02-23-2020, 06:25 PM | #1 |
Rep 3
Radiator fan removal help!!
Hello kind bimmer fellas
I have 435 Xdrive automatic I am trying to remove radiator fan and I am having quite a bit of difficulties removing it. Basically I am following this service manual https://www.newtis.info/tisv2/a/en/f...ement/IJDZ6vvr The transmission cooler is attached to the fan cowl and it is blocking the way of the radiator fan. The manual says to remove it in upward direction and I tried but the radiator hose is blocking the way. Any other direction it won't move. I even tried to disconnect the radiator hose, but it won't budge (I unclipped, wiggled it, pried but none worked) Does anyone know how to successfully remove this radiator fan??? Any advice would be appreciated In the picture 1 = transmission cooler 2 = radiator hose ☆ = where the radiator hose blocks the transmission cooler |
02-24-2020, 11:03 AM | #2 |
Rep 2,387
For the hose, unclip it and gently use a screwdriver to lever the plastic connector off the rad as you wiggle it with your hand. Be patient and it'll come off.
For the cooler, I had this same experience with an X3 recently. First push down in the cooler to release it then pull up.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
04-09-2020, 03:30 AM | #3 | |
Rep 205
Any help would be greatly appreciated |
01-10-2023, 12:18 AM | #5 |
Rep 10
You do not have to disconnect hoses, I was able to do it by pulling the cooling fan sideways. It bearly fits through cooling hoses but you have to be gentle.
The procedure is described quite well in these two videos: 2:42 3:50 |
fan cowl, n55, radiator fan, transmission cooler |
