10-25-2017, 07:29 PM | #1 |
Rep 22
FS: Brembo BMW M-Performance Rear Calipers
Instagram LOCATION: Manhasset, NY 11030 2 x BMW/BREMBO M Performance Rear 2-piston calipers, original blue paint with an ///M logo BMW PNs: 34218046262 & 34218046261 2 x BMW M Performance Rear Brake Pads w/ 98% life remaining BMW PN 34216876422 Last edited by Dr.Yellowbird; 01-16-2018 at 05:55 PM.. |
10-29-2017, 12:03 AM | #2 | |
Rep 44
Willing to sell rear bule caliper only?
11-04-2017, 11:26 PM | #3 |
Rep 938
so these will just bolt right up to a e46 m3 fronts?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
01-10-2018, 01:50 AM | #8 |
Rep 763
Drives: BMW E90 Dinan stage 3 335I
Figment to a pre lci e90 sedan 335i with 19 rims?
2007 E90 335i N54 Montego blue with grey Dakota leather interior
01-12-2018, 02:23 PM | #9 |
Rep 22
All, quite a few questions about the fitment of the rear calipers on the F30. Yes they fit, I have the front and rear MP BBK running on my 2015 F30 335IX.
The carriers as you can see have the same bolt to bolt hole distance, which is 78mm from center to center. They both are tapped for a M12 x 1.5 mm. The only difference is that you will need the larger rotor 345x24 compared to the standard 330x24 rotor. |
01-12-2018, 07:34 PM | #10 |
Rep 89
Very interested!! For the rear calipers and rotors, I have the m performance brakes but the rear calipers are the shitty ones. If I do want the nicer looking calipers do I have to get the rotors too?
01-14-2018, 03:52 PM | #11 |
Rep 22
Ideally if upgrading the caliper to the brembo, you would run the matching 345mm rotor. It certainly is not mandatory...however you are going to have part of the pad not in contact with a rotor...again not ideal.
