45 PM   #11
DHS
Drives: '16 X1, '15 435i & '98 Z3
Especially true in airplanes.
      06-18-2017, 01:58 AM   #12
LRW70
LRW70's Avatar
Drives: 2016 F30 340i
2016 BMW 340i  [0.00]
Very true!
      06-18-2017, 01:14 PM   #13
rlmesq
The Porsche 356 and VWs of the same era had an actual mechanical fuel reserve. Most didn't have a fuel gauge... and the gauges weren't particularly reliable
There was an L-shaped lever on the firewall under the dash. It connected to a petcock (valve) that had three positions: on, off and reserve. In the on position, it connected to a pickup tube that extended a couple of inches up into the fuel tank. If the fuel level dropped below the pickup tube, the engine would start to starve out. The driver could reach for the petcock lever and turn it from the on (down) position to the reserve (90° right) position, opening the outlet in the bottom of the tank. There was about six litres of fuel between the pickup and the outlet, which gave about 40 miles of cruising range.
Of course, those cars had carbs. You wouldn't want to starve out fuel injectors... and trying to reach under the dash while the car was moving was just a little unsafe. Lack of seat belts made it easier.
I prefer the comfort and safety of a modern car, but there's something to be said about driving a car with an engine I could remove myself with nothing but a floor jack.
      06-18-2017, 01:49 PM   #14
kern417
Cheapskate
4450
Drives: 2018 440i |2016 340i | 2010 X5
i hate filling up my tank. i want the frequency to be as low as possible. one of the reasons i got a 4 series over a 2 series was the extra 2-gallons of fuel capacity in the tank. some of us just know that filling up when the tank is low isn't the end of the world.
that being said, if you read the thread, you'll see the OP is concerned about mixing e85. it's also helpful to know how much fuel you have if you're manually calculating mpg, running gas down to a half tank for a day at a drag strip, etc.
Youtube/Instagram/TikTok: @kern417
      06-18-2017, 01:51 PM   #15
metallicpea
metallicpea's Avatar
714
Drives: 320i ZSP & E46 M3 6MT
Well, refilling at half a tank just causes you to stop at the gas station twice as often. I prefer as few pit stops as possible, wish the tank weren't quite so small.
I will say, the amount past 0 is smaller on my F30 than any car I have ever owned. It is less than half a gallon in my experience.
      06-18-2017, 04:03 PM   #16
blckz06
Drives: 340i
Good to know.. thx for the useful replies.
      06-18-2017, 04:10 PM   #17
blckz06
Drives: 340i
Thats the reserve set up I had on my old zx10r ages ago.
      06-18-2017, 05:22 PM   #18
insanecoder
Drives: 340isDrive
Ya its an ultra expensive car and a gallon of gas is under $3
why mess around?
just doesnt make any sense
bimmer4562966.00
      06-19-2017, 07:31 AM   #19
nozydog
Driver
nozydog's Avatar
Drives: 2020 X2 M35i
I used to run my e90 down to zero on fuel gauge regularly... ended up needing a new cat (luckily within warranty) which would have cost me getting on for a grand!!! While it wasn't definitely the cause, on googling the subject I found that running low regularly is a possible cause of cat damage!! So, I suggest not taking that risk!!
      06-19-2017, 09:17 AM   #20
kern417
Cheapskate
4450
that doesn't make any sense. how could low fuel cause a cat to go bad
      06-19-2017, 09:18 AM   #21
bimmer456
Drives: 340i
Maybe it's running to lean if it's running on fumes
      06-19-2017, 09:20 AM   #22
kern417
Cheapskate
4450
why mess around?
at what point are you "messing around?" Half tank? Quarter tank? 5 miles to empty?
It really isn't that serious. your fuel pump basket makes sure the pump stays submerged in fuel even when you're low on fuel. If anything it's better the cycle the fuel through the system so you don't have old fuel sloshing around in the tank. that just make your fuel filter work harder.
