02-29-2024, 05:45 PM | #1 |
Rep 58
FM and AM Works, Everything Else Does Not
Was driving today and listening Sirius XM when the sound suddenly quit. The channel change buttons do not work. The system connects to my phone and I can change songs on my iPhone, but no sound. The steering wheel control will roll through the stations, but the head unit stays on (displays) the SiriusXM station that I was listening to when the sound went off.
I've done both the power button held for 30 seconds and the mode + power button held for more than 60 seconds and nothing changes. There is no reset happening. My next move is to disconnect the battery. Advice is welcomed. Thanks, Chem |
03-04-2024, 11:52 PM | #2 |
Rep 1,590
Yes, try battery first. 30 mins.
Not sure if the hard drive going bad may cause this (less likely). Buttons do not work: could be a loose connection (quad connect) in the back of the HU. Could be a CAN(1) or CAN2 issue. Check with error reader. Best would be ISTA+ and $10 ENET cable.
